Dresden Elektronik FLS-PP lp color LED light strip.
Tue Sep 15, 2015 6:11 am
Brad offline
Thank you so much for creating the Hue plug in. Your updates are how I keep up with new Hue developments. I recently installed a Dresden Elektronik FLS-PP lp ballast for under counter lighting in the kitchen and I am using them with RGBWW light strips. The Hue hub recognizes the RGB channel (extended color light) and the white channel (dimmable light). I can see and control the color channel and the white channel through the hub, but I cannot find the white channel in the plug in. Am I missing something , or is this a possible update?
Wed Sep 16, 2015 12:02 am
nsheldon offline
Re: Dresden Elektronik FLS-PP lp color LED light strip.
The Hue Lights plugin doesn't use the concept of separate channels exactly. However, it does treat the FLS-PP lp like a standard Hue bulb, which means you can send it color change commands (RGB, HSB, or XY colorspace) or color temperature (2500 K, 6500 K, etc) commands through the plugin. The plugin sends brighten and dim commands to any Hue Lights device in Indigo regardless of whether it's a color device or a white light device. It doesn't use a separate channel to do that. The plugin doesn't treat dimming commands for color lights and white lights differently. So you use the same action in the plugin to dim both color and white lights. Did that make it clearer or just more confusing?
Wed Sep 16, 2015 5:36 am
Brad offline
Thanks for the reply. In my setup, the FLS-PP appears in the Hue Hub as two separate bulbs, an extended color bulb and a dimmable bulb, both of which I can control with the iPhone app. The plugin recognizes the extended color bulb, but it does not list the dimmable bulb at all.
Wed Sep 16, 2015 10:21 am
nsheldon offline
I see. That's interesting. I don't have access to any FLS-PP to test, so I can't determine whether it's showing up as 2 different devices or one. I may be able to tell (no guarantee) if you enable debugging in the Hue Lights configuration then reload the plugin. Send the log to me from the point where you enabled debugging until the plugin loads completely (then you can disable debugging if you like).
Wed Sep 16, 2015 4:29 pm
Brad offline
I enabled debugging, but I am not sure how to tell when the plugin has completely loaded. This is what I have from reloading the plugin.
Sep 16, 2015, 6:10:06 PM
Hue Lights Debug logging enabled
Hue Lights Debug Get device status for WC2
Hue Lights Debug Sending URL request: http://192.168.1.139/api/116ea21d09828b ... /lights/12
Hue Lights Debug Data from hub: {"state": {"on":true,"bri":254,"hue":14922,"sat":144,"effect":"none","xy":[0.4595,0.4105],"ct":369,"alert":"none","colormode":"ct","reachable":false}, "type": "Extended color light", "name": "WC 2 Hue", "modelid": "LCT001", "manufacturername": "Philips","uniqueid":"00:17:88:01:00:fa:d0:20-0b", "swversion": "66009663", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}
Hue Lights Debug Get device status for Bathroom Tub
Hue Lights Debug Sending URL request: http://192.168.1.139/api/116ea21d09828b ... /lights/13
Hue Lights Debug Data from hub: {"state": {"on":false,"bri":254,"hue":9100,"sat":254,"effect":"none","xy":[0.6227,0.3605],"ct":480,"alert":"none","colormode":"ct","reachable":false}, "type": "Extended color light", "name": "Bath Hue", "modelid": "LCT001", "manufacturername": "Philips","uniqueid":"00:17:88:01:00:d8:5b:8e-0b", "swversion": "66009663", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}
