Pioneer Input List Blank
Sun Dec 20, 2020 12:39 pm
NewfD90 offline
I'm using the plug-in successfully to turn on/off and control the volume on my Pioneer VSX-1022, but when I go to try and change use a change input action (Zone 1), the populated list of sources is all blank.
I've tried enabling/disabling, refreshing and even deleting/re-creating the device. All to no avail.
Any advice as to what to do next?
Mon Dec 21, 2020 12:29 am
nsheldon offline
Re: Pioneer Input List Blank
Hi.
Thanks for the report. That's very odd behavior. Be sure that you have no other devices connecting to the VSX-1022-K. Unlike the other VSX receivers supported by the plugin, that receiver was never designed for home automation support. The plugin essentially uses a "hack" to pretend like it's the iOS iControl AV app. But if you try to use any other instance of the iControl AV app anywhere else, it will break the Pioneer Receiver plugin's connection and may cause the issues you're seeing.
You may also try physically unplugging the VSX-1022-K from the wall and plugging it back in. This resets the virtual terminal server built-in to the receiver. Simply turning if off does not.
Aside from that possible cause, I can't think of anything else off hand. I'd probably need to see debug logs from the plugin. You can enable debug logging by going to the Plugins menu -> Pioneer Receiver -> Configure then check the "Enable debugging" check box. Once checked and saved, replicate the behavior and provide the full debug logs from the time you enabled debugging to the time the receiver was turned on and you couldn't see any list of inputs. Note that I only have the VSX-1021-K so all troubleshooting with other receivers has to be done through communication with folks like you with different receivers, so there'll likely be followup questions. :)
Mon Dec 21, 2020 12:08 pm
NewfD90 offline
No, nothing else is connected to it. It appears as if the problem with 1022 is that it doesn't support the ?RGB command (among many others...). I found the Pioneer API document and put together some python to test out all of the published query commands. Power, Volume, Mute and Input# is about all it supports.
For the queries it doesn't support, it just replies with it's ack - 'R'.
It looks like the plugin is expecting a proper reply from the ?RGB query to populate the input name list.
But no big deal, I've modified my action group to send the raw command to select the input I want ("15FN").
Bottom line, it's like you said, the 1022's remote control interface is half-baked.
Chance
Tue Dec 22, 2020 11:40 am
nsheldon offline
Thanks Chance.
Interesting. Even more so that it responds with an "R" acknowledgement of a valid command rather than an error code. I'm a little surprised no one else has come forward to report that issue with the 1022, though there probably aren't that many folks using that specific model at this point. But yea, the plugin assumes input names are editable like on the other VSX models so it's trying to get an updated list of those inputs. I hadn't allowed for the contingency of the receiver not providing names.
Tue Dec 22, 2020 12:44 pm
NewfD90 offline
Yes, it is odd that it doesn't reply with an error.
Anyways, I wouldn't worry about it as it looks like I'm the only person using your plugin on a 1022 :lol: and your send raw command with some delays in an action group work just fine.
Incidentally, I'm exposing the action groups to the homekit bridge so my Wife can use her Apple watch to turn on/off/switch inputs.
For completeness' sake, a debug log is below. You can see al the 'R's it send back in response to your plugin-s queries.
Interestingly, every ~30sec it sends an ack ('R'). Like a heartbeat.
Pioneer Receiver Debug deviceStartComm: adding vsx1022k deviceId 3458546 to deviceList.
Pioneer Receiver Debug connect method called.
Pioneer Receiver Debug connect: Pioneer connected? False
Pioneer Receiver Debug connect: Pioneer connecting? False
Pioneer Receiver Debug updateDeviceProps: Updating device Pioneer properties.
Pioneer Receiver Debug connect: Connecting to Pioneer at 192.168.250.116
Pioneer Receiver Debug updateDeviceState: Updating device Pioneer state: status = connecting
Pioneer Receiver Debug didDeviceCommPropertyChange called.
Pioneer Connection established.
Pioneer Receiver Debug updateDeviceState: Updating device Pioneer state: status = connected
Pioneer Receiver Debug updateDeviceState: Updating device Pioneer state: connected = True
Pioneer Receiver Debug getReceiverStatus: Getting all information for Pioneer.
Pioneer Receiver Debug getReceiverStatus: List of device IDs being updated: []
Pioneer Gathering receiver system information.
Pioneer Receiver Debug getDisplayContent: Getting Pioneer display content.
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?FL
Pioneer Receiver Debug getPowerStatus: Getting Pioneer power status.
