Hue Phoenix Wall Light
Tue Dec 22, 2015 5:47 am
marketability offline
Hi
I have two new Phoenix wall Lights (Model HML004 66014169) that I can't add as devices.
When the plugin loads - it seems to see the correct number of lights " Hue Lights Loaded 21 lights."
But when I try and create a device the Phoenix Lights are not listed under any category
Any suggestions?
Great plugin by the way!
Tue Dec 22, 2015 11:23 pm
nsheldon offline
Re: Hue Phoenix Wall Light
Hi and thanks for the post.
The Hue Lights plugin doesn't recognize the Phoenix wall light. I can likely add support if you provide some debug log output. Simply go to the Plugins menu in Indigo then to Hue Lights -> Configure. Enable debug logging then reload the plugin (Plugins -> Hue Lights -> Reload). Copy the entire log from the point where you reloaded the plugin. I need to find the "model ID" that the Phoenix is reporting to the Hue hub in order to add support.
Wed Dec 23, 2015 3:16 am
Thanks that would be great - here's the log
Data from hub: {"state": {"on":true,"bri":254,"alert":"none","reachable":true}, "type": "Dimmable light", "name": "Porch Outside", "modelid": "LWB006", "manufacturername": "Philips","uniqueid":"00:17:88:01:10:59:63:8f-0b", "swversion": "66015095"}
Hue Lights Debug Got response {u'11': {u'name': u'Lounge Bloom', u'swversion': u'66013452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 40314, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.32079999999999997, 0.32879999999999998], u'reachable': True, u'bri': 253, u'sat': 102}, u'uniqueid': u'00:17:88:01:00:10:fe:94-0b', u'type': u'Color light', u'modelid': u'LLC011'}, u'10': {u'name': u'Lounge Strip', u'swversion': u'66015744', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 42353, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.32229999999999998, 0.32869999999999999], u'reachable': True, u'bri': 253, u'ct': 167, u'sat': 66}, u'uniqueid': u'00:17:88:01:01:1a:28:e2-0b', u'type': u'Extended color light', u'modelid': u'LST002'}, u'13': {u'name': u'Bedroom Jo', u'swversion': u'66015095', u'manufacturername': u'Philips', u'state': {u'on': True, u'reachable': True, u'bri': 90, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:10:59:5e:6c-0b', u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'12': {u'name': u'Bedroom Peter', u'swversion': u'66015095', u'manufacturername': u'Philips', u'state': {u'on': False, u'reachable': True, u'bri': 115, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:10:59:5e:6a-0b', u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'15': {u'name': u'Kitchen 4', u'swversion': u'66013105', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'reachable': True, u'bri': 254, u'ct': 234, u'sat': 44}, u'uniqueid': u'00:17:88:01:10:35:08:f1-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'14': {u'name': u'Dining Lamp', u'swversion': u'66013187', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 41860, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.37859999999999999, 0.37419999999999998], u'reachable': True, u'bri': 254, u'ct': 245, u'sat': 3}, u'uniqueid': u'00:17:88:01:00:ed:34:28-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'17': {u'name': u'Lounge Floor', u'swversion': u'66014919', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 34703, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.32279999999999998, 0.3291], u'reachable': True, u'bri': 253, u'ct': 167, u'sat': 198}, u'uniqueid': u'00:17:88:01:10:3b:41:33-0b', u'type': u'Extended color light', u'modelid': u'LCT007'}, u'16': {u'name': u'Kitchen 5', u'swversion': u'66013105', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'reachable': True, u'bri': 254, u'ct': 234, u'sat': 44}, u'uniqueid': u'00:17:88:01:00:e9:48:2d-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'19': {u'name': u'Kitchen B2', u'swversion': u'66013105', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'reachable': True, u'bri': 254, u'ct': 234, u'sat': 44}, u'uniqueid': u'00:17:88:01:10:35:09:4e-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'18': {u'name': u'Kitchen B1', u'swversion': u'66013105', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'reachable': True, u'bri': 254, u'ct': 234, u'sat': 44}, u'uniqueid': u'00:17:88:01:00:e9:3c:60-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'20': {u'name': u'Bedroom Phoenix Jo', u'swversion': u'66014169', u'manufacturername': u'Philips', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'none', u'reachable': True, u'bri': 254, u'ct': 370}, u'uniqueid': u'00:17:88:01:00:f7:83:5c-0b', u'type': u'Color temperature light', u'modelid': u'HML004'}, u'1': {u'name': u'Tulip Pink', u'swversion': u'66013452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 41860, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.37859999999999999, 