Aeon Home Energy Monitor
Thu Oct 17, 2013 7:01 am
jeremyjjr offline
I've just installed an Aeon Home Energy Monitor and with a couple of logging scripts have it up and running perfectly. Am able to show cost per day, week, month and will shortly be implementing usage graphs as well.
However, whenever the sensor connects with an update, I receive the following error in the Indigo log ...
Error                           device "Sensor - Energy Monitor" state key onOffState not defined (ignoring update request)
Any ideas what this refers to and how I can clean it up?
J.
Thu Oct 17, 2013 7:17 am
Re: Aeon Home Energy Monitor
Hi Jeremy,
Turn on debug logging (checkbox available via Interfaces->Z-Wave->Configure... dialog), then once the error occurs copy/paste the Event Log results into a reply for me. Include a couple of minutes before/after the error in the copy/paste.
Also, inside the Device dialog press the Edit Device Settings... button, then the Write to Log button and include that as well.
Thu Oct 17, 2013 7:32 am
jeremyjjr offline
Hi Matt,
Debug log below:
Z-Wave Debug                    starting node status polling
  Z-Wave Debug                    RCVD requestBatteryLevel: 01 09 00 04 00 08 03 80 03 64 1E
  Z-Wave Debug                    . .  requestBatteryLevel: node 008, level 100
  Z-Wave Debug                    received "008 - Sensor - Energy Monitor" status update battery level 100%
  Z-Wave Debug                    RCVD requestVarSensorStatus: 01 0E 00 04 00 08 08 31 05 04 64 00 05 45 74 95
  Z-Wave Debug                    . .  requestVarSensorStatus: node 008, endpoint None, type 4, raw value 6400...
  Z-Wave Debug                    . .  requestVarSensorStatus: 345.460 W (float: 345.460000)
  Z-Wave Debug                    received "Sensor - Energy Monitor" sensor update to 345.460 W
  Z-Wave Debug                    received "Sensor - Energy Monitor" status update is on
  Z-Wave Debug                    RCVD multiEndPointPacket: 01 18 00 04 00 08 12 60 0D 01 00 32 02 21 74 00 05 45 74 00 00 00 00 00 00 C4
  Z-Wave Debug                    . .  multiEndPointPacket: node 008, endPoint 1
  Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 08 0E 32 02 21 74 00 05 45 74 00 00 00 00 00 00 FF
  Z-Wave Debug                    . .  requestMeterLevel: node 008, endpoint 1, meterType 01, raw value 7400...
  Z-Wave Debug                    . .  requestMeterLevel: 345.460 W (float: 345.460000)
  Z-Wave Debug                    received "Sensor - Energy Monitor - Clamp 1" power load to 345.460 W
  Z-Wave Debug                    RCVD multiEndPointPacket: 01 18 00 04 00 08 12 60 0D 02 00 32 02 21 74 00 00 00 00 00 00 00 00 00 00 F3
  Z-Wave Debug                    . .  multiEndPointPacket: node 008, endPoint 2
  Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 08 0E 32 02 21 74 00 00 00 00 00 00 00 00 00 00 FF
  Z-Wave Debug                    . .  requestMeterLevel: node 008, endpoint 2, meterType 01, raw value 7400...
  Z-Wave Debug                    . .  requestMeterLevel: 0.000 W (float: 0.000000)
  Z-Wave Debug                    RCVD multiEndPointPacket: 01 18 00 04 00 08 12 60 0D 01 00 32 02 21 64 00 00 0A 4B 00 78 00 00 0A 0B D8
  Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 08 0E 32 02 21 64 00 00 0A 4B 00 78 00 00 0A 0B FF
  Z-Wave Debug                    . .  requestMeterLevel: node 008, endpoint 1, meterType 01, raw value 6400...