Hue Lights Debug Get device status for Brad's Desk
Hue Lights Debug Sending URL request: http://192.168.1.139/api/116ea21d09828b ... 2/lights/4
Hue Lights Debug Data from hub: {"state": {"on":true,"bri":254,"alert":"select","reachable":true}, "type": "Dimmable light", "name": "Brad Desk Lux", "modelid": "LWB004", "manufacturername": "Philips","uniqueid":"00:17:88:01:00:d5:d6:ba-0b", "swversion": "66012040", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}
Hue Lights Debug Get device status for Brads Office Lux
Hue Lights Debug Sending URL request: http://192.168.1.139/api/116ea21d09828b ... /lights/10
Hue Lights Debug Data from hub: {"state": {"on":true,"bri":254,"alert":"none","reachable":true}, "type": "Dimmable light", "name": "Brads Office pendant lux", "modelid": "LWB004", "manufacturername": "Philips","uniqueid":"00:17:88:01:00:de:de:c7-0b", "swversion": "66012040", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}
Hue Lights Debug Get device status for Dining Room Lamp
Hue Lights Debug Sending URL request: http://192.168.1.139/api/116ea21d09828b ... 2/lights/5
Hue Lights Debug Data from hub: {"state": {"on":false,"bri":1,"hue":13748,"sat":254,"effect":"none","xy":[0.5321,0.4273],"ct":500,"alert":"none","colormode":"hs","reachable":true}, "type": "Extended color light", "name": "Dining Room", "modelid": "LCT001", "manufacturername": "Philips","uniqueid":"00:17:88:01:00:d8:47:09-0b", "swversion": "66013452", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}
Hue Lights Debug Get device status for Dining Room Light Strip
Hue Lights Debug Sending URL request: http://192.168.1.139/api/116ea21d09828b ... 2/lights/8
Hue Lights Debug Data from hub: {"state": {"on":false,"bri":1,"hue":1787,"sat":254,"effect":"none","xy":[0.6892,0.3095],"alert":"none","colormode":"hs","reachable":true}, "type": "Color light", "name": "Rope", "modelid": "LST001", "manufacturername": "Philips","uniqueid":"00:17:88:01:00:ce:a4:0e-0b", "swversion": "66013452", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}
Hue Lights Debug Get device status for Family Room Bloom L
Hue Lights Debug Sending URL request: http://192.168.1.139/api/116ea21d09828b ... 2/lights/6
Hue Lights Debug Data from hub: {"state": {"on":true,"bri":13,"hue":11284,"sat":254,"effect":"none","xy":[0.5622,0.4249],"alert":"none","colormode":"hs","reachable":true}, "type": "Color light", "name": "LivingColors L", "modelid": "LLC011", "manufacturername": "Philips","uniqueid":"00:17:88:01:00:c1:2d:0b-0b", "swversion": "66013452", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}
Hue Lights Debug Get device status for Family Room Bloom R
Hue Lights Debug Sending URL request: http://192.168.1.139/api/116ea21d09828b ... 2/lights/7
Hue Lights Debug Data from hub: {"state": {"on":true,"bri":64,"hue":1916,"sat":133,"effect":"none","xy":[0.5675,0.3555],"alert":"none","colormode":"hs","reachable":true}, "type": "Color light", "name": "LivingColors R", "modelid": "LLC011", "manufacturername": "Philips","uniqueid":"00:17:88:01:00:c5:e1:b9-0b", "swversion": "66013452", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}
Hue Lights Debug Get device status for Family Room Desk
Hue Lights Debug Sending URL request: http://192.168.1.139/api/116ea21d09828b ... 2/lights/2
