Timers and Pesters
Tue Sep 17, 2013 3:36 am
BobRoss offline
Timers and Pesters
I just upgraded to version 6 -some GREAT new stuff.
I'm trying to get timers working.
I created a timer device - used the timers plugin to load a time. and received this error:
Sep 17, 2013 2:31:20 AM
Timers and Pesters Error Error in plugin execution CallPluginFunc:
<type 'exceptions.TypeError'>: getActionConfigUiXml() takes exactly 3 arguments (2 given)
Is there a step by step example of what and how to use timers
Bob Ross
Tue Sep 17, 2013 8:57 am
Re: Timers and Pesters
Can you give me the exact steps you go through to create the error? I can't seem to replicate the error here.
Tue Sep 17, 2013 4:44 pm
BobRoss offline
So....
When I did it again - Well, it worked ok
Sorry
Bob
Tue Sep 17, 2013 6:19 pm
BobRoss offline
Well - I may have screwed up
I had a timer running - I deleted the device. It deleted.
Now I get these in the Log.
Bob
Sep 17, 2013 8:16:49 PM
error Timer loop error occured: -1700
Sep 17, 2013 8:17:04 PM
Sep 17, 2013 8:17:19 PM
Sep 17, 2013 8:17:34 PM
Sep 17, 2013 8:17:49 PM
Sep 17, 2013 8:18:04 PM
Sep 17, 2013 8:18:19 PM
Sep 17, 2013 8:18:34 PM
Tue Sep 17, 2013 7:22 pm
Hmmm - have you reloaded the plugin?
Wed Sep 18, 2013 1:48 am
BobRoss offline
unloaded - reloaded
rebooted -
I did not unload, reboot and reload.
whats a 1700 error
Bob
Wed Sep 18, 2013 5:18 am
BobRoss offline
So...
Another bit of data - I had installed and moved to the 6.01 folder "Indigo Timer Script" maybe that's the cause.
I removed "Indigo Timer Script", I unloaded "Timers and Pesters", killed the server. Restarted the computer.
Made a copy of my database, downloaded a fresh copy of Indigo. installed it.
Copied back my database.
Yep still get the -1700 error
Tonight, unless another idea, I will reload my 5.X database and start there
Bob
Wed Sep 18, 2013 8:55 am
Sorry, you're right, that 1700 error is from your timer script not from the Timers plugin. The script is being executed from some schedule that's executing every 15 seconds (see the log timestamps) so you'll need to find which one and disable it. That script isn't one of our scripts so I don't know what could be causing the error.
Wed Sep 18, 2013 9:38 am
BobRoss offline
I put that in the thank you column - I now know what to look for!!
Bob
