nsheldon wrote:...curl will likely work.
berkinet wrote:Just got an email from Rainforest Automation about a software upgrade for the Eagle. … ... I've signed up for the beta.
berkinet wrote:You might want to wait before upgrading…
The beta 2.0 software was loaded on my Eagle this morning, and it breaks the plugin..
Nov 13, 2013, 6:08:16 PM
Energy EAGLE Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 637, in runConcurrentThread
File "plugin.py", line 1573, in eagleSummationValues
<type 'exceptions.UnboundLocalError'>: local variable 'tempTimestamp' referenced before assignment
Energy EAGLE Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Received INSTEON "Garage Occupancy Sensor South" off (button 1)
Indigo Cocoa client disconnected (192.168.252.43)
Indigo Cocoa client authenticated (192.168.252.43)
Reloading plugin "Energy EAGLE 0.9.12"
Stopping plugin "Energy EAGLE 0.9.12" (pid 53900)
Stopped plugin "Energy EAGLE 0.9.12"
Starting plugin "Energy EAGLE 0.9.12" (pid 6540)
Started plugin "Energy EAGLE 0.9.12"
Nov 13, 2013, 6:08:59 PM
Nov 13, 2013, 6:09:33 PM
2013-11-13 17:01:14 Energy EAGLE Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 1496, in eagleSummationValues
File "plugin.py", line 1690, in sendCommand
<class 'socket.error'>: (54, 'Connection reset by peer')
2013-11-13 17:01:14 Energy EAGLE Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2013-11-13 17:01:24 Energy EAGLE Error Error connecting to "Rainforest Gateway". Error: (61, 'Connection refused')
2013-11-13 17:01:24 Energy EAGLE Error Error sending data to "Rainforest Gateway". Error: 'bool' object has no attribute 'close'
2013-11-13 17:01:24 Energy EAGLE Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 633, in runConcurrentThread
File "plugin.py", line 908, in eagleDeviceData
File "plugin.py", line 1677, in sendCommand
File "plugin.py", line 1767, in disconnect
<type 'exceptions.AttributeError'>: 'bool' object has no attribute 'close'
2013-11-13 17:01:24 Energy EAGLE Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2013-11-13 17:01:34 Energy EAGLE Error Error connecting to "Rainforest Gateway". Error: (61, 'Connection refused')
2013-11-13 17:01:34 Energy EAGLE Error Error sending data to "Rainforest Gateway". Error: 'bool' object has no attribute 'close'
2013-11-13 17:01:34 Energy EAGLE Error Error in plugin execution runConcurrentThread:
2013-11-13 17:01:34 Energy EAGLE Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2013-11-13 17:01:44 Energy EAGLE Error Error connecting to "Rainforest Gateway". Error: (61, 'Connection refused')
2013-11-13 17:01:44 Energy EAGLE Error Error sending data to "Rainforest Gateway". Error: 'bool' object has no attribute 'close'
2013-11-13 17:01:44 Energy EAGLE Error Error in plugin execution runConcurrentThread:
2013-11-13 17:01:44 Energy EAGLE Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2013-11-13 17:01:59 Energy EAGLE Error Error connecting to "Rainforest Gateway". Error: timed out
2013-11-13 17:02:04 Energy EAGLE Error Error connecting to "Rainforest Gateway". Error: timed out
2013-11-13 17:02:04 Energy EAGLE Error Error sending data to "Rainforest Gateway". Error: 'bool' object has no attribute 'close'
2013-11-13 17:02:04 Energy EAGLE Error Error in plugin execution runConcurrentThread:
2013-11-13 17:02:04 Energy EAGLE Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2013-11-13 17:02:16 Energy EAGLE Error Error connecting to "Rainforest Gateway". Error: (61, 'Connection refused')
2013-11-13 17:02:16 Energy EAGLE Error Error sending data to "Rainforest Gateway". Error: 'bool' object has no attribute 'close'
2013-11-13 17:02:16 Energy EAGLE Error Error in plugin execution runConcurrentThread:
2013-11-13 17:02:16 Energy EAGLE Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2013-11-13 17:02:17 Received INSTEON "2FL Walker's Room Main Lights" on
2013-11-13 17:02:26 Energy EAGLE Error Error connecting to "Rainforest Gateway". Error: (61, 'Connection refused')
2013-11-13 17:02:26 Energy EAGLE Error Error sending data to "Rainforest Gateway". Error: 'bool' object has no attribute 'close'
2013-11-13 17:02:26 Energy EAGLE Error Error in plugin execution runConcurrentThread:
2013-11-13 17:02:26 Energy EAGLE Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2013-11-13 17:02:43 Energy EAGLE Error Error in plugin execution runConcurrentThread:
2013-11-13 17:02:43 Energy EAGLE Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2013-11-13 17:02:55 Trigger Electric Meter Message Received
2013-11-13 17:02:56 Email Sent to "alert@heintznet.com"; subject "SCE Power Meter Message Received"
2013-11-13 17:03:00 Energy EAGLE Error Error in plugin execution runConcurrentThread:
2013-11-13 17:03:00 Energy EAGLE Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2013-11-13 17:03:18 Energy EAGLE Error Error in plugin execution runConcurrentThread:
Energy EAGLE Debug logging enabled
Energy EAGLE Debug disconnect called.
