Getting Enable/Disable State of a Schedule
Sat Nov 09, 2013 1:48 pm
sumocomputers offline
My end goal is that I want to get the Enable/Disable state of a given schedule, and then in a control page, present a different icon for each state.
I could not see a way to do it natively with built in logic, and so I looked into using variables, but I can not see a way to obtain the Enable/Disable state of a schedule and pass it to the variable.
Is there a way to get this info and have it display the state or change graphics on a control page?
Chris
Mon Nov 11, 2013 5:21 am
Re: Getting Enable/Disable State of a Schedule
Here's a Python script suggestion:
scheduleState = indigo.schedules[scheduleID or "scheduleName"].enabled
then set the variable by:
indigo.variable.updateValue(indigo.variables.getId("variable_name"), str(scheduleState))
or
indigo.variable.updateValue(indigo.variables.[variableId], str(scheduleState))
The variable will then be set to True or False depending whether the schedule is enabled or not :)
Mon Nov 11, 2013 10:45 am
or
I appreciate the help with the Python script.
So using your code I have made another schedule that runs the following every 30 seconds, which seems to retrieve and properly update the variable:
scheduleState = indigo.schedules[917345397].enabled
indigo.variable.updateValue(indigo.variables.getId("garageRollupMonitorIsActive"), str(scheduleState))
On a control page, I figured out how to display the value of a variable in the form of text, so it shows either True or False, but it is text only.
I need a little more help as to how to display 2 different graphics on a control page based on a variable value (like green dot for true, red dot for false). Is this possible? I don't see an obvious way to do this using the Indigo Control Page editor.
Chris
Mon Nov 11, 2013 11:00 am
sumocomputers wrote:
[... I need a little more help as to how to display 2 different graphics on a control page based on a variable value (like green dot for true, red dot for false). Is this possible? I don't see an obvious way to do this using the Indigo Control Page editor. ...
I haven't tried this myself yet but I think you need to look at the Custom Images on Control Pages wiki article. I think this will enable you to do what you want :)
Mon Nov 11, 2013 11:03 am
Alright, thanks for the article, I will give it a go!
Tue Apr 15, 2014 8:57 am
SgtBilko offline
Can a schedule be enabled / disabled from a Python script ? I can't find a way of doing this via introspection.
Thank you
Tue Apr 15, 2014 9:53 am
Not documented AFAIK but the following seems to work :)
To enable:
indigo.schedule.enable(deviceId,value=True)
To disable:
indigo.schedule.enable(deviceId,value=False)
Tue Apr 15, 2014 9:55 am
SgtBilko offline
I thought it might be someting like that
Thank you very much, I appreciate your help
Ian
