variable name with a "."
Sat Nov 09, 2013 12:35 am
a program can create a variable with a name that includes a "." (e.g. ipNumber-192.168.1.1)
When I want to do this manually or want to edit one that contains a "." Indigo does not allow that.
Is that observation correct?
If so, should "." be avoided in a variable name: any situation where that creates a problem in indigo?
Sat Nov 09, 2013 9:26 am
Re: variable name with a "."
Hi Karl,
Correct, it looks like the UI edit field input filter we are using is more restrictive than the checking we do on the scripting side. I cannot think of anything that the "." character would break, so assuming you can live with the UI discrepancy I think it will be okay.
Users browsing this forum: No registered users and 21 guests