Energy EAGLE Debug Data returned:
<Info>
<Text>Interval data start</Text>
</Info>
<Reading>
<Value>2.251</Value>
<TimeStamp>0x1a15bcc8</TimeStamp>
</Reading>
<Reading>
<Value>3.612</Value>
<TimeStamp>0x1a15cad8</TimeStamp>
</Reading>
<Reading>
<Value>0.965</Value>
<TimeStamp>0x1a15d8e8</TimeStamp>
</Reading>
<Reading>
<Value>1.036</Value>
<TimeStamp>0x1a15e6f8</TimeStamp>
</Reading>
<Reading>
<Value>0.950</Value>
<TimeStamp>0x1a15f508</TimeStamp>
</Reading>
<Reading>
<Value>0.652</Value>
<TimeStamp>0x1a160318</TimeStamp>
</Reading>
<Reading>
<Value>0.547</Value>
<TimeStamp>0x1a161128</TimeStamp>
</Reading>
<Reading>
<Value>0.634</Value>
<TimeStamp>0x1a161f38</TimeStamp>
</Reading>
<Reading>
<Value>0.655</Value>
<TimeStamp>0x1a162d48</TimeStamp>
</Reading>
<Reading>
<Value>0.747</Value>
<TimeStamp>0x1a163b58</TimeStamp>
</Reading>
<Reading>
<Value>2.278</Value>
<TimeStamp>0x1a164968</TimeStamp>
</Reading>
<Reading>
<Value>1.572</Value>
<TimeStamp>0x1a165778</TimeStamp>
</Reading>
<Reading>
<Value>1.202</Value>
<TimeStamp>0x1a166588</TimeStamp>
</Reading>
<Reading>
<Value>1.914</Value>
<TimeStamp>0x1a167398</TimeStamp>
</Reading>
<Reading>
<Value>1.902</Value>
<TimeStamp>0x1a1681a8</TimeStamp>
</Reading>
<Reading>
<Value>2.095</Value>
<TimeStamp>0x1a168fb8</TimeStamp>
</Reading>
<Reading>
<Value>1.082</Value>
<TimeStamp>0x1a169dc8</TimeStamp>
</Reading>
<Reading>
<Value>0.984</Value>
<TimeStamp>0x1a16abd8</TimeStamp>
</Reading>
<Reading>
<Value>1.239</Value>
<TimeStamp>0x1a16b9e8</TimeStamp>
</Reading>
<Reading>
<Value>1.557</Value>
<TimeStamp>0x1a16c7f8</TimeStamp>
</Reading>
<Reading>
<Value>1.524</Value>
<TimeStamp>0x1a16d608</TimeStamp>
</Reading>
<Reading>
<Value>1.697</Value>
<TimeStamp>0x1a16e418</TimeStamp>
</Reading>
<Reading>
<Value>2.710</Value>
<TimeStamp>0x1a16f228</TimeStamp>
</Reading>
<Reading>
<Value>2.103</Value>
<TimeStamp>0x1a170038</TimeStamp>
</Reading>
<Info>
<Text>Interval data end</Text>
</Info>
Energy EAGLE Debug Energy EAGLE version: 0.9.9.3
Energy EAGLE Debug Parsing Summation Values XML from "Rainforest Gateway".
