shapa wrote:Well, let's say I love to help others to avoid my mistakes
Bleeding edge. Someone should be doing the QA anyway.
For sure I've checked the permissions. And in case I'll double click on any image name - it will actually show the image.
Those images are definitely "outcoming" - when someone is using the intercom, static jpeg from the camera is shared via iMessage. Another house install (still on BigSur) continues to work fine.
Not sure home automation wants to live on the bleeding edge!
Anyhow, have updated a system to Monterey and agree sending images is broken...
There is this report:
https://apple.stackexchange.com/questio ... ey-problemWhich essentially the same issue as plugin uses AppleScript to Imessage to send messages out, have just checked and the incoming SQL database access works fine..
Update: WorkaroundIt is because of sandboxing the iMessage app - need to save photos to a directory that all app’s have access to. (which quick checks seems to be Downloads and Pictures).
Checked - if png in users Picture directory will send fine with the plugin.
I would guess could also overcome by giving iMessage FullDiskAccess in security - but haven't tested that as yet. Figured using Pictures directory safer for the moment.
Glenn
