I have been using X10 for years; I installed Indigo when I got my Mac, but continued to run just X10 on a CM15A. I decided to expand with some Insteon devices, so I got a 2413U. I downloaded the drivers and all worked well while controlling X10 only. I installed my first Insteon device and paired it flawlessly. Then I started building trigger actions and deleting all the preconfigured devices that come with Indigo and then things stopped working and reinstalling hasn't helped.
As I have tried to troubleshoot, things have just gotten worse. At times, when I tried to perform different actions, I would have PowerLinc messages displayed such as "saving database" that would stay forever without changing. or "disconnecting server..." Signals were not being sent and the program would freeze until it gave up trying to complete an action. I have checked the firewall. I have deleted p-list files. I have rebooted.
This is all running on a MacMini, OS 10.6.4. I have Indigo client and server versions 4.1.10. I have selected Interface PowerLinc Modem 2412U/etc. and serial port usbserial-A6008aza. I have the 2413U plugged in away from the computer (in the same place as when it was working) and I have switched to an alternate USB; the USB is directly connected to the MacMini and I have even swapped USB ports with no success. I autostart the server, but not the client application
The current state of affairs is that the connection to the server never occurs. Sometimes when I start the program everything seems fine. The "Server Connection Status" box pops up briefly and disappears and the main window of the program opens, but the PowerLinc Modem appears in RED. If I try to turn on an X10 device, I get a teal blip move to the middle of the PowerLinc Modem status line and stops. Nothing happens with the device. Each time you resend the request, another teal blip adds to the party, but nothing happens. If you go to the Interface menu option, you see that the CONNECT is not active. If you click on connect, you get a message above the PowerLinc Modem activity bar that says "Disconnectng interfaces…" and if you go back into Interface, the Connect button is still active. At this point everything becomes sluggish. It takes about 15 seconds of wheel spinning to access any menu options and each time the Console posts a new entry of the message: "syncScriptMenu() caught exception: ServerCommunicationError -- timeout waiting for server response." I cannot open the Event log in this state.
If I choose the menu option to Stop Server, nothing happens right away, but eventually (5 minutes) an Indigo message box appears that says "Failed to stop Indigo Server -- Make sure you are running the client under the same user account in which the server was started." I only have one Administrator privileged user account. Clearing that message reveals the Server Connection Status window is still displaying that it is "Establishing connection with the Indigo Server…" I have since explicitly added Read Write permissions for the Admin User name for the Indigo server.
At this point, if you try to Restart the computer using the Apple|Restart command, you get a message that logging out of Indigo was unsuccessful and to quit the program and try again. But, by now, it is impossible to get Indigo to become the active menu bar. Also, choosing quit from the program icon on the bottom menu bar does nothing. I can get into the program if I FORCE QUIT the Indigo Server from the Activity Monitor. BTW, when I am able to access the main program and I delete some of the preconfigured devices, there is never a save to the database.
Either the 2413U modem is bad or i need to remove everything and start over. It would be nice if there were a sticky posting with instructions on how to wipe all traces and start over.
[url][/url]