Energy EAGLE Debug Parsed data:
<?xml version="1.0" ?>
<Data>
<Info>
<Text>
Interval data start
</Text>
</Info>
<Reading>
<Value>
2.251
</Value>
<TimeStamp>
0x1a15bcc8
</TimeStamp>
</Reading>
<Reading>
<Value>
3.612
</Value>
<TimeStamp>
0x1a15cad8
</TimeStamp>
</Reading>
<Reading>
<Value>
0.965
</Value>
<TimeStamp>
0x1a15d8e8
</TimeStamp>
</Reading>
<Reading>
<Value>
1.036
</Value>
<TimeStamp>
0x1a15e6f8
</TimeStamp>
</Reading>
<Reading>
<Value>
0.950
</Value>
<TimeStamp>
0x1a15f508
</TimeStamp>
</Reading>
<Reading>
<Value>
0.652
</Value>
<TimeStamp>
0x1a160318
</TimeStamp>
</Reading>
<Reading>
<Value>
0.547
</Value>
<TimeStamp>
0x1a161128
</TimeStamp>
</Reading>
<Reading>
<Value>
0.634
</Value>
<TimeStamp>
0x1a161f38
</TimeStamp>
</Reading>
<Reading>
<Value>
0.655
</Value>
<TimeStamp>
0x1a162d48
</TimeStamp>
</Reading>
<Reading>
<Value>
0.747
</Value>
<TimeStamp>
0x1a163b58
</TimeStamp>
</Reading>
<Reading>
<Value>
2.278
</Value>
<TimeStamp>
0x1a164968
</TimeStamp>
</Reading>
<Reading>
<Value>
1.572
</Value>
<TimeStamp>
0x1a165778
</TimeStamp>
</Reading>
<Reading>
<Value>
1.202
</Value>
<TimeStamp>
0x1a166588
</TimeStamp>
</Reading>
<Reading>
<Value>
1.914
</Value>
<TimeStamp>
0x1a167398
</TimeStamp>
</Reading>
<Reading>
<Value>
1.902
</Value>
<TimeStamp>
0x1a1681a8
</TimeStamp>
</Reading>
<Reading>
<Value>
2.095
</Value>
<TimeStamp>
0x1a168fb8
</TimeStamp>
</Reading>
<Reading>
<Value>
1.082
</Value>
<TimeStamp>
0x1a169dc8
</TimeStamp>
</Reading>
<Reading>
<Value>
0.984
</Value>
<TimeStamp>
0x1a16abd8
</TimeStamp>
</Reading>
<Reading>
<Value>
1.239
</Value>
<TimeStamp>
0x1a16b9e8
</TimeStamp>
</Reading>
<Reading>
<Value>
1.557
</Value>
<TimeStamp>
0x1a16c7f8
</TimeStamp>
</Reading>
<Reading>
<Value>
1.524
</Value>
<TimeStamp>
0x1a16d608
</TimeStamp>
</Reading>
<Reading>
<Value>
1.697
</Value>
<TimeStamp>
0x1a16e418
</TimeStamp>
</Reading>
<Reading>
<Value>
2.710
</Value>
<TimeStamp>
0x1a16f228
</TimeStamp>
</Reading>
<Reading>
<Value>
2.103
</Value>
<TimeStamp>
0x1a170038
</TimeStamp>
</Reading>
<Info>
<Text>
Interval data end
</Text>
</Info>
</Data>
Energy EAGLE Debug Parsing consumption reading 23.
Energy EAGLE Debug Unable to get "Timestamp" XML element. Error was: list index out of range
Energy EAGLE Debug Starting runConcurrentThread.
Energy EAGLE Debug eagleDeviceData called. Device: Rainforest Gateway
Energy EAGLE Debug sendCommand called.
Energy EAGLE Debug connect called.
Energy EAGLE Debug Attempt # 1 to connect to EAGLE.
Energy EAGLE Debug Sending command
<LocalCommand>
<Name>get_device_data</Name>
<MacId>0xd8d5b90000000eda</MacId>
</LocalCommand>
Energy EAGLE Debug Reading data from "Rainforest Gateway".
