koubachi plugin error
Thu Nov 07, 2013 11:54 am
gbiski offline
Dan hello,
I am using the koubachi plugin and sudently i' am receiving the following error:
Reloading plugin "Koubachi 1.0.83"
Stopping plugin "Koubachi 1.0.83" (pid 7392)
Stopped plugin "Koubachi 1.0.83"
Starting plugin "Koubachi 1.0.83" (pid 10057)
Koubachi Error HTTP Error invoking Koubachi API: HTTP Error 406: Not Acceptable
Koubachi Error Unable to load devices.
Started plugin "Koubachi 1.0.83"
Koubachi Error exception in deviceStartComm(Koubachi Sensor): u'000666800a05'
I reloaded the plugin and reinstalled it but with no success.
Any idea?
thanks
George
Tue Apr 29, 2014 7:39 am
dhughes offline
Re: koubachi plugin error
Sorry for the delay in responding - I haven't been on the boards in a while!
It is sprinkler season here now so I will make sure the plugin works and repost.
Tue Jul 08, 2014 3:01 pm
PME999 offline
Hello,
I have the same problem.
Is it a problem in the adress HTTP format ?
here in the API page of Koubachi : https://api.koubachi.com/v2/plants.json ... pp_key=xxx
instead of
http://api.koubachi.com/v2/user/smart_d ... pp_key=xxx
but I don't know how to change it to try.
Thanks for your reply
Patrice
Wed Jun 10, 2015 3:56 pm
superholz offline
did anyone fix the plugin yet or built another to use the Koubachi plant sensors?
Fri Jun 10, 2016 8:52 pm
lrego offline
Same..here...noticed also the plugin using a older URL as stated above. Anyone got it fixed? Dan? THANKS
Tue Nov 07, 2017 8:40 am
dhughes offline
Hi All.
Sorry for the looooong dark period. I got busy on other things and haven't been paying attention here for quite some time.
I notice that through a merger, support for this device seems to have been dropped.
Let me know if you are still using it and I will find some time to see if there is a quick fix here.
Regards
Dan
Sat Nov 11, 2017 4:00 pm
superholz offline
Yes still using it, but I think next year the api anyhow will change or will be removed doe to the merge with Gardena. So a very simple fix would be greate but otherwise not worth fixing. I wonder if it would be possible to get data from the sensor directly without using the cloud API from Koubachi.
Gesendet von iPad mit Tapatalk
Users browsing this forum: No registered users and 31 guests
