UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2
Thu Apr 19, 2018 11:36 am
Jann offline
Re: UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2
I have a many Hue device types (i think 5 or 6...)
I'll change them all...
Thu Apr 19, 2018 11:52 am
Jann offline
Well, SHOOT!
It didn't work. Indigo still complaining. This one is different tho...
I changed the name of the Hue device to have the smart apostrophe, made the changes to all the debug lines in the python script, rebooted the server (for good measure) Then - for funsies - I just went to that device in indigo and hit "Send Status Request," the following happened:
 Hue Lights Error                Error in plugin execution ExecuteAction:
  File "plugin.py", line 3443, in actionControlDimmerRelay
  File "plugin.py", line 4784, in getBulbStatus
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2 in position 176: ordinal not in range(128)
Line 4784 is one of the 8 or so lines I changed to:
self.debugLog(u"Data from hub: {}".format(r.content))
Are we sure that's the line to use?
(ps: it STILL has the same problem assigning a NEW indigo device to a Hue device with an apostrophe.)
Thu Apr 19, 2018 11:54 am
FlyingDiver online
Since those are just debug logging lines, you could just comment them out and see if it works.
# self.debugLog(u"Data from hub: {}".format(r.content))
Thu Apr 19, 2018 11:57 am
Colorado4Wheeler offline
You could try opening it up in TextWrangler and doing a replace all:
replace self.debugLog with # self.debugLog
Thu Apr 19, 2018 11:58 am
Jann offline
Duh! (that "Duh" was for ME not YOU! Sorry....)
I'm a programmer and didn't think of this. I am just not a PYTHON programmer. BTW: what is the best way to restart after changing the python plugin? I rebooted the mini to make sure but Plug ins->Hue Lights->reload didn't seem to load the newly changed python script?
Thanks for ALL your help!
Jann
Thu Apr 19, 2018 12:01 pm
FlyingDiver online
It should, if you're actually editing the correct files. That's what I do 99% of the time while working on a plugin. Just do a restart on the plugin.
Thu Apr 19, 2018 12:09 pm
Jann offline
FINALLY!
The "commenting out" worked...
As did the "reload" of the plug-in. I just hadn't waited for the important thing upon reload...the plugin stops, starts and UNTIL it gets the JSON from the hue hub it doesn't get the "changed" name of the hue light... so I was trying to do things too fast.
Oh, well. I hope this gets fixed in the regular release...cos commenting out debug lines isn't the best fix.
Thanks for all the help!
Jann
Thu Apr 19, 2018 2:22 pm
nsheldon offline
In order for me to fix the debug lines, I need to be able to test this error condition, so it’d be gelpful to see the actual data coming from the Hue hub. Hard to get that if the debug lines are commented out though. Haha.
Thu Apr 19, 2018 2:56 pm
FlyingDiver online
Can you rename one of your devices with a unicode character in it? And maybe try some variants on the string conversion, like using:
print(u"Something interesting: {0}".format(some_var.decode('utf-8')))
Thu Apr 19, 2018 3:09 pm
nsheldon offline
Yea. I’ll try that. That should be a good enough test. It’ll probably take me a bit to get a fix out.
Thu Apr 19, 2018 3:12 pm
FlyingDiver online
I would also recommend doing the debug statement on the resulting JSON data, not the raw data from the request. That would probably eliminate the error totally, as the JSON conversion should correctly identify the strings as unicode.
Thu Apr 19, 2018 3:51 pm
nsheldon offline
Thanks for the recommendation.
