Upgrading from Original Ecobee Plugin (v1.2.3)
Thu Dec 13, 2018 4:25 pm
Jann offline
Hello all, and thanks @FlyingDiver for doing this new plugin.
I have a simple question... Can I have both the ecobee plugins running at once (v1.2.3 & v2.1.7) - since they create their own devices - for the amount of time it takes to move over all my triggers and schedules?
Why? I hear you ask..
Well, because if I delete the old device before I have the new one - and have moved the triggers, etc to the new one - each and every one of my triggers must be deleted and created from scratch (ie: when fan comes on ecobee, turn fan switch on oscillating fan.. or when temp is 76+ turn on ceiling fan)
Thanks in advance...
Thu Dec 13, 2018 5:08 pm
Jann offline
Re: Upgrading from Original Ecobee Plugin (v1.2.3)
FYI: I just tried it, and it works the exact same way as if you had an Insteon Thermostat and just installed a Z-Wave thermostat... ie: They co-exist.
I was able to install Ecobee 2 and successfully move all my schedules, triggers, etc... to the new Ecobee 2 system.
Thanks FlyingDiver!
Thu Dec 13, 2018 11:11 pm
You're welcome.