<NetworkInfo>
<DeviceMacId>0xd8d5b90000000eda</DeviceMacId>
<Status>Connected</Status>
<MeterMacId>0x0007810000226b9b</MeterMacId>
<ExtPanId>0x0007810000226b9b</ExtPanId>
<ShortAddr>0x00009bb4</ShortAddr>
<Channel>25</Channel>
<LinkStrength>100</LinkStrength>
</NetworkInfo>
<DeviceInfo>
<InstallCode>0x3b0d8bea7ebaab86</InstallCode>
<LinkKeyHigh>0x5fd35e4f4047e760</LinkKeyHigh>
<LinkKeyLow>0x11d856127f33456a</LinkKeyLow>
<FWVersion>1.4.29 (5423)</FWVersion>
<HWVersion>3.2.3</HWVersion>
<Manufacturer>Rainforest Automation, Inc.</Manufacturer>
<ModelId>RFA-Z109 EAGLE</ModelId>
<DateCode>20121201EC051052</DateCode>
</DeviceInfo>
<InstantaneousDemand>
<Demand>0x00000bce</Demand>
<TimeStamp>0x1a1706ce</TimeStamp>
<Multiplier>0x00000001</Multiplier>
<Divisor>0x000003e8</Divisor>
<DigitsRight>0x00000003</DigitsRight>
<DigitsLeft>0x00000006</DigitsLeft>
<SuppressLeadingZero>0x0001</SuppressLeadingZero>
</InstantaneousDemand>
<CurrentSummation>
<SummationDelivered>0x0000000002ee2c5e</SummationDelivered>
<SummationReceived>0x0000000000000000</SummationReceived>
<SuppressLeadingZero>0x01</SuppressLeadingZero>
</CurrentSummation>
<PriceCluster>
<Price>0x00000003</Price>
<Currency>0x0348</Currency>
<TrailingDigits>0x01</TrailingDigits>
<Tier>0x04</Tier>
<RateLabel>Tier 4</RateLabel>
</PriceCluster>
<MessageCluster>
<TimeStamp>0x1a1706b3</TimeStamp>
<Id>0x0004</Id>
<Text>11/12/2013-Bill to Date $160.46, Bill Forecast $245.72, Current Tier 4=$0.3/kwh</Text>
<ConfirmationRequired>Y</ConfirmationRequired>
<Confirmed>N</Confirmed>
<Read>N</Read>
<Queue>active</Queue>
</MessageCluster>
<MeterInfo>
<Type>0x0000</Type>
<Nickname></Nickname>
<Account></Account>
<Auth></Auth>
<Host></Host>
<Enabled>0x00</Enabled>
</MeterInfo>
Energy EAGLE Debug eagleDeviceData received XML from sendCommand:
Class: <type 'str'>
Data:
<Data> <NetworkInfo> <DeviceMacId>0xd8d5b90000000eda</DeviceMacId> <Status>Connected</Status> <MeterMacId>0x0007810000226b9b</MeterMacId> <ExtPanId>0x0007810000226b9b</ExtPanId> <ShortAddr>0x00009bb4</ShortAddr> <Channel>25</Channel> <LinkStrength>100</LinkStrength> </NetworkInfo> <DeviceInfo> <DeviceMacId>0xd8d5b90000000eda</DeviceMacId> <InstallCode>0x3b0d8bea7ebaab86</InstallCode> <LinkKeyHigh>0x5fd35e4f4047e760</LinkKeyHigh> <LinkKeyLow>0x11d856127f33456a</LinkKeyLow> <FWVersion>1.4.29 (5423)</FWVersion> <HWVersion>3.2.3</HWVersion> <Manufacturer>Rainforest Automation, Inc.</Manufacturer> <ModelId>RFA-Z109 EAGLE</ModelId> <DateCode>20121201EC051052</DateCode> </DeviceInfo> <InstantaneousDemand> <DeviceMacId>0xd8d5b90000000eda</DeviceMacId> <MeterMacId>0x0007810000226b9b</MeterMacId> <Demand>0x00000bce</Demand> <TimeStamp>0x1a1706ce</TimeStamp> <Multiplier>0x00000001</Multiplier> <Divisor>0x000003e8</Divisor> <DigitsRight>0x00000003</DigitsRight> <DigitsLeft>0x00000006</DigitsLeft> <SuppressLeadingZero>0x0001</SuppressLeadingZero> </InstantaneousDemand> <CurrentSummation> <DeviceMacId>0xd8d5b90000000eda</DeviceMacId> <MeterMacId>0x0007810000226b9b</MeterMacId> <SummationDelivered>0x0000000002ee2c5e</SummationDelivered> <SummationReceived>0x0000000000000000</SummationReceived> <Multiplier>0x00000001</Multiplier> <Divisor>0x000003e8</Divisor> <DigitsRight>0x00000003</DigitsRight> <DigitsLeft>0x00000006</DigitsLeft> <SuppressLeadingZero>0x01</SuppressLeadingZero> </CurrentSummation> <PriceCluster> <DeviceMacId>0xd8d5b90000000eda</DeviceMacId> <MeterMacId>0x0007810000226b9b</MeterMacId> <Price>0x00000003</Price> <Currency>0x0348</Currency> <TrailingDigits>0x01</TrailingDigits> <Tier>0x04</Tier> <RateLabel>Tier 