kpfriedberg wrote:Sorry if this is posted somewhere but i couldn't find it. I am moving Indigo from its current Mac to another machine. Can someone outline which files/folders I need to move? Thanks.
jay wrote:This process is going to get somewhat easier in 5.0, btw...
jay wrote:If you're using a 2412/2413 you'll also need to install the FTDI driver as well.
kpfriedberg wrote:jay wrote:This process is going to get somewhat easier in 5.0, btw...
Thanks goodness...any eta?
kpfriedberg wrote:jay wrote:If you're using a 2412/2413 you'll also need to install the FTDI driver as well.
Can i ask where i get this?
FYI, the Indigo Manual also specifies how to do it, although Benjamin's process works as well. The only real trick is making sure that you save and manually restore any customization you've done to the built-in scripts - using his process will cause all of the built-in scripts to be reset.
kpfriedberg wrote:any update here in regards to an easier way to migrate from one machine to another?
ryandl1 wrote:So I have a slightly different problem. I have been running Indigo 4 from my MacBook using Snow Leopard. I recently got a new iMac with Lion. I used the Mac transfer to a new computer setup to move all my files. When I did that it would not let me transfer from my username on the MacBook to the same username on the iMac so I had to create a new user name on the iMac. When I tried to open Indigo on the iMac I got a notice that I needed to open it with an adminsitrator's account. My new username is an administrator's account. I checked with Apple and they confirmed that I had to have a new username on the iMac and the process I followed was the correct one. I have not been able to find anywhere in Indigo 4 on my MacBook where I can list the authorized administrative accounts. What do I need to do to correct this situation and get Indigo 4 running on my iMac?
/Library/Application Support/Perceptive Automation/Indigo 4/