  Z-Wave Debug                    . .  requestMeterLevel: 2.635 kWh (float: 2.635000)
  Z-Wave Debug                    received "Sensor - Energy Monitor - Clamp 1" energy total to 2.635 kWh
  Z-Wave Debug                    RCVD multiEndPointPacket: 01 18 00 04 00 08 12 60 0D 02 00 32 02 21 64 00 00 00 00 00 78 00 00 00 00 9B
  Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 08 0E 32 02 21 64 00 00 00 00 00 78 00 00 00 00 FF
  Z-Wave Debug                    . .  requestMeterLevel: node 008, endpoint 2, meterType 01, raw value 6400...
  Z-Wave Debug                    . .  requestMeterLevel: 0.000 kWh (float: 0.000000)
And Sensor Properties here ...
Indigo Z-Wave Version: 1.0.131
Node ID: 8
Model: Home Energy Monitor (DSB09104)
Model ID: 00020009
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 2.78
Application Version: 3.67
Model Definition Version: 3
Library Type: 3
Class Name: Multilevel Sensor (routing)
Class Hierarchy: 04 : 21 : 01
Command Class Base: 31
Command Versions: 20v1 80v1 85v1 86v1 60v2 72v1 70v1 31v2 32v2
Multi-Endpoint Types: 1:(21 : 01), 2:(21 : 01)
Multi-Endpoint Classes: 1:[31 32], 2:[31 32]
Features: routing, battery, beaming, energyMeter
Neighbors: 1, 2, 6
Associations: 1:[1]
Config Values: 3:0 4:50 5:50 6:50 7:50 8:10 9:10 10:10 11:10 101:16131 102:0 103:0 111:120 112:600 113:600
Sun Oct 20, 2013 8:04 am
AndrewGWalsh offline
FWIW I get this too on this device.
Andrew
Sun Oct 20, 2013 1:45 pm
jeremyjjr offline
Hi Andrew,
Matt provided an update for me. Might be worth you asking him for a copy of the update? Good to know it wasn't isolated!
J.
Wed Oct 23, 2013 12:29 pm
midd offline
What are you referring to when say update? I have an AHEM, just waiting to install it.
Indigo 7, Monterey (12.1) on a 2009 Mac Pro..
Wed Oct 23, 2013 3:30 pm
jeremyjjr offline
Reach out to Matt and ask him to provide you with the Z-Wave update that catered for the version of the AHEM we seem to have. It might be that they're planning to include it in the 6.0.4 release but you'd have to ask them!
Wed Oct 23, 2013 3:50 pm
Correct, the changes will be included in 6.0.4. If you have an Aeotec Home Energy monitor and it doesn't work (the 2nd generation should work, the 1st generation needed some tweaking) then send me an email (indigo-support AT perceptiveautomation.com) and I can provide you with the library version that will be included in 6.0.4.
Wed Oct 23, 2013 4:08 pm
midd offline
Thanks. I have a Gen 2 model. Bought it from Norm.
Thu Oct 24, 2013 6:30 pm
Indigo 6.0.4 is now available and supports the Aeotec Home Energy Monitor DSB09104 (the G2 model was already working pre-6.0.4).
Mon Oct 28, 2013 12:04 pm
midd offline
My AHEM is up and running. Just took my time installing it and everything is working fine.
Mon Oct 28, 2013 3:29 pm
midd offline
Since installing the AHEM, I have noticed that I don't get a reading on clamp 2 in the devices window. I get a reading for clamp 1 and a reading for Meter Total, (which has a greater total than Clamp 1 so it's working).
Is this normal?
Mon Oct 28, 2013 5:47 pm
No, mine shows values for both individual clamps and the total.
Re-sync the module and copy/paste the results of the sync into a post for me.
Mon Oct 28, 2013 6:17 pm
midd offline
The re-sync corrected the problem. Thanks Matt.
Thu Oct 31, 2013 3:21 pm
midd offline
Jeremy was kind enough to let me see his script for my AHEM. It's way above my league on configuring as I know very little about Python.
Anyone else using a script to monitor energy use? I'm looking for day and month mainly. Daily and Monthly Cost aren't factors because I'm getting solar panels installed.