4</RateLabel> </PriceCluster> <MessageCluster> <DeviceMacId>0xd8d5b90000000eda</DeviceMacId> <MeterMacId>0x0007810000226b9b</MeterMacId> <TimeStamp>0x1a1706b3</TimeStamp> <Id>0x0004</Id> <Text>11/12/2013-Bill to Date $160.46, Bill Forecast $245.72, Current Tier 4=$0.3/kwh</Text> <ConfirmationRequired>Y</ConfirmationRequired> <Confirmed>N</Confirmed> <Read>N</Read> <Queue>active</Queue> </MessageCluster> <MeterInfo> <DeviceMacId>0xd8d5b90000000eda</DeviceMacId> <MeterMacId>0x0007810000226b9b</MeterMacId> <Type>0x0000</Type> <Nickname></Nickname> <Account></Account> <Auth></Auth> <Host></Host> <Enabled>0x00</Enabled> </MeterInfo></Data>
Energy EAGLE Debug Parsing Device Data XML from "Rainforest Gateway".
<Data>
<NetworkInfo>
<DeviceMacId>
0xd8d5b90000000eda
</DeviceMacId>
<Status>
Connected
</Status>
<MeterMacId>
0x0007810000226b9b
</MeterMacId>
<ExtPanId>
0x0007810000226b9b
</ExtPanId>
<ShortAddr>
0x00009bb4
</ShortAddr>
<Channel>
25
</Channel>
<LinkStrength>
100
</LinkStrength>
</NetworkInfo>
<DeviceInfo>
<DeviceMacId>
0xd8d5b90000000eda
</DeviceMacId>
<InstallCode>
0x3b0d8bea7ebaab86
</InstallCode>
<LinkKeyHigh>
0x5fd35e4f4047e760
</LinkKeyHigh>
<LinkKeyLow>
0x11d856127f33456a
</LinkKeyLow>
<FWVersion>
1.4.29 (5423)
</FWVersion>
<HWVersion>
3.2.3
</HWVersion>
<Manufacturer>
</Manufacturer>
<ModelId>
RFA-Z109 EAGLE
</ModelId>
<DateCode>
20121201EC051052
</DateCode>
</DeviceInfo>
<DeviceMacId>
0xd8d5b90000000eda
</DeviceMacId>
<MeterMacId>
0x0007810000226b9b
</MeterMacId>
<Demand>
0x00000bce
</Demand>
<TimeStamp>
0x1a1706ce
</TimeStamp>
<Multiplier>
0x00000001
</Multiplier>
<Divisor>
0x000003e8
</Divisor>
<DigitsRight>
0x00000003
</DigitsRight>
<DigitsLeft>
0x00000006
</DigitsLeft>
0x0001
<CurrentSummation>
<DeviceMacId>
0xd8d5b90000000eda
</DeviceMacId>
<MeterMacId>
0x0007810000226b9b
</MeterMacId>
0x0000000002ee2c5e
<SummationReceived>
0x0000000000000000
<Multiplier>
0x00000001
</Multiplier>
<Divisor>
0x000003e8
</Divisor>
<DigitsRight>
0x00000003
</DigitsRight>
<DigitsLeft>
0x00000006
</DigitsLeft>
0x01
</CurrentSummation>
<PriceCluster>
<DeviceMacId>
0xd8d5b90000000eda
</DeviceMacId>
<MeterMacId>
0x0007810000226b9b
</MeterMacId>
<Price>
0x00000003
</Price>
<Currency>
0x0348
</Currency>
<TrailingDigits>
0x01
</TrailingDigits>
<Tier>
0x04
</Tier>
<RateLabel>
Tier 4
</RateLabel>
</PriceCluster>
<MessageCluster>
<DeviceMacId>
0xd8d5b90000000eda
</DeviceMacId>
<MeterMacId>
0x0007810000226b9b
</MeterMacId>
<TimeStamp>
0x1a1706b3
</TimeStamp>
<Id>
0x0004
</Id>
<Text>
</Text>
Y
<Confirmed>
N
</Confirmed>
<Read>
N
</Read>
<Queue>
active
</Queue>
</MessageCluster>
<MeterInfo>
<DeviceMacId>
0xd8d5b90000000eda
</DeviceMacId>
<MeterMacId>
0x0007810000226b9b
</MeterMacId>
<Type>
0x0000
</Type>
<Nickname/>
<Account/>
<Auth/>
<Host/>
<Enabled>
0x00
</Enabled>
</MeterInfo>
</Data>
Energy EAGLE Debug updateDeviceState called.
