Hue Go
Mon Jul 06, 2015 8:19 pm
CntryDoe offline
Hue Go
I'm a big fan of the Hue Lights Plugin! (Thanks for all your hard work Nathan)
I finally got a "Hue Go" to play with. Unfortunately, it's not showing in the define device screen. I suspect that the plugin needs an update to support this device, unless I missed something obvious.
If anyone has questions about the HueGo, I'd be happy to answer what I can, or provide log info, etc... I'm not concerned about it working right away, however I thought I'd throw a post up in case anyone else was curious.
JT
Fri Jul 10, 2015 3:29 am
nsheldon offline
Re: Hue Go
Hi JT.
You're correct. The plugin needs to be updated to support the Hue Go. It's a simple update though. I just need to add the ModelID for the Hue Go to the plugin code and it'll be good to go. I found the Hue documentation that covers the ModelID for all supported lights (including the Hue Go). I'll get that updated soon and post a new plugin version.
Mon Jul 13, 2015 2:37 am
nsheldon offline
Re: Hue Go
Version 1.3.11 Posted:
  • Added support for Hue Go and Hue Color Light and Color Temperature Modules.
Sun Nov 13, 2016 1:25 am
nsheldon offline
Re: Hue Go
Version 1.4.0 Posted
Note this version is only compatible with Indigo 7. Indigo 6 and earlier users should NOT upgrade.
  • Added support for color picker in RGB and HSB color setting actions.
  • Added support for color and white temperature UI features in Indigo.
  • Added Toggle Debugging menu item in Hue Lights plugin menu.
  • Changed Hue Lights to now require Indigo 7 or later.
  • Changed LightStrip Plus handling so it appears with the original Hue LigthStrip model in Edit Device Settings dialog.
  • Updated Hue Group device name to show that it's no longer experimental.
