Indigo an EZX10RF interface
Tue Nov 12, 2013 8:31 am
rob_hut offline
This question has been touched on here:
viewtopic.php?f=3&t=2650&p=71604&hilit=EZX10RF#p71604
However the info seems a little out of date. Now there is a newr USB interface (2413U).
Is the EZX10RF any easier to use now? Can it be used in conjunction with the 2413U?
One solution offered on the thread above is that I plug the EZX10RF into the X10 interface, but the 2413U has no pass thru.
One answer is that I upgrade all my components to Insteon, but that would cost about $450 dollars as opposed to $120 for the interface.
Any advice or empirical knowledge would be great!
Cheers,
Bo
EZX10RF
http://www.smarthome.com/31276/Smarteni ... ver/p.aspx
Tue Nov 12, 2013 10:50 am
Re: Indigo an EZX10RF interface
The process is the same with the 2413U. You can plug them both into the same power strip since the 2413U doesn't have the pass-through.
My recommendation: If you are looking to get X10 RF commands (from X10 motion sensors, etc.) into Indigo then I recommend the W800. I have one and they work great, and they are very fast since it is all RF and needs no power line commands.
Tue Nov 12, 2013 11:08 am
rob_hut offline
This was exactly what I was looking for! Thanks so much. Im saving $20 by ordering from machomestore as well!
Thanks for being an awesome X10/Insteon champion!
Bo :D
