Noticed this evening that one of my thermostats didn't get set correctly. Found the following in the log.
- Code: Select all
5 Jan 2021 at 18:00:00
Schedule Winter_Even_Up_18:00
Heatmiser-Neo Error {"SET_TEMP":[19.0, "Master"]}
Heatmiser-Neo Error Invalid second argument to SET_TEMP, should be a valid device or array of valid devices
Then slightly later for a time delayed action of same schedule:
- Code: Select all
File "plugin.py", line 523, in actionControlThermostat
File "plugin.py", line 295, in getNeoData
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/__init__.py", line 338, in loads
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/decoder.py", line 366, in decode
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/decoder.py", line 384, in raw_decode
ValueError: No JSON object could be decoded
Heatmiser-Neo Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 88, in runConcurrentThread
File "plugin.py", line 186, in updateReadings
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/decoder.py", line 382, in raw_decode
ValueError: Expecting , delimiter: line 1 column 5761 (char 5760)
Heatmiser-Neo Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Heatmiser-Neo Starting Heatmiser Neo monitoring thread
The schedule runs fine now if I manually execute it.
Rgds
Colly
