{"error":{"code":404,"message":"method not found"}} message
Sun Sep 18, 2022 6:01 am
erikwegman offline
When I start Indigo with plugin installed it tries to contact the dev.netatmo.com site for registration. After login the {"error":{"code":404,"message":"method not found"}} message appears and nothing happens. Obviously the weather station is not registrated so no measurements are coming in...
What it going on? I know for sure that the client ID and client secret secret are correct, as well as the login credentials
Erik
Tue Sep 20, 2022 10:03 am
racarter offline
Re: {"error":{"code":404,"message":"method not found"}} mess
Do you have an up to date reflector account? Have you entered your REST API key?
If so, and you’re still having problems contact me via my support page for further assistance and a faster response.
It would be useful to see what's in the event log too.
Thu Nov 10, 2022 4:51 pm
jaknudsen offline
Did this get resolved? I'm experiencing the same issue.
Fri Nov 11, 2022 12:20 am
racarter offline
I had no further contact from the OP so I don't know. See my previous response for things to check, and how to proceed.
Fri Nov 11, 2022 1:42 am
jaknudsen offline
Thanks. Is it true that I need to set up an Indigo reflector for this plugin to work? When did this change occur? I've never had one before, and I've used this plugin for years.
Fri Nov 11, 2022 1:49 am
racarter offline
Unfortunately it's required because Netatmo have changed the authentication method for users. The only way to implement the new authentication method in the plugin necessitated the use of a reflector. This is mentioned clearly in the release notes.
The only alternative would be to withdraw the plugin.
Sun Nov 13, 2022 4:38 am
jaknudsen offline
Setting up a reflector worked. Thanks, and thanks for the effort in developing the plugin!
Sun Nov 13, 2022 5:47 am
racarter offline
Glad to hear you got it working :)