0.37419999999999998], u'reachable': True, u'bri': 254, u'ct': 245, u'sat': 3}, u'uniqueid': u'00:17:88:01:00:d9:0f:ac-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'3': {u'name': u'Tom Raffield', u'swversion': u'66013452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 34703, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.32279999999999998, 0.3291], u'reachable': True, u'bri': 253, u'ct': 167, u'sat': 198}, u'uniqueid': u'00:17:88:01:00:fb:8e:ca-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'2': {u'name': u'Tulip Blue', u'swversion': u'66013452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 41860, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.37859999999999999, 0.37419999999999998], u'reachable': True, u'bri': 254, u'ct': 245, u'sat': 3}, u'uniqueid': u'00:17:88:01:00:d9:0d:94-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'5': {u'name': u'Porch Outside', u'swversion': u'66015095', u'manufacturername': u'Philips', u'state': {u'on': True, u'reachable': True, u'bri': 254, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:10:59:63:8f-0b', u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'4': {u'name': u'Corridor', u'swversion': u'66014919', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 41860, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.37859999999999999, 0.37419999999999998], u'reachable': True, u'bri': 254, u'ct': 245, u'sat': 3}, u'uniqueid': u'00:17:88:01:10:4c:00:e5-0b', u'type': u'Extended color light', u'modelid': u'LCT007'}, u'7': {u'name': u'Kitchen 1', u'swversion': u'66012457', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'reachable': True, u'bri': 254, u'ct': 234, u'sat': 44}, u'uniqueid': u'00:17:88:01:00:d6:25:f9-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'6': {u'name': u'Porch', u'swversion': u'66015095', u'manufacturername': u'Philips', u'state': {u'on': True, u'reachable': True, u'bri': 254, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:10:59:65:fb-0b', u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'9': {u'name': u'Kitchen 3', u'swversion': u'66012457', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'reachable': True, u'bri': 254, u'ct': 234, u'sat': 44}, u'uniqueid': u'00:17:88:01:00:d7:44:62-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'8': {u'name': u'Kitchen 2', u'swversion': u'66012457', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'reachable': True, u'bri': 254, u'ct': 234, u'sat': 44}, u'uniqueid': u'00:17:88:01:00:d2:1d:a6-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'21': {u'name': u'Bedroom Phoenix Peter', u'swversion': u'66014169', u'manufacturername': u'Philips', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'none', u'reachable': False, u'bri': 254, u'ct': 370}, u'uniqueid': u'00:17:88:01:00:f7:83:af-0b', u'type': u'Color temperature light', u'modelid': u'HML004'}}
Hue Lights Debug Loaded lights list - {u'11': {u'name': u'Lounge Bloom', u'swversion': u'66013452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 40314, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.32079999999999997, 0.32879999999999998], u'reachable': True, u'bri': 253, u'sat': 102}, u'uniqueid': u'00:17:88:01:00:10:fe:94-0b', u'type': u'Color light', u'modelid': u'LLC011'}, u'10': {u'name': u'Lounge Strip', u'swversion': u'66015744', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 42353, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.32229999999999998, 0.32869999999999999], u'reachable': True, u'bri': 253, u'ct': 167, u'sat': 66}, u'uniqueid': u'00:17:88:01:01:1a:28:e2-0b', u'type': u'Extended color light', u'modelid': u'LST002'}, u'13': {u'name': u'Bedroom Jo', u'swversion': u'66015095', u'manufacturername': u'Philips', u'state': {u'on': True, u'reachable': True, u'bri': 90, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:10:59:5e:6c-0b', u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'12': {u'name': u'Bedroom Peter', u'swversion': u'66015095', u'manufacturername': u'Philips', u'state': {u'on': False, u'reachable': True, u'bri': 115, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:10:59:5e:6a-0b', u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'15': {u'name': u'Kitchen 4', u'swversion': u'66013105', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'reachable': True, u'bri': 254, u'ct': 234, u'sat': 44}, u'uniqueid': u'00:17:88:01:10:35:08:f1-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'14': {u'name': u'Dining Lamp', u'swversion': u'66013187', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 41860, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.37859999999999999, 0.37419999999999998], u'reachable': True, u'bri': 254, u'ct': 245, u'sat': 3}, u'uniqueid': u'00:17:88:01:00:ed:34:28-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'17': {u'name': u'Lounge