Hello,
I am hoping for a bit of help. I am unable to get the plugin to register with the hue hub. I suspect that this may somehow be due to my botching my first attempt at installation. I fat fingered the entry of the hub's ip and entered it incorrectly. I caught the error when I tried to create my first hue device (bulb) and I got an error indicating that I was not paired with the hub. I went back into config and spotted the incorrect ip. I changed the ip, hit start/finish, pressed the button on the hub, and hit start finish again. No go. I tried reloading hue devices but that made no difference.
At that point I tried deleting the prefs file and reconfiguring numerous times, removing the entire plugin and starting over numerous times, resetting the hue hub to its default settings (button on the bottom of the hub), upgrading the hub's firmware, restarting the router, changing the ip reservation for the hub, etc. All to no effect. I am still seeing the same error when trying to create and configure a device.
I have verified the ip of the hub both on my router and on the meet hue website. It is correct. I can control the bulbs through my ios devices just fine.
I have noticed that when I click the start/finish button a message saying something about waiting for the hub flashes for just a split second at the bottom of the config pane. Should this message be persisting until I hit the button on the hub?
Here is my log file:
2015-01-11 21:32:35.732 Application Starting Indigo Server version 6.0.19 (Mac OS X 10.5.
2015-01-11 21:32:35.732 Application Loading attachments
2015-01-11 21:32:35.743 Application "device target attachment.scpt" script loaded
2015-01-11 21:32:35.751 Application "group target attachment.scpt" script loaded
2015-01-11 21:32:35.762 Application "growl attachment.scpt" script loaded
2015-01-11 21:32:35.791 Application "iTunes attachment.scpt" script loaded
2015-01-11 21:32:35.799 Application "scenes attachment.scpt" script loaded
2015-01-11 21:32:35.811 Application "time stamp attachment.scpt" script loaded
2015-01-11 21:32:36.212 Application Loading plugin "Action Collection 1.4.13"
2015-01-11 21:32:36.251 Application Starting plugin "Action Collection 1.4.13" (pid 320)
2015-01-11 21:32:36.254 Application Loading interface "INSTEON Commands 2.0.5"
2015-01-11 21:32:36.287 Application Starting interface "INSTEON Commands 2.0.5" (pid 321)
2015-01-11 21:32:36.290 Application Loading interface "Z-Wave 1.0.301"
2015-01-11 21:32:36.320 Application Starting interface "Z-Wave 1.0.301" (pid 322)
2015-01-11 21:32:36.325 Application Found disabled plugin "Airfoil 1.1.7"
2015-01-11 21:32:36.327 Application Found disabled plugin "DIRECTV DVR Control 1.0.0"
2015-01-11 21:32:36.329 Application Found disabled plugin "EasyDAQ Relay Card 1.1.7"
2015-01-11 21:32:36.330 Application Found disabled plugin "Growl 1.1.2"
2015-01-11 21:32:36.397 Application Found disabled plugin "Hue Lights 1.3.10"
2015-01-11 21:32:36.399 Application Found disabled plugin "iCal Alarm Processor 1.1.0"
2015-01-11 21:32:36.401 Application Found disabled plugin "iTunes 1.1.5"
2015-01-11 21:32:36.403 Application Found disabled plugin "NOAA Weather 1.1.1"
2015-01-11 21:32:36.405 Application Found disabled plugin "SQL Logger 1.1.8"
2015-01-11 21:32:36.406 Application Found disabled plugin "Timers and Pesters 1.1.5"
2015-01-11 21:32:36.443 Application Found disabled plugin "Vera Bridge 1.0.6"
2015-01-11 21:32:36.444 Application Found disabled interface "Virtual Devices 1.0.11"
2015-01-11 21:32:36.446 Application Found disabled plugin "WeatherSnoop 2.0.5"
2015-01-11 21:32:36.478 Application Bonjour registered "Indigo - Sample House"
