Having trouble controlling Phidgets 1017
Tue Nov 19, 2013 4:32 pm
automatr offline
Just purchased a Phidgets SBC3 and 1017 to replace my EasyDAQ EasyDAQ NET16PRMx because of problems communicating with that device. (I have three of these if anyone is interested in them). So far no problems communicating with the SBC and analog sensors, but I'm having some trouble with an attached 1017 Relay Card. I can control the relays of the 1017 with no problem from the Phidgets System Preferences window. I can define the 1017 as a device in Indigo, and it reports that it is online.
Phidgets 1.jpg (48.97 KiB) Viewed 1159 times
Where I am running into trouble is actually being able to access the relays on the 1017 through Indigo. Perhaps I'm doing something wrong? As an example, if I try to make an Action Group, New>Device Actions>Phidgets Control, The option that seems to fit this task is "Control A Interface Kit Digital Output Device", yes?
Phidgets 2.jpg (131.15 KiB) Viewed 1159 times
If I then select Edit Action Settings>Select Phidget, the drop down menu is empty.
Phidgets 3.jpg (88.6 KiB) Viewed 1159 times
So I am stuck at this point. Am I doing something wrong?
automatr / Jeff
Tue Nov 19, 2013 8:00 pm
automatr offline
Found it, never mind ...
After poking around for a while, I figure it out. It was pretty obvious, now I feel kinda dumb!
Tue Nov 19, 2013 8:19 pm
berkinet offline
Re: Having trouble controlling Phidgets 1017
You aren't the first. :wink:
For anyone wondering what the 'fix' is: Phidget interfaceKit outputs need to be created as separate devices and are turned in/off like any light or appliance.