Floor', u'swversion': u'66014919', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 34703, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.32279999999999998, 0.3291], u'reachable': True, u'bri': 253, u'ct': 167, u'sat': 198}, u'uniqueid': u'00:17:88:01:10:3b:41:33-0b', u'type': u'Extended color light', u'modelid': u'LCT007'}, u'16': {u'name': u'Kitchen 5', u'swversion': u'66013105', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'reachable': True, u'bri': 254, u'ct': 234, u'sat': 44}, u'uniqueid': u'00:17:88:01:00:e9:48:2d-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'19': {u'name': u'Kitchen B2', u'swversion': u'66013105', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'reachable': True, u'bri': 254, u'ct': 234, u'sat': 44}, u'uniqueid': u'00:17:88:01:10:35:09:4e-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'18': {u'name': u'Kitchen B1', u'swversion': u'66013105', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'reachable': True, u'bri': 254, u'ct': 234, u'sat': 44}, u'uniqueid': u'00:17:88:01:00:e9:3c:60-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'20': {u'name': u'Bedroom Phoenix Jo', u'swversion': u'66014169', u'manufacturername': u'Philips', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'none', u'reachable': True, u'bri': 254, u'ct': 370}, u'uniqueid': u'00:17:88:01:00:f7:83:5c-0b', u'type': u'Color temperature light', u'modelid': u'HML004'}, u'1': {u'name': u'Tulip Pink', u'swversion': u'66013452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 41860, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.37859999999999999, 0.37419999999999998], u'reachable': True, u'bri': 254, u'ct': 245, u'sat': 3}, u'uniqueid': u'00:17:88:01:00:d9:0f:ac-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'3': {u'name': u'Tom Raffield', u'swversion': u'66013452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 34703, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.32279999999999998, 0.3291], u'reachable': True, u'bri': 253, u'ct': 167, u'sat': 198}, u'uniqueid': u'00:17:88:01:00:fb:8e:ca-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'2': {u'name': u'Tulip Blue', u'swversion': u'66013452', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 41860, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.37859999999999999, 0.37419999999999998], u'reachable': True, u'bri': 254, u'ct': 245, u'sat': 3}, u'uniqueid': u'00:17:88:01:00:d9:0d:94-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'5': {u'name': u'Porch Outside', u'swversion': u'66015095', u'manufacturername': u'Philips', u'state': {u'on': True, u'reachable': True, u'bri': 254, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:10:59:63:8f-0b', u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'4': {u'name': u'Corridor', u'swversion': u'66014919', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 41860, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.37859999999999999, 0.37419999999999998], u'reachable': True, u'bri': 254, u'ct': 245, u'sat': 3}, u'uniqueid': u'00:17:88:01:10:4c:00:e5-0b', u'type': u'Extended color light', u'modelid': u'LCT007'}, u'7': {u'name': u'Kitchen 1', u'swversion': u'66012457', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'reachable': True, u'bri': 254, u'ct': 234, u'sat': 44}, u'uniqueid': u'00:17:88:01:00:d6:25:f9-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'6': {u'name': u'Porch', u'swversion': u'66015095', u'manufacturername': u'Philips', u'state': {u'on': True, u'reachable': True, u'bri': 254, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:10:59:65:fb-0b', u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'9': {u'name': u'Kitchen 3', u'swversion': u'66012457', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'reachable': True, u'bri': 254, u'ct': 234, u'sat': 44}, u'uniqueid': u'00:17:88:01:00:d7:44:62-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'8': {u'name': u'Kitchen 2', u'swversion': u'66012457', u'manufacturername': u'Philips', u'state': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'reachable': True, u'bri': 254, u'ct': 234, u'sat': 44}, u'uniqueid': u'00:17:88:01:00:d2:1d:a6-0b', u'type': u'Extended color light', u'modelid': u'LCT003'}, u'21': {u'name': u'Bedroom Phoenix Peter', u'swversion': u'66014169', u'manufacturername': u'Philips', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'none', u'reachable': False, u'bri': 254, u'ct': 370}, u'uniqueid': u'00:17:88:01:00:f7:83:af-0b', u'type': u'Color temperature light', u'modelid': u'HML004'}}
