BUG: Change SetPoint in Auto Mode
Tue May 04, 2021 3:56 pm
ukie offline
When my smart thermostat is operating in AUTO mode and I adjust the cool temp down, I get the following in the event log:
Ecobee 2                        Ecobee Upstairs: set cool to: 77.0 and leave heat at: 67.0
Ecobee 2                       Ecobee Upstairs: set heat to: 66.0 and leave cool at: 78.0
Where the initial temp was set to 78 and 67.
So it ends up changing only the heat set point and the cool point remains as is.
Tue May 04, 2021 4:17 pm
Re: BUG: Change SetPoint in Auto Mode
Can you do that again with debug logging on?
I assume if you're in Cool or Heat mode and you adjust the setpoint it does it correctly?
Tue May 04, 2021 4:57 pm
ukie offline
Ecobee 2                        Ecobee Upstairs: set cool to: 77.0 and leave heat at: 68.0
   Ecobee 2 Debug                  API 'set hold temp' request completed, result = <Response [200]>
   Ecobee 2 Debug                  Ecobee Upstairs: action.thermostatAction: DecreaseHeatSetpoint
   Ecobee 2                        Ecobee Upstairs: set heat to: 67.0 and leave cool at: 78.0
This is happening only through the Indigo App HVAC interface. Adjusting it directly from the Indigo Mac Client works properly since it has two arrows for both cool setpoint and heat setpoint.
Tue May 04, 2021 6:01 pm
I'm sorry, I don't know what you mean. You mean the Indigo Touch iOS app? I've never tried using that for this plugin.
Wed May 05, 2021 9:59 am
ukie offline
Yes, the Indigo iOS app has an HVAC interface.
https://photos.app.goo.gl/nsqqjDpeYr5Pt2yv9
Wed May 05, 2021 10:00 am
Ok, I'm going to test with that. I wonder if it's actually a bug in that HVAC UI?
Wed May 05, 2021 10:24 am
OK, so what's the expected behavior with that single set of buttons in the touch UI? Change both setpoints each press?
Wed May 05, 2021 10:41 am
Yes - the server issues separate setpoint change messages.
Wed May 05, 2021 11:57 am
For now, ignore the log messages and let me know if the actual UI (Mac client, touch client, and Ecobee app) are showing the correct values after a change from the touch UI.
Wed May 05, 2021 12:51 pm
ukie offline
Ecobee app indeed reflects the Indigo log behavior, only the heat set point changes.
Wed May 05, 2021 2:00 pm
Ok, I'm getting the same thing. The Indigo touch UI shows both changes, but Ecobee is showing only one change, the last one sent by the server.
Wed May 05, 2021 2:24 pm
My initial analysis is that there seems to be a race condition between the plugin and the Indigo server, such that the device snapshot (which includes the current setpoints) sent with the commands does not include the change made from the first change command. Looking into a fix now.
Wed May 05, 2021 2:27 pm
Mon May 10, 2021 10:38 am
Mon May 10, 2021 9:35 pm
ukie offline
This fixed it. Thank you!
