Disable FanLinc LEDs?
Thu Jul 11, 2013 12:21 pm
Re: Disable FanLinc LEDs?
Probably won't get to it. But, since you can use the Send Raw to do it you can just do it that way.
Wed Jul 06, 2016 12:14 am
akimball offline
I just used the raw command on seven installed FanLincs... bought since then end of 2012. Extended command worked on all 7. Would love to see this (on/off) in the Indigo FanLinc device itself if you ever get a wild hair. For now I just set it up as "contingent" action which I can select the fanlinc just prior to execution. 5 of my 7 fans, the LED's were brightly visible... cool effect, until I had a guest complain of the red light. :)
I know... I know you're busy, and yes... I appreciate all you do more than you know. Thanks :)
-Al
Wed Jul 06, 2016 5:29 am
eme jota ce offline
This is great. Thanks for the commands.
I didn't bother to search the forum to check my memory, but seem to remember a similar discussion about these lights with the fanlincs were originally released. The solution then ... electrical tape (black). :shock:
