NOAA Weather Plus - Expanded NOAA Info for Indigo
Wed Nov 14, 2012 2:56 am
nsheldon offline
Re: NOAA Weather Plus - A New Indigo 5 Plugin
Patch update 1.1.8 released:
(See original post for download link).
Changes Since Version 1.1.6
Added support for Indigo 6 UI improvements.
Fixed a bug that could cause the plugin to crash if the wind direction was blank.
Fixed a bug that could cause the plugin to crash if GPS coordinates were used for which NOAA has no data and for which NOAA returns unusable XML code.
Improved error message clarity in Indigo log when unable reach the NOAA server due to DNS or network connectivity issues.
Mon Jan 21, 2013 5:50 pm
nsheldon offline
Patch update 1.1.11 released:
Changes Since Version 1.1.9
  • Fixed some bugs that would cause the runConcurrentThread to crash if various forecast data was unavailable.
  • Added more robust error checking and handling throughout.
  • Fixed a bug in the Wind Chill calculation formula that caused large negative numbers.
Tue Jan 22, 2013 12:45 pm
nsheldon offline
Patch update 1.1.12 released:
Changes Since Version 1.1.11
  • Added more debugging to and updated wind chill calculation algorithm. It now uses the alternate weather information for calculations if needed.
  • Made the alternate data gathering and parsing more efficient.
Mon May 27, 2013 4:58 pm
nsheldon offline
Patch update 1.1.13 released:
Changes Since Version 1.1.12
  • Updated forecast URL accessed. The forecast XML feed now appears to require that a language be specified in the forecast request.
  • Fixed a bug in the update method that could cause the plugin to crash if there was a problem communicating with NOAA servers.
Tue Jul 30, 2013 3:14 pm
nsheldon offline
Patch update 1.1.14 released:
Changes Since Version 1.1.13
  • Added: optional automatic version checking (enabled by default) and email notification (configurable in the plugin configuration window).
Sat Oct 05, 2013 11:35 pm
nsheldon offline
Patch update 1.1.15 released:
Changes Since Version 1.1.14
  • Fixed a bug that could cause the plugin to crash if the NOAA server stopped responding after a connection was established.
Thu Nov 28, 2013 12:41 am
nsheldon offline
Patch update 1.1.16 released:
Changes Since Version 1.1.15
  • Fixed a bug that would cause the plugin to crash if "NA" was specified for the current condition observation time.
Tue Nov 18, 2014 11:54 pm
nsheldon offline
Patch update 1.1.17 released:
Changes Since Version 1.1.16
  • Fixed a bug that would cause the plugin to crash if the wind speed element didn't exist in the weather data.
Fri Jul 24, 2015 1:51 am
nsheldon offline
Patch update 1.1.18 released:
Changes Since Version 1.1.17
  • Fixed a bug that caused the weather condition icon name state to show up as a partial URL instead of the icon filename.
Mon Jan 09, 2017 3:49 am
nsheldon offline
Patch update 1.1.19 released:
Changes Since Version 1.1.18
  • Fixed weather condition icon image names that appeared as "DualImage" for the icon name due to changes in NOAA data feed.
