Indigo with Cloud Conditions?
Sun Aug 11, 2013 9:25 am
Rmafive offline
Hi guys,
I am new to Indigo and I am really enjoying the system. I previously used a Smartlinc for controlling lamps throughout my house, but it recently died. I was wondering if it is possible to create a trigger for activating certain lights when the weather condition is cloudy using Indigo. I am having trouble figuring out how to use the built-in weather feature and I tried downloading the NOAA Weather Plus plugin and I still am not certain how to correctly set that up to achieve my goal. Do I have to purchase Indigo Pro to have this sort of functionality (turning lights on when the weather is cloudy outside)? Also, is there a simpler plugin or feature I can use for this?
Thanks for any help!
Sun Aug 11, 2013 12:42 pm
Re: Indigo with Cloud Conditions?
Yes, Indigo Pro is required to use plugins like the built-in NOAA Weather plugin.
To accomplish this using the built-in NOAA plugin you'd first create a weather station device. Then, you'd want to create a Device State Changed Trigger on your weather station device and select "Current Condition" "Has Any Change". You would then add a condition (on the Conditions tab) that would look at the Current Condition device state and see if it contains "cloudy":
     "If device" "KPIT" "Current Condition" "contains" "Cloudy"
By selection the correct popups from the condition editor. Add the appropriate actions and you're done.
Mon Aug 12, 2013 4:10 pm
Rmafive offline
Thanks for the help, Jay! This worked perfectly, I will be sure to purchase the Pro version.