2015-01-11 21:32:36.929 Application Indigo Cocoa client connected
2015-01-11 21:32:39.964 Application Started plugin "Action Collection 1.4.13"
2015-01-11 21:32:40.252 Application Started interface "INSTEON Commands 2.0.5"
2015-01-11 21:32:42.789 Application Started interface "Z-Wave 1.0.301"
2015-01-11 21:32:43.115 Z-Wave connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
2015-01-11 21:32:44.676 Application WebServer client connected
2015-01-11 21:32:44.695 WebServer started on port 8176 -- digest authentication enabled
2015-01-11 21:32:46.216 Application Connected to PowerLinc 2413U interface on port usbserial-A603342I
2015-01-11 21:32:46.216 Application PowerLinc address 33.E3.CE, firmware version 9.14
2015-01-11 21:32:57.450 Schedule Basement stairway lights (delayed action)
2015-01-11 21:32:57.729 Sent INSTEON "Basement stairway dimmer" off
2015-01-11 21:32:59.401 Application Enabling plugin "Hue Lights 1.3.10"
2015-01-11 21:32:59.410 Application Starting plugin "Hue Lights 1.3.10" (pid 324)
2015-01-11 21:33:00.970 Application Started plugin "Hue Lights 1.3.10"
2015-01-11 21:33:01.183 Z-Wave received "002 - Luminance" sensor update to 6 lux
2015-01-11 21:33:01.219 Z-Wave received "002 - Humidity" sensor update to 29%
2015-01-11 21:33:01.253 Z-Wave received "002 - Temperature" sensor update to 65.3 °F
2015-01-11 21:33:01.703 Hue Lights Your plugin version, v1.3.10, is current.
2015-01-11 21:33:01.707 Hue Lights Error No IP address set for the Hue hub. You can get this information from the My Settings page at http://www.meethue.com.
2015-01-11 21:33:01.710 Hue Lights Error No IP address set for the Hue hub. You can get this information from the My Settings page at http://www.meethue.com.
2015-01-11 21:33:10.659 Hue Lights Debug logging enabled
2015-01-11 21:34:52.430 Hue Lights Checking with the Hue hub at for pairing state...
2015-01-11 21:34:52.431 Hue Lights Debug Request is {"username": "1e70b00cb07269f3995d6cf86e4b7a54", "devicetype": "Indigo Hue Plugin"}
2015-01-11 21:34:52.976 Hue Lights Error Failed to connect to the Hue hub at . - Check that the hub is connected and turned on and that the network settings are correct.
2015-01-11 21:35:03.852 Z-Wave received "Basement stairway - Motion Sensor" status update is on
2015-01-11 21:35:03.853 Trigger Basement stairway lights
2015-01-11 21:35:04.200 Sent INSTEON "Basement stairway dimmer" on to 100
2015-01-11 21:35:23.391 Z-Wave received "Basement stairway - Motion Sensor" status update is off
2015-01-11 21:35:32.180 Z-Wave received "Basement stairway - Motion Sensor" status update is on
2015-01-11 21:35:32.181 Trigger Basement stairway lights
2015-01-11 21:35:32.461 Sent INSTEON "Basement stairway dimmer" on to 100
2015-01-11 21:35:48.983 Hue Lights Checking with the Hue hub at for pairing state...
2015-01-11 21:35:48.984 Hue Lights Debug Request is {"username": "1e70b00cb07269f3995d6cf86e4b7a54", "devicetype": "Indigo Hue Plugin"}
2015-01-11 21:35:48.984 Hue Lights Error Failed to connect to the Hue hub at . - Check that the hub is connected and turned on and that the network settings are correct.
2015-01-11 21:35:51.020 Hue Lights Debug closedPrefsConfigUi called
2015-01-11 21:35:51.020 Hue Lights Debug logging enabled
2015-01-11 21:35:51.409 Z-Wave received "Basement stairway - Motion Sensor" status update is off
2015-01-11 21:36:15.655 Hue Lights Debug closedPrefsConfigUi called
2015-01-11 21:36:15.655 Hue Lights Debug logging disabled
I do not know why it indicates that there is no ip set for the hub. I opened up the prefs file for the plugin and saw that it did have the correct ip as set in the config pane.
Thanks in advance. Any help will be very much appreciated.
Yours,
Jesse
