"send status request" from web browser interface?
Fri Sep 07, 2012 7:21 am
nexx offline
My application integrates with indigo through the 8176 http port interface.
Is it possible to "send status request" from this interface? how?
thanks,
Valentino
Fri Sep 07, 2012 7:36 am
Re: "send status request" from web browser interface?
Hi Valentino,
There isn't a direct restful API to send a status request, so I believe you'll have to create an Action Group that does the request(s) you want and then execute that group via the restful API.
Fri Sep 07, 2012 11:20 am
nexx offline
Ohh, too bad. I have like 50 or more appliances.. need something more generic..
It seems its possible through Applescript, isn't? "status request <device>" but I didn't figured it out how to save the request into a ascript variable...
Can I do it through the "insteonhost -i"?
Fri Sep 07, 2012 11:35 am
Note that you shouldn't need to send status requests under normal circumstances - so if you find yourself needing to do status requests frequently then you might want to find out why devices are out of sync and fix that problem rather than just addressing the symptom...
I'm not quite sure what your AppleScript question is and how it relates to the RESTful API.
Fri Sep 07, 2012 1:16 pm
johnpolasek offline
I do it from a script for a light and a lamp that are in a bedroom at the end of a long wiring run and sometimes accessed from a palmpad and X10 reciever; The switchlinc and appliancelinc that are controlling these lights are "dual coded", insteon as well as X10 (L10 and L11); Indigo and the two keypadlincs that also control them use Insteon to reach them, but the X10 reciever on a plug on the same breaker as the two devices is too weak to signal back to the Mac, so if the palmpad on the bedstand is used, INdig doesn't know that the device changed until it asks (once a minute on a schedule). Sure, I COULD get a remotelinc and dual band device to hang out there, but as long as the kludge works, why add the expense? Of course if the Insteon devices were programmed PROPERLY, they would broadcast their state change from X10 just like the switchlinc does from someone hitting the paddle, but that's a gripe for Smarthome... And I also do a request on the Garage door open IOlinc in the same schedule because every once a while; signal noise or maybe just confusion in the device, it fails to send a state change when I close the door, which means I make a trip to the garage for nothing after checking before bed.
Fri Sep 07, 2012 1:38 pm
You can use the indigohost command line with the embedded option:
indigohost -e "indigo.device.statusRequest(79187544)"
It is not super efficient since it starts a new process that has to connect to the IndigoServer, but it still might be an acceptable technique.
Fri Sep 07, 2012 2:16 pm
[SNIP]
Which is basically my point to the OP - for a few specific scenarios like this creating an action group is an acceptable for occasional use. However, if you have 50 devices that are getting out of sync regularly then it's a completely different problem...
Fri Sep 07, 2012 7:40 pm
nexx offline
There's no problem in my network. Devices get out of sync simply because my mac is not on 24x7. For example, if the mac is sleeping, and you turn on a light from a keypadlinc, it will be out of sync when the mac resumes..
I was trying to asking if it is possible to send and get "status request" from the IndigoServer applescript interface? Would somebody please post a sample code? I think it may be faster than spawning an indigohost shell.
thanks
Fri Sep 07, 2012 7:42 pm
nexx offline
Thanks, what this number ("79187544") stand for?
Fri Sep 07, 2012 7:51 pm
The number is the unique device ID. You can get it by right-clicking on the Device in the main window. The device name will work as well (put it in quotes), but the ID is preferred since it never changes.
To do it from AppleScript try:
 status request "device name here"
(note that AppleScript only accepts the device name -- the ID won't work there)
Sat Sep 08, 2012 4:28 am
nexx offline
Ok Thanks, one last question, do this code returns anything (for error checking)?
Sat Sep 08, 2012 5:31 am
nexx offline
Thanks, Jay, Matt!
Here's the solution:
osascript -e 'tell application "IndigoServer" to status request "office-window"'
It is much faster than launching a "indigohost" process.
Sun Sep 09, 2012 8:44 am
The command is queued up to be sent by the interface then returns immediately, so no return status is available.
Sat Dec 01, 2012 11:37 am
jabeard3 offline
Jay -
Assuming my mac is on all the time, why would I have discrepancies? It's specifically outdoor appliance linc's that have been out of sync, they are only ever controlled by Indigo and while they haven't been out of sync often... I'm wondering why they were out at all.
Sat Dec 01, 2012 11:48 am
Signal noise is the likely culprit - Indigo will send it a command but the device won't respond with an acknowledgement because of a signal issue. The device may have responded, but Indigo won't know because it didn't receive the ACK. You may see those errors in the event log saying "no acknowledgement".
Check out the signal troubleshooting page for common causes and solutions to signal issues.
