Cant Create Hue White Ambiance lights in Indigo
Mon Oct 23, 2017 9:42 pm
reugster offline
So I have added a Hue Ambiance light to my setup. I can see it in the Hue app and control it, Change color temp etc but I cannot add it to indigo. Ive restarted the Hue Hub, Indigo, powered the light off and on, etc I can find all the other lights and when i change their names in Hue, the names do update in the plugin and are accessible.
Running Hue 1.6.6, Indigo 7.1.0 with the original Hue hub. All firmware is updated on all the bulbs.
I captured the log and I can see the "Deskbias" light in the debug messages below but cannot see it in any of the pop ups when setting up a light. it is completely unavailable.
Oct 23, 2017 at 11:15:21 PM
Disabling plugin "Hue Lights 1.6.6"
Stopping plugin "Hue Lights 1.6.6" (pid 6656)
Stopped plugin "Hue Lights 1.6.6"
Enabling plugin "Hue Lights 1.6.6"
Starting plugin "Hue Lights 1.6.6" (pid 6890)
Started plugin "Hue Lights 1.6.6"
Hue Lights Loaded 10 lights.
Hue Lights Loaded 3 groups.
Hue Lights Loaded 104 scenes.
Hue Lights Loaded 1 sensor.
Hue Lights Debug logging disabled
Hue Lights Turning on debug logging
Hue Lights Debug Starting updateSensorsList.
Hue Lights Debug Starting parseAllHueSensorsData.
Hue Lights Debug Starting updateLightsList.
Hue Lights Debug Sending command to hub: http://10.3.10.105/api/10a4607a59af2bb8 ... 598/lights
Hue Lights Debug Got response {u'11': {u'name': u'Deskbias', u'swconfigid': u'C1AD284C', u'swversion': u'1.19.0_r19755', u'manufacturername': u'Philips', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'bri': 254, u'ct': 302}, u'uniqueid': u'00:17:88:01:03:6c:63:3a-0b', u'productid': u'Philips-LTW015-1-A19CTv2', u'type': u'Color temperature light', u'modelid': u'LTW015'}, u'10': {u'name': u'Hallwaydown', u'swversion': u'5.38.2.19136', u'manufacturername': u'Philips', u'state': {u'on': True, u'reachable': True, u'bri': 204, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:00:da:b6:c1-0b', u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'1': {u'name': u'Den bias', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 14948, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4588, 0.4104], u'reachable': True, u'bri': 23, u'ct': 365, u'sat': 143}, u'uniqueid': u'00:17:88:01:00:ba:af:aa-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'3': {u'name': u'Bedroom wall', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.0, 0.0], u'reachable': False, u'bri': 0, u'ct': 0, u'sat': 0}, u'uniqueid': u'00:17:88:01:00:ba:aa:2c-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'2': {u'name': u'Office2', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.0, 0.0], u'reachable': False, u'bri': 0, u'ct': 0, u'sat': 0}, u'uniqueid': u'00:17:88:01:00:ba:a0:d8-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'5': {u'name': u'Office3', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 2049, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.3804, 0.3768], u'reachable': True, u'bri': 191, u'ct': 248, u'sat': 0}, u'uniqueid': u'00:17:88:01:00:b6:d2:0b-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'4': {u'name': u'Rob reading', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 13088, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5128, 0.4147], u'reachable': True, u'bri': 52, u'ct': 467, u'sat': 212}, u'uniqueid': u'00:17:88:01:00:ba:b0:aa-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'7': {u'name': u'Geralds bedside', u'swversion': u'5.38.2.19136', u'manufacturername': u'Philips', u'state': {u'on': True, u'reachable': True, u'bri': 58, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:00:dc:28:8d-0b', u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'6': {u'name': u'Growlight', u'swversion': u'5.38.2.19136', u'manufacturername': u'Philips', u'state': {u'on': True, u'reachable': True, u'bri': 204, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:00:d5:39:ef-0b', u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'8': {u'name': u'Basementstairs', u'swversion': u'5.38.2.19136', u'manufacturername': u'Philips', u'state': {u'on': True, u'reachable': True, u'bri': 204, u'alert': u'select'}, u'uniqueid': u'00:17:88:01:00:d5:40:9f-0b', u'type': u'Dimmable light', u'modelid': u'LWB004'}}