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?P
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?AP
Pioneer Receiver Debug readData: Pioneer said: R
FN06
PWR0
R
Pioneer Receiver Debug processResponse: from Pioneer.
Pioneer Receiver Debug processResponse: Pioneer: command acknowledged.
Pioneer Receiver Debug updateDeviceState: Updating device Pioneer state: status = on (zone 1)
Pioneer Receiver Debug getInputSourceNames: Getting Pioneer input source names.
Pioneer Receiver Debug getVolumeStatus: Getting Pioneer volume status.
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?V
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ZV
Pioneer Receiver Debug getMuteStatus: Getting Pioneer mute status.
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?M
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?Z2M
Pioneer Receiver Debug getInputSourceStatus: Getting Pioneer input source status.
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ZS
Pioneer Receiver Debug getAudioInOutStatus: Getting Pioneer audio I/O status.
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?AST
Pioneer Receiver Debug getVideoInOutStatus: Getting Pioneer video I/O status.
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?VST
Pioneer Receiver Debug getTunerPresetNames: Getting Pioneer tuner preset station names.
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?TQ
Pioneer Receiver Debug getTunerPresetStatus: Getting Pioneer tuner preset status.
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?PR
Pioneer Receiver Debug getSystemSetupStatus: Getting Pioneer system settings.
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?SPK
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?PKL
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?RML
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?SSA
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?SSE
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?SSF
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?SAB
Pioneer Receiver Debug getAudioDspSettings: Getting Pioneer audio DSP settings.
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?TO
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?BA
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?TR
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?MC
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?IS
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?PQ
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?VSB
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?VHT
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?HA
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?L
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?SDA
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?SDB
Schedule _delayed_action_100
Schedule _delayed_action_101
Pioneer Receiver Debug Turning on power (zone 1) for Pioneer
Pioneer Receiver Debug sendCommand: Telling Pioneer: PO
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATA
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATC
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATD
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATE
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATF
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATG
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATH
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATJ
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATK
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATL
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATM
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATN
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATO
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATP
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATQ
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATR
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATS
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATT
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?ATU
Pioneer Receiver Debug getVideoDspSettings: Getting Pioneer video DSP settings.
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?VTB
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?VTC
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?VTD
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?VTE
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?VTG
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?VTH
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?VTL
Pioneer Receiver Debug getChannelVolumeLevels: Getting Pioneer individual channel volume levels.
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?SL_CLV
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?LW_CLV
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?SW_CLV
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?LH_CLV
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?SR_CLV
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?C__CLV
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?SBRCLV
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?RH_CLV
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?R__CLV
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?L__CLV
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?SBLCLV
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?RW_CLV
Pioneer Receiver Debug connect: Connection wait count: 0
Pioneer Receiver Debug readData: Pioneer said: VOL095
R
MUT1
R
FN06
R
R
R
VOL095
PWR0
R
PWR0
R
R
R
R
R
R
R
R
MUT1
R
PWR0
VOL095
VOL095
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
VOL095
VOL095
VOL095
VOL095
VOL095
VOL095
VOL095
R
R
R
R
R
R
R
R
R
R
R
R
Pioneer Receiver Debug processResponse: Looking for connected Virtual Volume Controllers. volumeDeviceList: []
Pioneer volume (zone 1): -33.0 dB
Schedule _delayed_action_112
Pioneer Receiver Debug sendRawCommand called: command: 15FN for Pioneer
Pioneer Receiver Debug sendCommand: Telling Pioneer: 15FN
Pioneer Receiver Debug readData: Pioneer said: FN15
Pioneer Receiver Debug updateDeviceState: Updating device Pioneer state: zone1source = 15
Pioneer Receiver Debug sendCommand: Telling Pioneer: ?RGB15
Pioneer Receiver Debug processResponse: Neither zone is using the tuner. Clearing frequency info.
R
Schedule _delayed_action_103
Schedule _delayed_action_104
Pioneer Receiver Debug deviceStopComm called: Pioneer
Pioneer Receiver Debug disconnect method called.
Pioneer Receiver Debug updateDeviceState: Updating device Pioneer state: status = disconnected
Pioneer Receiver Debug updateDeviceState: Updating device Pioneer state: connected = False
Pioneer Receiver Debug disconnect: Pioneer telnet connection is now closed.
Dec 22, 2020 at 11:39:21 AM
Dec 22, 2020 at 11:39:52 AM
Dec 22, 2020 at 11:40:23 AM