Hue Lights Debug Data from hub: {"state": {"on":false,"bri":1,"hue":11284,"sat":254,"effect":"none","xy":[0.5578,0.4083],"ct":500,"alert":"select","colormode":"hs","reachable":true}, "type": "Extended color light", "name": "Family Room", "modelid": "LCT001", "manufacturername": "Philips","uniqueid":"00:17:88:01:00:d6:de:fe-0b", "swversion": "66013452", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}
Hue Lights Debug Get device status for Family Room globe
Hue Lights Debug Sending URL request: http://192.168.1.139/api/116ea21d09828b ... 2/lights/3
Hue Lights Debug Data from hub: {"state": {"on":false,"bri":1,"hue":11284,"sat":254,"effect":"none","xy":[0.5578,0.4083],"ct":500,"alert":"select","colormode":"hs","reachable":true}, "type": "Extended color light", "name": "FR Globe", "modelid": "LCT001", "manufacturername": "Philips","uniqueid":"00:17:88:01:00:e1:6e:f9-0b", "swversion": "66013452", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}
Hue Lights Debug Get device status for Family Room Upright
Hue Lights Debug Sending URL request: http://192.168.1.139/api/116ea21d09828b ... 2/lights/1
Hue Lights Debug Data from hub: {"state": {"on":true,"bri":51,"hue":8736,"sat":254,"effect":"none","xy":[0.5842,0.3889],"ct":500,"alert":"none","colormode":"hs","reachable":true}, "type": "Extended color light", "name": "FR Uplight", "modelid": "LCT001", "manufacturername": "Philips","uniqueid":"00:17:88:01:00:e1:64:e8-0b", "swversion": "66013452", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}
Hue Lights Debug Get device status for KitchenUC 1
Hue Lights Debug Sending URL request: http://192.168.1.139/api/116ea21d09828b ... /lights/16
Hue Lights Debug Data from hub: {"state": {"on":true,"bri":254,"hue":9133,"sat":80,"effect":"none","xy":[0.3563,0.3603],"ct":216,"alert":"none","colormode":"ct","reachable":true}, "type": "Extended color light", "name": "Extended color light 1", "modelid": "FLS-PP3", "manufacturername": "dresden elektronik","uniqueid":"00:21:2e:ff:ff:00:7c:f5-0a", "swversion": "020E.2010009B", "pointsymbol": { "1":"0f00f0ffff000033330000333300003333000044", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}
Disabling plugin "Hue Lights 1.3.12"
Stopping plugin "Hue Lights 1.3.12" (pid 351)
Hue Lights Debug Get device status for KitchenUC 2
Hue Lights Debug Sending URL request: http://192.168.1.139/api/116ea21d09828b ... /lights/18
Hue Lights Debug Data from hub: {"state": {"on":true,"bri":254,"hue":9133,"sat":80,"effect":"none","xy":[0.3563,0.3603],"ct":216,"alert":"none","colormode":"ct","reachable":true}, "type": "Extended color light", "name": "Extended color light 2", "modelid": "FLS-PP3", "manufacturername": "dresden elektronik","uniqueid":"00:21:2e:ff:ff:00:7f:c0-0a", "swversion": "020E.2010009B", "pointsymbol": { "1":"0f00f0ffff000033330000333300003333000044", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}
Hue Lights Debug Get device status for Master Bed Lamp
Hue Lights Debug Sending URL request: http://192.168.1.139/api/116ea21d09828b ... 2/lights/9
Hue Lights Debug Data from hub: {"state": {"on":false,"bri":1,"alert":"none","reachable":true}, "type": "Dimmable light", "name": "Bedroom Lux", "modelid": "LWB004", "manufacturername": "Philips","uniqueid":"00:17:88:01:00:df:57:ad-0b", "swversion": "66012040", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}
Hue Lights Debug runConcurrentThread stopped.
Hue Lights Debug runConcurrentThread exiting.
