hadi wrote:I have a PowerLink 1132CU and two LampLink Plus plug-in dimmers. The system responds to On/Off commands with no problems, but the time/date actions (such as turning automatically on and off at sunrise/sunset) are not working.
Any suggestions? thanks,
Because you have the 1132CU, there are two different control modes you can be in: Indigo controlling the logic (Time/Date and Trigger Actions), and the 1132CU controlling the logic. If you are online, or connected, to the 1132CU such that you can manually control devices from Indigo, then Indigo is controlling things. If you disconnect from the interface (not physically, but from the Interface->Disconnect menu) or if you quit Indigo, then the 1132CU will control the logic.
Which method are you using when it fails (is Indigo running)? If you are trying to use Indigo, then you must have your computer set to not go to sleep. Could this be the problem?
Presuming you are using Indigo to control the logic at this point, does it show in the Log Window that the Time/Date Action went off at sunset and sunrise?
Matt
