Hi
I am currently evaluating Indigo and Xtension.
The following problem happened yesterday when the Mac booted up using Energy Saver (This will change soon as I am about to use a PowerBook G3 which will be always on).
7:07:29 PM, 4/26/04 Error undefined signal (66) from interface
7:07:29 PM, 4/26/04 Error undefined signal (E6) from interface
7:07:30 PM, 4/26/04 Error failure to connect and initialize interface
So I unplugged the CM11 and connected it to another machine - same problem. I thought I would leave it unplugged for an hour or so but upon retry it was the same.
I decided to try it with Xtension 5.0.1 and it found the interface. Quit Xtension and opened Indigo and everything was ok again.
Is this just one of those things that happen? Why would Xtension connect to the interface but not Indigo on 2 different machines until Xtension had initialised it .
Just incase required :
PowerMac G4 867 / PowerBook G4 1.25
Mac OS X 10.3.3
Usb -> Serial Interface (Uses FDTI drivers)
CM11
Inidigo 1.3.3
So far I have been very impressed with Indigo and find it easier to use than Xtension. However, I like the feature Xtension has where you can use photo's of the room