Hue Lights Debug Stopping device: Bathroom Tub
Hue Lights Debug Stopping device: Brad's Desk
Hue Lights Debug Stopping device: Brads Office Lux
Hue Lights Debug Stopping device: Dining Room Lamp
Hue Lights Debug Stopping device: Dining Room Light Strip
Hue Lights Debug Stopping device: Dining Room Light Strip Hue
Hue Lights Debug Stopping device: Dining Room Light Strip K
Hue Lights Debug Stopping device: Family Room Bloom L
Hue Lights Debug Stopping device: Family Room Bloom Left Blue
Hue Lights Debug Stopping device: Family Room Bloom Left Color K
Hue Lights Debug Stopping device: Family Room Bloom Left Green
Hue Lights Debug Stopping device: Family Room Bloom Left Hue
Hue Lights Debug Stopping device: Family Room Bloom Left Red
Hue Lights Debug Stopping device: Family Room Bloom Left Saturation
Hue Lights Debug Stopping device: Family Room Bloom R
Hue Lights Debug Stopping device: Family Room Desk
Hue Lights Debug Stopping device: Family Room globe
Hue Lights Debug Stopping device: Family Room Upright
Hue Lights Debug Stopping device: KitchenUC 1
Hue Lights Debug Stopping device: KitchenUC 1 Color Temp
Hue Lights Debug Stopping device: KitchenUC 1 Hue
Hue Lights Debug Stopping device: KitchenUC 2
Hue Lights Debug Stopping device: KitchenUC 2 Color Temp
Hue Lights Debug Stopping device: KitchenUC 2 Hue
Hue Lights Debug Stopping device: Master Bed Lamp
Hue Lights Debug Stopping device: WC1
Hue Lights Debug Stopping device: WC2
Hue Lights Debug Plugin shutdown called
Stopped plugin "Hue Lights 1.3.12"
Enabling plugin "Hue Lights 1.3.12"
Starting plugin "Hue Lights 1.3.12" (pid 8712)
Hue Lights Debug Initializing Plugin.
Started plugin "Hue Lights 1.3.12"
Hue Lights Debug Startup called
Hue Lights Debug pluginPrefs contains 30 presets.
Hue Lights Debug Got response {u'11': {u'name': u'WC 1 Hue', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'hue': 14910, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.45960000000000001, 0.41049999999999998], u'reachable': False, u'bri': 254, u'ct': 369, u'sat': 144}, u'uniqueid': u'00:17:88:01:00:fd:fa:55-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'10': {u'name': u'Brads Office pendant lux', u'swversion': u'66012040', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'reachable': True, u'bri': 254, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:00:de:de:c7-0b', u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'13': {u'name': u'Bath Hue', u'swversion': u'66009663', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': False, u'hue': 9100, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.62270000000000003, 0.36049999999999999], u'reachable': False, u'bri': 254, u'ct': 480, u'sat': 254}, u'uniqueid': u'00:17:88:01:00:d8:5b:8e-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'12': {u'name': u'WC 2 Hue', u'swversion': u'66009663', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'hue': 14922, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.45950000000000002, 0.41049999999999998], u'reachable': False, u'bri': 254, u'ct': 369, u'sat': 144}, u'uniqueid': u'00:17:88:01:00:fa:d0:20-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'17': {u'name': u'Dimmable light 1', u'swversion': u'020E.2010009B', u'manufacturername': u'dresden elektronik', u'pointsymbol': {u'1': u'0f00f0ffff000033330000333300003333000044', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'reachable': True, u'bri': 70, u'alert': u'none'}, u'uniqueid': u'00:21:2e:ff:ff:00:7c:f5-0b', u'type': u'Dimmable light', u'modelid': u'FLS-PP3 White'}, u'16': {u'name': u'Extended color light 1', u'swversion': u'020E.2010009B', u'manufacturername': u'dresden elektronik', u'pointsymbol': {u'1': u'0f00f0ffff000033330000333300003333000044', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'hue': 9133, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.35630000000000001, 0.36030000000000001], u'reachable': True, u'bri': 254, u'ct': 216, u'sat': 80}, u'uniqueid': u'00:21:2e:ff:ff:00:7c:f5-0a', u'type': u'Extended color light', u'modelid': u'FLS-PP3'}, u'19': {u'name': u'Dimmable light 2', u'swversion': u'020E.2010009B', u'manufacturername': u'dresden elektronik', u'pointsymbol': {u'1': u'0f00f0ffff000033330000333300003333000044', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'reachable': True, u'bri': 73, u'alert': u'none'}, u'uniqueid': u'00:21:2e:ff:ff:00:7f:c0-0b', u'type': u'Dimmable light', u'modelid': u'FLS-PP3 White'}, u'18': {u'name': u'Extended color light 2', u'swversion': u'020E.2010009B', u'manufacturername': u'dresden elektronik', u'pointsymbol': {u'1': u'0f00f0ffff000033330000333300003333000044', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'hue': 