Default voice
Fri Sep 10, 2010 3:59 am
col offline
Default voice
Is there a way to change the default male voice in Indigo, I would like to change it to female.
Fri Sep 10, 2010 7:36 am
Re: Default voice
You can change the default voice for the Mac in the Speech System Preference. If you're using the "say" AppleScript command you can specify the voice (say "text" using "Victoria").
Fri Sep 10, 2010 7:52 am
col offline
Re: Default voice
Yes I did that but it does not change the voice in Indigo (in the speak box in the actions menu) any ideas why?
Fri Sep 10, 2010 8:56 am
Re: Default voice
You probably have to restart the IndigoServer.
Fri Sep 10, 2010 9:12 am
col offline
Re: Default voice
Great, thanks for your help
Mon Feb 06, 2023 10:16 am
vintonc offline
Re: Default voice
The original post is quite old(2010) so I don't think the answer applies. The current Indigo documentation seems to imply "Speak a text string using the built-in speech synthesizer." that it only uses this voice.
Is there a way in Monterey to use the System Voice as defined in System Preferences -> Accessibility -> Spoken Content -> System Voice. ?
Users browsing this forum: No registered users and 19 guests
