- Posted on
Fri Oct 27, 2017 5:06 am
Mirko
offline
Hi Nathan,
I switched off all the Plug-inn's. Then one by one I switched them on again. Got no Announcer message.
But Announcer does not work.
I switched on the Announcer debug all in green:
Trigger Schilderatelier - Ventilator +22˚C OFF
Announcer Debug Running announce method. Data passed to the method: configured : True
delayAmount : 900
description : play a sound file and speak a message: it's less than 22 degrees celcius. turn off the ventilator, please.
deviceId : 0
pluginId : com.nathansheldon.indigoplugin.Announcer
pluginTypeId : announce
props : com.nathansheldon.indigoplugin.Announcer : (dict)
address : -system-.4551 (string)
announceAudioFile : /Users/domo/Music/Public Announcement Chime.mp3 (string)
announceVolume : 255 (string)
audioPlayer : /Applications/Play-Sound/Play Sound.app (string)
description : play a sound file and speak a message: it's less than 22 degrees Celcius. Turn off the ventilator, please. (string)
message : it's less than 22 degrees Celcius. Turn off the ventilator, please. (string)
messageFile : (string)
messageVar : (string)
rate : (string)
speechDelay : 2 (string)
speechVolume : 255 (string)
useMessageVariable : false (bool)
useSpecificApp : true (bool)
voice : -system- (string)
replaceExisting : True
textToSpeak :
Announcer Debug Announcer called from an action request.
Announcer Debug action property values assigned.
Announcer Debug Audio player /Applications/Play-Sound/Play Sound.app is running.
Announcer Debug Converting announcement audio file UNIX path to Mac HFS filesystem path.
Announcer Announcing message "it's less than 22 degrees Celcius. Turn off the ventilator, please.".
Announcer Debug Using "say" command to create message file "/tmp/1509101069.98.aif" with spoken message "it's less than 22 degrees Celcius. Turn off the ventilator, please." using voice at volume 255.
Announcer Debug Say command results: 0
Announcer Debug Telling /Applications/Play-Sound/Play Sound.app to play the file /Users/domo/Music/Public Announcement Chime.mp3.
Z-Wave received "043 - Luminance - KUBUSatelier" sensor update to 68 lux
Z-Wave received "026 - Motion Sensor 3hg BADKAMER / Battery level" status update is off
Trigger 026 - 02a Variable ON / OFF
Trigger 026 - 02a Beweging melder Bad 3 hg Lights OFF
Action Group A03 3hg Alle badkamer spots OFF
Trigger 026 - 02a Beweging melder Bad 3 hg Lights OFF WTW stand 2
Z-Wave received "074 - Temperature - KUBUS bij raamwerkbank" sensor update to 21.4 °C
Z-Wave received "074 - Humidity - KUBUS bij raamwerkbank" sensor update to 49%
Sent X10 "H11 Badkamer 3 spots" off
Trigger H11 - OFF >> Variable > OFF
Schedule 026 - 02a Beweging melder Bad 3 hg Lights OFF (delayed action)
Z-Wave received "074 - Luminance - KUBUS bij raamwerkbank" sensor update to 50 lux
Z-Wave received "074 - Ultraviolet - KUBUS bij raamwerkbank" sensor update to 0
Sent X10 "H01 Badkamer spot boven wastafel" off
Sent X10 "H13 Badkamer Wastafel Spiegel Kast" off
Schedule Schilderatelier - Ventilator +22˚C OFF (delayed action)
Sent X10 "B04 ATELIER-Ventilator" off
Z-Wave received "025 - Luminance 3hg GORDIJNEN ACHTER" sensor update to 1607 lux
Trigger D17 - Timer 37 min >> into Variable >> TimerBath_3hg_licht37min
Z-Wave received "017 - Motion Sensor 3hg Trap / Battery level" status update is off
Trigger 017 Motion Sensor Trap 3hg Licht OFF
Z-Wave sent "018 - Wall Plug Relay (FGWP101) Lamp Bekeken Jo Klaps" off
Cynical Calendars dispatching end event Sonia 11:00 uur
Cynical Calendars iCal Indigo B01 On/Off checking match for Sonia 11:00 uur
Z-Wave received "011 - Luminance Trap 1hg" sensor update to 86 lux
Trigger 011 Motion Sensor Trap 1 hg Zwave - STAIRCASE - Variable LUMEN
Z-Wave received "017 - Luminance Trap 3hg " sensor update to 11 lux
Trigger 017 Motion Sensor Trap 3 hg Zwave - STAIRCASE - Variable LUMEN
Z-Wave received "071 - 3 hoog Raam Straatzijde Temperature" sensor update to 30.8 °C
Z-Wave received "071 - 3 hoog Raam Straatzijde Humidity" sensor update to 32%
Z-Wave received "071 - 3 hoog Raam Straatzijde Luminance" sensor update to 280 lux
Z-Wave received "071 - 3 hoog Raam Straatzijde Ultraviolet" sensor update to 0
Z-Wave received "037 - Luminance Talud UP" sensor update to 59 lux