Hue Lights Debug Got response {u'1': {u'action': {u'on': True, u'hue': 34703, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.32279999999999998, 0.3291], u'bri': 253, u'ct': 167, u'sat': 198}, u'lights': [u'3', u'10', u'11', u'17'], u'type': u'LightGroup', u'name': u'Dimmer 3'}, u'3': {u'action': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'bri': 254, u'ct': 234, u'sat': 44}, u'lights': [u'9', u'18', u'7', u'16', u'8', u'15', u'19'], u'type': u'LightGroup', u'name': u'Dimmer 8'}, u'2': {u'action': {u'on': True, u'hue': 41860, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.37859999999999999, 0.37419999999999998], u'bri': 254, u'ct': 245, u'sat': 3}, u'lights': [u'4'], u'type': u'LightGroup', u'name': u'Dimmer 4'}, u'5': {u'action': {u'on': False, u'bri': 115, u'alert': u'none'}, u'lights': [u'12'], u'type': u'LightGroup', u'name': u'Dimmer 11'}, u'4': {u'action': {u'on': True, u'alert': u'none', u'colormode': u'ct', u'bri': 254, u'ct': 370}, u'lights': [u'13', u'12', u'21', u'20'], u'type': u'LightGroup', u'name': u'Dimmer 10'}, u'6': {u'action': {u'on': True, u'bri': 90, u'alert': u'none'}, u'lights': [u'13'], u'type': u'LightGroup', u'name': u'Dimmer 12'}}
Hue Lights Debug Loaded groups list - {u'1': {u'action': {u'on': True, u'hue': 34703, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.32279999999999998, 0.3291], u'bri': 253, u'ct': 167, u'sat': 198}, u'lights': [u'3', u'10', u'11', u'17'], u'type': u'LightGroup', u'name': u'Dimmer 3'}, u'3': {u'action': {u'on': True, u'hue': 33848, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.36930000000000002, 0.3695], u'bri': 254, u'ct': 234, u'sat': 44}, u'lights': [u'9', u'18', u'7', u'16', u'8', u'15', u'19'], u'type': u'LightGroup', u'name': u'Dimmer 8'}, u'2': {u'action': {u'on': True, u'hue': 41860, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.37859999999999999, 0.37419999999999998], u'bri': 254, u'ct': 245, u'sat': 3}, u'lights': [u'4'], u'type': u'LightGroup', u'name': u'Dimmer 4'}, u'5': {u'action': {u'on': False, u'bri': 115, u'alert': u'none'}, u'lights': [u'12'], u'type': u'LightGroup', u'name': u'Dimmer 11'}, u'4': {u'action': {u'on': True, u'alert': u'none', u'colormode': u'ct', u'bri': 254, u'ct': 370}, u'lights': [u'13', u'12', u'21', u'20'], u'type': u'LightGroup', u'name': u'Dimmer 10'}, u'6': {u'action': {u'on': True, u'bri': 90, u'alert': u'none'}, u'lights': [u'13'], u'type': u'LightGroup', u'name': u'Dimmer 12'}}
Hue Lights Loaded 6 groups.
Thu Dec 24, 2015 1:16 am
nsheldon offline
Version 1.3.16 Posted
  • Added support for the Phoenix wall light.
Note that the Phoenix light will appear in the Hue bulb list. This means that the plugin will allow HSB or XY (RGB) color commands to be sent to the Phoenix even though the Phoenix does not support such commands. This will generate an error from the Hue hub (and in the plugin). Fuller support for color-temperature-only lights will require more significant changes to the plugin code later on.
Thu Dec 24, 2015 2:06 am
I love you :D
Thu Dec 24, 2015 2:39 am
Hi - the lights are working fine thanks but the plugin is throwing an error...
Hue Lights Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 656, in runConcurrentThread
File "plugin.py", line 2194, in getBulbStatus
<type 'exceptions.KeyError'>: 'hue'
Hue Lights Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
If I reload the plugin I get the following log entry...
Hue Lights Error exception in deviceStartComm(Bedroom Phoenix Jo): 'hue'
Hue Lights Error exception in deviceStartComm(Bedroom Phoenix Peter): 'hue'
Cheers
Thu Dec 24, 2015 4:31 am
nsheldon offline
Thanks for the report.
I was afraid that might happen. The error is casued because the plugin thinks the Phoenix is a Hue bulb and is asking the hub for the current color setting, but the hub doesn't have any color settings for the Phoenix lights because those lights don't support color. The quickest fix will be to make the plugin think the Phoenix lights are Lux type bulbs (which don't support any color whatsoever). It'll take a day or so to get that posted though.
Thu Dec 24, 2015 6:05 am
Thanks for your help - much appreciated
I think treating it as a Lux bulb makes sense as the lamp only handles white anyway
Have a great Xmas!
Fri Dec 25, 2015 4:39 am
nsheldon offline
Version 1.3.17 Posted
  • Updated Phoenix support so it appears in the LivingWhites device list instead of the color Hue bulbs list.
Fri Dec 25, 2015 11:37 am
thanks!
Sun Nov 13, 2016 1:23 am
nsheldon offline
Version 1.4.0 Posted
Note this version is only compatible with Indigo 7. Indigo 6 and earlier users should NOT upgrade.
  • Added support for color picker in RGB and HSB color setting actions.
  • Added support for color and white temperature UI features in Indigo.
  • Added Toggle Debugging menu item in Hue Lights plugin menu.
  • Changed Hue Lights to now require Indigo 7 or later.
  • Changed LightStrip Plus handling so it appears with the original Hue LigthStrip model in Edit Device Settings dialog.
  • Updated Hue Group device name to show that it's no longer experimental.