Hue Lights Debug Loaded lights list - {u'11': {u'name': u'Deskbias', u'swconfigid': u'C1AD284C', u'swversion': u'1.19.0_r19755', u'manufacturername': u'Philips', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'bri': 254, u'ct': 302}, u'uniqueid': u'00:17:88:01:03:6c:63:3a-0b', u'productid': u'Philips-LTW015-1-A19CTv2', u'type': u'Color temperature light', u'modelid': u'LTW015'}, u'10': {u'name': u'Hallwaydown', u'swversion': u'5.38.2.19136', u'manufacturername': u'Philips', u'state': {u'on': True, u'reachable': True, u'bri': 204, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:00:da:b6:c1-0b', u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'1': {u'name': u'Den bias', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 14948, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4588, 0.4104], u'reachable': True, u'bri': 23, u'ct': 365, u'sat': 143}, u'uniqueid': u'00:17:88:01:00:ba:af:aa-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'3': {u'name': u'Bedroom wall', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.0, 0.0], u'reachable': False, u'bri': 0, u'ct': 0, u'sat': 0}, u'uniqueid': u'00:17:88:01:00:ba:aa:2c-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'2': {u'name': u'Office2', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.0, 0.0], u'reachable': False, u'bri': 0, u'ct': 0, u'sat': 0}, u'uniqueid': u'00:17:88:01:00:ba:a0:d8-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'5': {u'name': u'Office3', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 2049, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.3804, 0.3768], u'reachable': True, u'bri': 191, u'ct': 248, u'sat': 0}, u'uniqueid': u'00:17:88:01:00:b6:d2:0b-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'4': {u'name': u'Rob reading', u'swversion': u'5.23.1.13452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 13088, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5128, 0.4147], u'reachable': True, u'bri': 52, u'ct': 467, u'sat': 212}, u'uniqueid': u'00:17:88:01:00:ba:b0:aa-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'7': {u'name': u'Geralds bedside', u'swversion': u'5.38.2.19136', u'manufacturername': u'Philips', u'state': {u'on': True, u'reachable': True, u'bri': 58, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:00:dc:28:8d-0b', u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'6': {u'name': u'Growlight', u'swversion': u'5.38.2.19136', u'manufacturername': u'Philips', u'state': {u'on': True, u'reachable': True, u'bri': 204, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:00:d5:39:ef-0b', u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'8': {u'name': u'Basementstairs', u'swversion': u'5.38.2.19136', u'manufacturername': u'Philips', u'state': {u'on': True, u'reachable': True, u'bri': 204, u'alert': u'select'}, u'uniqueid': u'00:17:88:01:00:d5:40:9f-0b', u'type': u'Dimmable light', u'modelid': u'LWB004'}}
Hue Lights Debug Starting parseAllHueLightsData.
Hue Lights Debug parseAllHueLightsData: There are 10 lights on the Hue bridge and 9 Indigo devices controlling Hue devices.
Hue Lights Debug Starting updateGroupsList.
Hue Lights Debug Sending command to hub: http://10.3.10.105/api/10a4607a59af2bb8 ... 598/groups
Hue Lights Debug Got response {u'1': {u'name': u'Dimmer 2', u'lights': [u'1', u'5'], u'state': {u'any_on': True, u'all_on': True}, u'recycle': False, u'type': u'LightGroup', u'action': {u'on': True, u'hue': 2049, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.3804, 0.3768], u'bri': 191, u'ct': 248, u'sat': 0}}, u'3': {u'name': u'Office', u'lights': [u'11'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'ct', u'bri': 254, u'ct': 302}, u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Other', u'lights': [u'1', u'2', u'3', u'4', u'5', u'6', u'7', u'8'], u'state': {u'any_on': True, u'all_on': False}, u'action': {u'on': True, u'hue': 2049, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3804, 0.3768], u'bri': 204, u'ct': 248, u'sat': 0}, u'type': u'Room', u'class': u'Other'}}
Hue Lights Debug Loaded groups list - {u'1': {u'name': u'Dimmer 2', u'lights': [u'1', u'5'], u'state': {u'any_on': True, u'all_on': True}, u'recycle': False, u'type': u'LightGroup', u'action': {u'on': True, u'hue': 2049, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.3804, 0.3768], u'bri': 191, u'ct': 248, u'sat': 0}}, u'3': {u'name': u'Office', u'lights': [u'11'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'ct', u'bri': 254, u'ct': 302}, u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Other', u'lights': [u'1', u'2', u'3', u'4', u'5', u'6', u'7', u'8'], u'state': {u'any_on': True, u'all_on': False}, u'action': {u'on': True, u'hue': 2049, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3804, 0.3768], u'bri': 204, u'ct': 248, u'sat': 0}, u'type': u'Room', u'class': u'Other'}}
Hue Lights Debug Starting parseAllHueGroupsData.
Mon Oct 23, 2017 9:52 pm
nsheldon offline
Re: Cant Create Hue White Ambiance lights in Indigo
Hi.
Thanks for the report and the debug log. It looks like that bulb (model "LTW015") might not yet be supported in the Hue Lights app. I'll release an update shortly to add support for that light.
Regards,
Nathan
Tue Oct 24, 2017 5:39 pm
reugster offline
R
Wed Oct 25, 2017 7:26 pm
nsheldon offline
Version 1.6.7 Posted
  • Added support for another Hue GU10 bulb model (LTW015).
  • Added support for minimum and maximum color temperature ranges of color temperature lights in Indigo 7.1.
Wed Oct 25, 2017 9:09 pm
reugster offline
It works perfectly. Thanks
Wed Oct 25, 2017 9:34 pm
nsheldon offline
Awesome! You’re welcome.
