Moving Shortcuts into a New Folder
Tue Mar 07, 2023 9:48 am
In the Shortcuts app for macOS, you may find that you can't drag an existing shortcut to a new (empty) Shortcuts Folder. This is a bug in the Shortcuts app. To get around this limitation, create a new shortcut into the new folder and name it something like 'temp' -- it doesn't need to actually do anything. You should now be able to drag an existing shortcut into the folder. Once that's done, you can delete your 'temp' shortcut.
Tue Mar 07, 2023 10:18 am
Re: Moving Shortcuts into a New Folder
Also note that drag 'n drop works on iOS and iPadOS.
