Philips Hue Single Bulb V3 white & color ambiance
Sun Oct 30, 2016 1:33 am
marketability offline
Re: Philips Hue Single Bulb V3 white & color ambiance
Hi - just wanted to check whether I have a new bulb type or am being stupid trying to add them as devices
The bulb type is a GU10 spotlight model name LTW013 "Hue Ambiance Spot"
The update devices is working as it pulls in the group the new bulbs belong to but I can't add the individual bulbs as devices
ThANKS FOR YOUR HELP AS ALWAYS
Sun Oct 30, 2016 7:25 am
CliveS online
To quote from a previous post in this thread by Nathan
you can edit the "supportedDevices.py" file and add that modelID to the compatible device list in that file. To view and edit the file, go to the "Go" menu in the Finder and select "Go to Folder". Type (or paste)
/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Hue Lights.indigoPlugin/Contents/Server Plugin
Open the "supportedDevices.py" file in a text editor like TextEdit. Find the line that starts with "kHueBulbDeviceIDs". Add your modelID "LLC020" to that list, making sure it's surrounded by single quotation marks. Save the file and reload the plugin. If you're not comfortable making code changes like that, you can wait for the next update
To add your bulb first make a copy of supportedDevices.py and then open supportedDevices.py and you need to add LTW013 to kHueBulbDeviceIDs (I think! but Nathan will correct me if this is wrong)
# (compatible Hue bulb devices)
kHueBulbDeviceIDs = ['LCT001', 'LCT002', 'LCT003', 'LCT007', 'LLC010', 'LLM001', 'LLM010', 'LLM011', 'LLM012', 'LTW001', 'LTW004', 'LTW013', 'LTW014', 'LST002', 'FLS-PP3']
I used Xcode to modify my file as I found TextEdit was adding extras to my file and causing chaos
CliveS
CliveS
Sun Oct 30, 2016 11:20 am
nsheldon offline
@marketability: Nope. Not being stupid.. I'll add that model to the next update as well. Clive's instructions are spot on. If you're comfortable making that edit, it'll work right away and should be a good workaround until the next update.
@CliveS: Thanks for the assist!
Sun Oct 30, 2016 1:18 pm
Thanks Clive & Nathan - will give the edit a go!
Sun Oct 30, 2016 1:30 pm
all sorted - thanks!
Fri Nov 04, 2016 2:07 am
nsheldon offline
Version 1.3.29 Posted
  • Added support for additional Hue light models.
Fri Nov 04, 2016 2:16 am
Thanks for this - couple of issues that you might be able to help with please
should i delete the "hacked" devices I added by editing the devices file?
I'm getting these errors...
 Error                           device "Bedroom Anteroom" state key hue not defined (ignoring update request)
  Error                           device "Bedroom Anteroom" state key saturation not defined (ignoring update request)
  Error                           device "Bedroom Anteroom" state key colorX not defined (ignoring update request)
  Error                           device "Bedroom Anteroom" state key colorY not defined (ignoring update request)
  Error                           device "Bedroom Anteroom" state key colorTemp not defined (ignoring update request)
  Error                           device "Bedroom Anteroom" state key colorMode not defined (ignoring update request)
  Error                           device "Bedroom Anteroom" state key colorRed not defined (ignoring update request)
  Error                           device "Bedroom Anteroom" state key colorGreen not defined (ignoring update request)
  Error                           device "Bedroom Anteroom" state key colorBlue not defined (ignoring update request)
  Hue Lights Error                The "Lounge Lightstrip" device has an unrecognized model ID of "LST002". Hue Lights plugin does not support this device.
the LST002 device is an odd one
Thanks again
Fri Nov 04, 2016 2:25 am
I've solved the state errors by deleting and re adding the devices - thanks
Fri Nov 04, 2016 3:26 am
nsheldon offline
Hi.
Great! I'm glad you were able to resolve the errors. Yea, the version 2 light strips are a bit odd in terms of how they're defined in the plugin (due to the fact that they support color temperature).
Fri Nov 04, 2016 10:13 am
Do we know what the differences between the v2 and v3 bulbs are? I've had a look and counldn't seem to find much beyond confirmation of their existence.
Fri Nov 04, 2016 11:22 am
nsheldon offline
The docs on the Philips Hue developer site seem to indicate a slight difference in color gamut between the old and new lights. Not a big difference though.
Fri Nov 04, 2016 4:59 pm
Well I'm quite happy with my v1 bulbs and the hue + ambilight feature on my TV.. So no pressing need to upgrade :)
Mon Nov 07, 2016 12:58 am
nsheldon offline
Version 1.3.30 Posted
  • Fixed a bug in 1.3.29 that prevented Hue Lights from recognizing the 2nd generation LightStrips.
Sun Nov 13, 2016 1:21 am
nsheldon offline
Version 1.4.0 Posted
Note this version is only compatible with Indigo 7. Indigo 6 and earlier users should NOT upgrade.
  • Added support for color picker in RGB and HSB color setting actions.
  • Added support for color and white temperature UI features in Indigo.
  • Added Toggle Debugging menu item in Hue Lights plugin menu.
  • Changed Hue Lights to now require Indigo 7 or later.
  • Changed LightStrip Plus handling so it appears with the original Hue LigthStrip model in Edit Device Settings dialog.
  • Updated Hue Group device name to show that it's no longer experimental.
