UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2
Wed Apr 18, 2018 3:38 pm
Jann offline
Hi all.
Having issues adding or editing ANY of my lights in Hue Lights plugin..
Getting the following:
Hue Lights Error                Error in plugin execution UiValidate:
  File "plugin.py", line 877, in validateDeviceConfigUi
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2 in position 181: ordinal not in range(128)
ONLY when the lamp names in the Hue lamp have apostrophes... (ie: "Jann's Office Lamp") ... When no apostrophe in the same Hue Lamp and I reload Hue Lights (to get new device names) everything works..
Ideas please?
Wed Apr 18, 2018 4:31 pm
Re: UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2
I suspect it's a smart apostrophe that's causing the problem.
This is a normal one: '
This is a "smart" one: ’
iOS and macOS like to "fix" them for you... :roll:
Wed Apr 18, 2018 8:11 pm
nsheldon offline
I’m sure Jay is correct. I don’t exactly know how to fix this in the plugin. Python and Unicode haven’t always been the best of friends. :wink: Jay: have any pointers on how to get the plugin to not puke when it encounters Unicode in REST data?
Thu Apr 19, 2018 12:12 am
Do all your string handling in unicode, not ascii.
However, I can't figure out how the OP is getting that error on that specific line of code. Unless they're not running the current version linked from the plugin store.
Thu Apr 19, 2018 12:51 am
Jann offline
I am sure it is the apostrophe being a “smart apostrophe” or some-such...but all the software (indigo & hue lights) are updated.
Seems to me that Hue Lights are assuming EVERYthing that the JSON hue sends is ascii...not Unicode...and therein lies the issue.
Thu Apr 19, 2018 1:43 am
nsheldon offline
As far as I can tell, I am handling everything as Unicode in Hue Lights. Unless you can point out examples in the code where I’m not (along with the recommended Unicode alternate).
Thu Apr 19, 2018 5:45 am
Can you turn on debug logging and get that error again? That will show the actual data returned from the hub.
Thu Apr 19, 2018 5:49 am
I've found that using this construction has basically eliminated Unicode errors for me:
u"Something interesting: {0}".format(some_var)
But that doesn't always work:
#! /usr/bin/env python
# -*- coding: utf-8 -*-
some_var = 'º'
print(u"Something interesting: {0}".format(some_var))
Yields:
  File "untitled text 136", line 5, in <module>
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc2 in position 0: ordinal not in range(128)
So you can do this:
some_var = 'º'
print(u"Something interesting: {0}".format(some_var.decode('utf-8')))
Which yields:
Apr 19, 2018, 6:47:03 AM
untitled text 136
Something interesting: º
So I *think* you'll need to trap on the error and decode the string when needed.
Unicode is a pain.
Thu Apr 19, 2018 5:51 am
This works without the trap:
some_var = u'º'
Thu Apr 19, 2018 10:54 am
Jann offline
Well, as far as unicode in this plug-in goes, since Hue says the api is unicode, there's no issue with de-unicoding when you shouldn't, right?
So, assuming "ascii" in the plug-in wrt the item names (the names WE gave the hue bulbs) would be invalid, right? Just use the unicode line above when de-unicoding the item name, then somehow keep it unicode wrt Indigo. I wouldn't know how that is done... does Indigo use unicode when displaying names in the drop-down "item chooser" when assigning a Indigo "device" to a third-party "device?"
Jann
Thu Apr 19, 2018 10:59 am
The problem is that the line number from the error message you posted doesn't have any unicode conversion going on. Which is why I wondered if I'm looking at the same version of the plugin you are. I'm looking at 1.6.10.
Also, capturing the debug output will show the JSON data that the plugin is working with, which will also help figure out what's going wrong.
Thu Apr 19, 2018 11:03 am
Jann offline
@flyingdiver: app version is 1.6.11
Give me a minute to turn on logging, change the name BACK To apostrophe, then add it and let it give error
Will respond in 10 or so..
Thu Apr 19, 2018 11:15 am
Ah. The plugin store does not have the latest version. I found 1.6.11, and here's the line that's giving the error:
         self.debugLog(u"Data from hub: " + r.content)
So it's actually the debug statement itself. Changing that to the following will probably fix the error:
         self.debugLog(u"Data from hub: {}".format(r.content))
Thu Apr 19, 2018 11:34 am
Jann offline
Okay I found a LOT of places where "Data from hub: " was unicoded but the r.content was not. Should I change them all to use format(r.content)?
grep -n '"Data from hub:' "./Hue Lights.indigoPlugin/Contents/Server Plugin/plugin.py":
450:         self.debugLog(u"Data from hub: " + r.content)
554:         self.debugLog(u"Data from hub: " + r.content)
658:         self.debugLog(u"Data from hub: " + r.content)
773:         self.debugLog(u"Data from hub: " + r.content)
877:         self.debugLog(u"Data from hub: " + r.content)
981:         self.debugLog(u"Data from hub: " + r.content)
1145:         self.debugLog(u"Data from hub: " + r.content)
1231:         self.debugLog(u"Data from hub: " + r.content)
1341:         self.debugLog(u"Data from hub: " + r.content)
4784:      self.debugLog(u"Data from hub: " + r.content)
4844:      self.debugLog(u"Data from hub: " + r.content)
4907:      self.debugLog(u"Data from hub: " + r.content)
Thu Apr 19, 2018 11:35 am
Can't hurt. All those other ones are for the different device types, I think. If you only have the one Hue device type you'll never hit that code.
