Email Scan Authentication Failed
Fri Sep 17, 2010 11:53 am
alangraham999 offline
I finally gave Indigo it's own dedicated email address...put in the proper .me pop info and no matter what settings I give it I get the same error...even though this worked before on my main .me mail account. Any thoughts?
Sat Sep 18, 2010 3:42 pm
Re: Email Scan Authentication Failed
Are you seeing the error when trying to send emails or scan them? Can you copy/paste the error you see?
Tue Oct 05, 2010 4:55 pm
Error email scan authentication failed
That's what I get constantly...no matter what settings I give it.
Tue Oct 05, 2010 6:52 pm
What exact settings are you using in the Indigo prefs dialog (except user name and password, of course)?
Tue Oct 05, 2010 7:25 pm
POP Server:
mail.me.com
Port
995
Use SSL
POP Username ********@me.com
Check Every 1 minute
Delete From Server
Tue Oct 05, 2010 7:37 pm
The user name should be everything to the left of the @ character (not the full email address).
If it still doesn't work, then have you put in a ticket with MobileMe to enable POP access?
http://support.apple.com/kb/HT2138
By default they have it disabled for all accounts created after 7/10/2008.
Thu Apr 12, 2012 8:15 am
jtm997 offline
I think this thread is about the same problem I am having. here is what I am doing
I am running on a MAC mini with Lion.
plug-ins:
Action Collection
Cynical SecuritySpy
DigiTemp
GoggleVoice SMS
NOAA Weather
WeatherSnoop
I get this error message about every 10 minutes.
Apr 12, 2012 8:11:45 AM
Any idea where I should go to correct the issue? most likely a password issue I think.
Thu Apr 12, 2012 8:19 am
What email provider are you using? Apple's iCloud?
If so, that is the problem. iCloud no longer supports POP (just IMAP) and Indigo's email scanning client requires POP. Lots of Indigo users create dedicated gmail accounts, since that is free and works well.
Thu Apr 12, 2012 8:46 am
jtm997 offline
I would like to use my Gmail. But i am sure of the settings.
Preferences ask for a POP server. How do I know what goes into each box?
What is the correct SMTP Server, Port, and do I check IUse SSL(TLS)
And thanks for your help!
Thu Apr 12, 2012 8:52 am
jtm997 offline
Another quick question.
Should the email address in Preferences be my email address or the address that I have set up in gmail that is used in GoogleVoice SMS?
Thu Apr 12, 2012 9:00 am
First, enable GMail POP:
http://support.google.com/mail/bin/answ ... swer=13273
And here are GMail's settings:
http://support.google.com/mail/bin/answ ... swer=13287
The email address needs to be that of your GMail account, otherwise the GMail server will reject it.
Thu Apr 12, 2012 11:37 am
jtm997 offline
That answered a lot of questions. Thanks very much. I have no errors!!