9133, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.35630000000000001, 0.36030000000000001], u'reachable': True, u'bri': 254, u'ct': 216, u'sat': 80}, u'uniqueid': u'00:21:2e:ff:ff:00:7f:c0-0a', u'type': u'Extended color light', u'modelid': u'FLS-PP3'}, u'1': {u'name': u'FR Uplight', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'hue': 8736, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.58420000000000005, 0.38890000000000002], u'reachable': True, u'bri': 51, u'ct': 500, u'sat': 254}, u'uniqueid': u'00:17:88:01:00:e1:64:e8-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'3': {u'name': u'FR Globe', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': False, u'hue': 11284, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.55779999999999996, 0.4083], u'reachable': True, u'bri': 1, u'ct': 500, u'sat': 254}, u'uniqueid': u'00:17:88:01:00:e1:6e:f9-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'2': {u'name': u'Family Room', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': False, u'hue': 11284, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.55779999999999996, 0.4083], u'reachable': True, u'bri': 1, u'ct': 500, u'sat': 254}, u'uniqueid': u'00:17:88:01:00:d6:de:fe-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'5': {u'name': u'Dining Room', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': False, u'hue': 13748, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.53210000000000002, 0.42730000000000001], u'reachable': True, u'bri': 1, u'ct': 500, u'sat': 254}, u'uniqueid': u'00:17:88:01:00:d8:47:09-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'4': {u'name': u'Brad Desk Lux', u'swversion': u'66012040', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'reachable': True, u'bri': 254, u'alert': u'select'}, u'uniqueid': u'00:17:88:01:00:d5:d6:ba-0b', u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'7': {u'name': u'LivingColors R', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'hue': 1916, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.5675, 0.35549999999999998], u'reachable': True, u'bri': 64, u'sat': 133}, u'uniqueid': u'00:17:88:01:00:c5:e1:b9-0b', u'type': u'Color light', u'modelid': u'LLC011'}, u'6': {u'name': u'LivingColors L', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'hue': 11284, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.56220000000000003, 0.4249], u'reachable': True, u'bri': 13, u'sat': 254}, u'uniqueid': u'00:17:88:01:00:c1:2d:0b-0b', u'type': u'Color light', u'modelid': u'LLC011'}, u'9': {u'name': u'Bedroom Lux', u'swversion': u'66012040', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': False, u'reachable': True, u'bri': 1, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:00:df:57:ad-0b', u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'8': {u'name': u'Rope', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': False, u'hue': 1787, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.68920000000000003, 0.3095], u'reachable': True, u'bri': 1, u'sat': 254}, u'uniqueid': u'00:17:88:01:00:ce:a4:0e-0b', u'type': u'Color light', u'modelid': u'LST001'}}
Hue Lights Debug Loaded lights list - {u'11': {u'name': u'WC 1 Hue', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'hue': 14910, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.45960000000000001, 0.41049999999999998], u'reachable': False, u'bri': 254, u'ct': 369, u'sat': 144}, u'uniqueid': u'00:17:88:01:00:fd:fa:55-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'10': {u'name': u'Brads Office pendant lux', u'swversion': u'66012040', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'reachable': True, u'bri': 254, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:00:de:de:c7-0b', u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'13': {u'name': u'Bath Hue', u'swversion': u'66009663', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': False, u'hue': 9100, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.62270000000000003, 0.36049999999999999], u'reachable': False, u'bri': 254, u'ct': 480, u'sat': 254}, u'uniqueid': u'00:17:88:01:00:d8:5b:8e-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'12': {u'name': u'WC 2 Hue', u'swversion': u'66009663', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'hue': 14922, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.45950000000000002, 0.41049999999999998], u'reachable': False, u'bri': 254, u'ct': 369, u'sat': 144}, u'uniqueid': u'00:17:88:01:00:fa:d0:20-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'17': {u'name': u'Dimmable light 1', u'swversion': u'020E.2010009B', u'manufacturername': u'dresden elektronik', u'pointsymbol': {u'1': u'0f00f0ffff000033330000333300003333000044', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'reachable': True, u'bri': 70, u'alert': u'none'}, u'uniqueid': u'00:21:2e:ff:ff:00:7c:f5-0b', u'type': u'Dimmable light', u'modelid': u'FLS-PP3 White'}, u'16': {u'name': u'Extended color light 1', u'swversion': u'020E.2010009B', u'manufacturername': u'dresden elektronik', u'pointsymbol': {u'1': u'0f00f0ffff000033330000333300003333000044', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'hue': 9133, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.35630000000000001, 0.36030000000000001], u'reachable': True, u'bri': 254, u'ct': 216, u'sat': 80}, u'uniqueid': u'00:21:2e:ff:ff:00:7c:f5-0a', u'type': u'Extended color light', u'modelid': u'FLS-PP3'}, u'19': {u'name': u'Dimmable light 2', u'swversion': u'020E.2010009B', u'manufacturername': u'dresden elektronik', u'pointsymbol': {u'1': u'0f00f0ffff000033330000333300003333000044', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'reachable': True, u'bri': 73, u'alert': u'none'}, u'uniqueid': u'00:21:2e:ff:ff:00:7f:c0-0b', u'type': u'Dimmable light', u'modelid': u'FLS-PP3 White'}, u'18': {u'name': u'Extended color light 2', u'swversion': u'020E.2010009B', u'manufacturername': u'dresden elektronik', u'pointsymbol': {u'1': u'0f00f0ffff000033330000333300003333000044', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'hue': 9133, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.35630000000000001, 0.36030000000000001], u'reachable': True, u'bri': 254, u'ct': 216, u'sat': 80}, u'uniqueid': u'00:21:2e:ff:ff:00:7f:c0-0a', u'type': u'Extended color light', u'modelid': u'FLS-PP3'}, u'1': {u'name': u'FR Uplight', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'hue': 8736, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.58420000000000005, 0.38890000000000002], u'reachable': True, u'bri': 51, u'ct': 500, u'sat': 254}, u'uniqueid': u'00:17:88:01:00:e1:64:e8-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'3': {u'name': u'FR Globe', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': False, u'hue': 11284, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.55779999999999996, 0.4083], u'reachable': True, u'bri': 1, u'ct': 500, u'sat': 254}, u'uniqueid': u'00:17:88:01:00:e1:6e:f9-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'2': {u'name': u'Family Room', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': False, u'hue': 11284, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.55779999999999996, 0.4083], u'reachable': True, u'bri': 1, u'ct': 500, u'sat': 254}, u'uniqueid': u'00:17:88:01:00:d6:de:fe-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'5': {u'name': u'Dining Room', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': False, u'hue': 13748, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.53210000000000002, 0.42730000000000001], u'reachable': True, u'bri': 1, u'ct': 500, u'sat': 254}, u'uniqueid': u'00:17:88:01:00:d8:47:09-0b', u'type': u'Extended color light', u'modelid': u'LCT001'}, u'4': {u'name': u'Brad Desk Lux', u'swversion': u'66012040', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'reachable': True, u'bri': 254, u'alert': u'select'}, u'uniqueid': u'00:17:88:01:00:d5:d6:ba-0b', u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'7': {u'name': u'LivingColors R', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'hue': 1916, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.5675, 0.35549999999999998], u'reachable': True, u'bri': 64, u'sat': 133}, u'uniqueid': u'00:17:88:01:00:c5:e1:b9-0b', u'type': u'Color light', u'modelid': u'LLC011'}, u'6': {u'name': u'LivingColors L', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': True, u'hue': 11284, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.56220000000000003, 0.4249], u'reachable': True, u'bri': 13, u'sat': 254}, u'uniqueid': u'00:17:88:01:00:c1:2d:0b-0b', u'type': u'Color light', u'modelid': u'LLC011'}, u'9': {u'name': u'Bedroom Lux', u'swversion': u'66012040', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': False, u'reachable': True, u'bri': 1, u'alert': u'none'}, u'uniqueid': u'00:17:88:01:00:df:57:ad-0b', u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'8': {u'name': u'Rope', u'swversion': u'66013452', u'manufacturername': u'Philips', u'pointsymbol': {u'1': u'none', u'3': u'none', u'2': u'none', u'5': u'none', u'4': u'none', u'7': u'none', u'6': u'none', u'8': u'none'}, u'state': {u'on': False, u'hue': 1787, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.68920000000000003, 0.3095], u'reachable': True, u'bri': 1, u'sat': 254}, u'uniqueid': u'00:17:88:01:00:ce:a4:0e-0b', u'type': u'Color light', u'modelid': u'LST001'}}
Hue Lights Loaded 17 lights.
