Visibility to Ecobee Data
Fri Jul 22, 2022 5:40 pm
SearchCz offline
Re: Visibility to Ecobee Data
I'm making progress on my scripts, and I'm able to pull in a variety of dev states ( hvacMode, equipmentStatus, hvacCoolerIsOn, hvacHeaterIsOn, setpointHeat, setpointCol ).
I have two questions.
1) whats the key to the dev.state for current temperature(s).
2) what would be the proper syntax if I wanted to set a dev.state in my script. hvacMode and setpoints for example.
All help greatly appreciated!
FlyingDiver wrote:
SearchCz wrote:
How would I et a look at any f these device state values in a python script ?
https://wiki.indigodomo.com/doku.php?id ... vice_state
# get the device
dev = indigo.devices[23989834]  # Some custom device
print unicode(dev.states)
Except, you can't use the label in the popup shown a couple posts up. You need the name from the list, or right click on the name in the list and get the python reference.
Fri Jul 22, 2022 6:02 pm
https://wiki.indigodomo.com/doku.php?id ... ce_states5
You can't set a state directly. You have to use one of the Indigo device commands from the link above (right after the states list).
Fri Jul 22, 2022 7:11 pm
SearchCz offline
Thanks for that link. That should keep me busy for a while.
Any idea why my attempts to change a set point by one degree are failing? My thermostat is set to Celsius, and when I use an indigo action to increment that setpoint it initially appears to work (adding 1 to the setpoint value) then immediately dropping that setpoint by about .6 degrees.
Fri Jul 22, 2022 7:12 pm
Ecobee is Fahrenheit natively (more or less) so you're going to have conversion round-off issues.