Energy EAGLE Debug eagleSummationValues called. Device: Rainforest Gateway, Summation Type: Delivered
<LocalCommand>
<Name>get_summation_values</Name>
<Interval>day</Interval>
<SummationType>Delivered</SummationType>
</LocalCommand>
<Info>
</Info>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Reading>
</Reading>
<Info>
</Info>
<Data>
<Info>
<Text>
Interval data start
</Text>
</Info>
<Reading>
<Value>
2.251
</Value>
<TimeStamp>
0x1a15bcc8
</TimeStamp>
</Reading>
<Reading>
<Value>
3.612
</Value>
<TimeStamp>
0x1a15cad8
</TimeStamp>
</Reading>
<Reading>
<Value>
0.965
</Value>
<TimeStamp>
0x1a15d8e8
</TimeStamp>
</Reading>
<Reading>
<Value>
1.036
</Value>
<TimeStamp>
0x1a15e6f8
</TimeStamp>
</Reading>
<Reading>
<Value>
0.950
</Value>
<TimeStamp>
0x1a15f508
</TimeStamp>
</Reading>
<Reading>
<Value>
0.652
</Value>
<TimeStamp>
0x1a160318
</TimeStamp>
</Reading>
<Reading>
<Value>
0.547
</Value>
<TimeStamp>
0x1a161128
</TimeStamp>
</Reading>
<Reading>
<Value>
0.634
</Value>
<TimeStamp>
0x1a161f38
</TimeStamp>
</Reading>
<Reading>
<Value>
0.655
</Value>
<TimeStamp>
0x1a162d48
</TimeStamp>
</Reading>
<Reading>
<Value>
0.747
</Value>
<TimeStamp>
0x1a163b58
</TimeStamp>
</Reading>
<Reading>
<Value>
2.278
</Value>
<TimeStamp>
0x1a164968
</TimeStamp>
</Reading>
<Reading>
<Value>
1.572
</Value>
<TimeStamp>
0x1a165778
</TimeStamp>
</Reading>
<Reading>
<Value>
1.202
</Value>
<TimeStamp>
0x1a166588
</TimeStamp>
</Reading>
<Reading>
<Value>
1.914
</Value>
<TimeStamp>
0x1a167398
</TimeStamp>
</Reading>
<Reading>
<Value>
1.902
</Value>
<TimeStamp>
0x1a1681a8
</TimeStamp>
</Reading>
<Reading>
<Value>
2.095
</Value>
<TimeStamp>
0x1a168fb8
</TimeStamp>
</Reading>
<Reading>
<Value>
1.082
</Value>
<TimeStamp>
0x1a169dc8
</TimeStamp>
</Reading>
<Reading>
<Value>
0.984
</Value>
<TimeStamp>
0x1a16abd8
</TimeStamp>
</Reading>
<Reading>
<Value>
1.239
</Value>
<TimeStamp>
0x1a16b9e8
</TimeStamp>
</Reading>
<Reading>
<Value>
1.557
</Value>
<TimeStamp>
0x1a16c7f8
</TimeStamp>
</Reading>
<Reading>
<Value>
1.524
</Value>
<TimeStamp>
0x1a16d608
</TimeStamp>
</Reading>
<Reading>
<Value>
1.697
</Value>
<TimeStamp>
0x1a16e418
</TimeStamp>
</Reading>
<Reading>
<Value>
2.710
</Value>
<TimeStamp>
0x1a16f228
</TimeStamp>
</Reading>
<Reading>
<Value>
2.103
</Value>
<TimeStamp>
0x1a170038
</TimeStamp>
</Reading>
<Info>
<Text>
Interval data end
</Text>
</Info>
</Data>
automaton wrote:They are only supposed to have upgraded those people who answered the beta invite. Guess someone forgotNathan,
You're right, they've upgraded me. I guess the Eagle "phones home"...