Hue Lights Debug Got response {u'1': {u'action': {u'on': True, u'bri': 254, u'alert': u'none'}, u'lights': [u'4', u'10'], u'type': u'LightGroup', u'name': u'Brads Office'}, u'2': {u'action': {u'on': True, u'hue': 9133, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.35630000000000001, 0.36030000000000001], u'bri': 254, u'ct': 216, u'sat': 80}, u'lights': [u'17', u'16', u'19', u'18'], u'type': u'LightGroup', u'name': u'Kitchen'}}
Hue Lights Debug Loaded groups list - {u'1': {u'action': {u'on': True, u'bri': 254, u'alert': u'none'}, u'lights': [u'4', u'10'], u'type': u'LightGroup', u'name': u'Brads Office'}, u'2': {u'action': {u'on': True, u'hue': 9133, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.35630000000000001, 0.36030000000000001], u'bri': 254, u'ct': 216, u'sat': 80}, u'lights': [u'17', u'16', u'19', u'18'], u'type': u'LightGroup', u'name': u'Kitchen'}}
Hue Lights Loaded 2 groups.
Hue Lights Debug Starting device: Bathroom Tub
Hue Lights Debug Hue Bulb device definition:
address : 192.168.1.4 (ID 13)
batteryLevel : None
brightness : 0
buttonGroupCount : 0
configured : True
defaultBrightness : 100
description :
deviceTypeId : hueBulb
displayStateValRaw : 0
displayStateValUi : 0
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 0
com.nathansheldon.indigoplugin.HueLights : (dict)
address : 192.168.1.4 (ID 13) (string)
bulbId : 13 (string)
defaultBrightness : 40 (string)
modelId : LCT001 (string)
nameOnHub : Bath Hue (string)
rate : 0 (string)
savedBrightness : 255 (integer)
lastChanged : 2015-09-16 08:12:50
ledStates : []
model : Hue Bulb (Original, Downlight, Spotlight, etc.)
onBrightensToDefaultToggle : False
onBrightensToLast : False
onState : False
pluginId : com.nathansheldon.indigoplugin.HueLights
pluginProps : com.nathansheldon.indigoplugin.HueLights : (dict)
rate : 0 (string)
protocol : Plugin
remoteDisplay : True
states : States : (dict)
alertMode : none (string)
brightnessLevel : 0 (integer)
colorBlue : 0 (integer)
colorGreen : 0 (integer)
colorMode : ct (string)
colorRed : 0 (integer)
colorTemp : 2083 (integer)
colorX : 0.6227 (real)
colorY : 0.3605 (real)
effect : none (string)
hue : 50 (integer)
online : false (bool)
saturation : 100 (integer)
subModel :
supportsAllOff : False
supportsStatusRequest : True
Sat Sep 19, 2015 1:17 am
nsheldon offline
Version 1.3.13 Posted
  • Added support for the Dresden Elektronik FLS-PP lp LED strip white light segment.
Sat Sep 19, 2015 7:40 am
Brad offline
Freakin awesome. Works like a champ with so many possibilities. Thank you so very much.
Sat Sep 19, 2015 8:16 pm
nsheldon offline
Excellent! Glad to hear it works well.