Schedule 007 Motion Sensor BG 119A Light OFF (delayed action)
Z-Wave received "055 - Badkuip 3 hoog Luminance" sensor update to 7 lux
Sent X10 "A09 Verlichting BG achter VoorDeur 119A" off
Z-Wave received "012 - Luminance Trap 2hg" sensor update to 123 lux
Z-Wave received "091 - Tilt/Tamper AMO bed voor nachtlicht LINKS" status update is off
Z-Wave received "091 - Motion Sensor AMO bed voor nachtlicht LINKS" status update is off
Z-Wave received "026 - Luminance 3hg BADKAMER" sensor update to 6 lux
Sent X10 "A08 BG licht HAVIK" off
Z-Wave received "033 - Luminance Kubus Kantoor" sensor update to 8 lux
Z-Wave received "007 - Luminance Begane Grond 119A" sensor update to 18 lux
Trigger 007 Motion Sensor Trap BG Zwave - STAIRCASE - Variable LUMEN
Z-Wave received "035 - Luminance 2hg Kleding" sensor update to 5 lux
Z-Wave received "075 - 2 hoog Raam Straatzijde Temperature" sensor update to 26.1 °C
Z-Wave received "075 - 2 hoog Raam Straatzijde Humidity" sensor update to 43%
Z-Wave received "075 - 2 hoog Raam Straatzijde Luminance" sensor update to 1474 lux
Z-Wave received "075 - 2 hoog Raam Straatzijde Ultraviolet" sensor update to 0
Z-Wave received "076 - 1 hoog Raam Straatzijde Temperature" sensor update to 24.7 °C
Z-Wave received "076 - 1 hoog Raam Straatzijde Humidity" sensor update to 41%
Z-Wave received "076 - 1 hoog Raam Straatzijde Luminance" sensor update to 255 lux
Z-Wave received "076 - 1 hoog Raam Straatzijde Ultraviolet" sensor update to 0
Z-Wave received "089 - Luminance VSE Talud" sensor update to 42 lux
27 Oct 2017, 12:46:28
Z-Wave received "073 - TH boven aanrecht Temperature" sensor update to 22.1 °C
Z-Wave received "073 - TH boven aanrecht Humidity" sensor update to 47%
Z-Wave received "073 - TH boven aanrecht Luminance" sensor update to 4 lux
Z-Wave received "073 - TH boven aanrecht Ultraviolet" sensor update to 0
Announcer Error Error in plugin execution ExecuteAction:
File "plugin.py", line 885, in announce
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/appscript/reference.py", line 577, in __getattr__
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/appscript/reference.py", line 259, in referencebyname
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/appscript/reference.py", line 228, in connect
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/appscript/terminology.py", line 168, in tablesforapp
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/appscript/terminology.py", line 140, in aetesforapp
RuntimeError: Can't get terminology for application (aem.Application(u'/Applications/Play-Sound/Play Sound.app')): Command failed: Apple event timed out. (-1712)
Weather Conditions Retrieving Weather Condition Information from Weather Underground
Z-Wave received "043 - Luminance - KUBUSatelier" sensor update to 72 lux
Weather Conditions Data retrieved from Weather Underground, and Saved.
Z-Wave received "035 - Tilt/Tamper 2hg Kleding" status update is off
Z-Wave received "035 - Motion Sensor - 2hg Kleding / Battery level" status update is off
Trigger 035 - Kleding 2 hoog Motion light OFF
Action Group A02 - 2hg LED Kledingkasten WARM white OFF
Action Group A02 - 2hg LED Kledingkasten AMBER OFF
Z-Wave sent "015 - Composite 2 hg LED Links kledingkast" set color to 0 0 0, 100
Z-Wave sent "015 - Composite 2 hg LED Links kledingkast" off
Sent Hue Lights "Hue light STRIP - 2hg Schoenenkast" off at ramp rate 0.0 sec.
Z-Wave sent "016 - Composite 2 hg LED Rechts Kledingkast" set color to 0 0 0, 100
Z-Wave sent "016 - Composite 2 hg LED Rechts Kledingkast" off
Z-Wave sent "015 - Composite 2 hg LED Links kledingkast" set color to 73 11 0, 0
Z-Wave sent "016 - Composite 2 hg LED Rechts Kledingkast" set color to 73 11 0, 0
Z-Wave received "074 - Luminance - KUBUS bij raamwerkbank" sensor update to 53 lux
Z-Wave received "008 - Temperature 1 Tuin Vijver" sensor update to 20.62 °C
Z-Wave received "025 - Luminance 3hg GORDIJNEN ACHTER" sensor update to 1710 lux
Z-Wave received "011 - Luminance Trap 1hg" sensor update to 87 lux
Schedule Heater Schildpadden 12 uur (delayed action)
Sent X10 "F08 TUIN-Turtle Heater" off
Trigger F08 Heater Schildpadden OFF
Z-Wave received "033 - Temperature Kubus Kantoor" sensor update to 22.1 °C
