- Posted on
Sat Jan 16, 2021 9:36 am
Stoutjesdijk
offline
Here is a new graph. It is hard to see, but at 11:30 the setpoint was increased to 22C, and at that time the L and R stat temperatures were both about 14C. A separate temperature sensor far away from the window measured about 16C at that time (purple).
The right Spirit, which is located in a corner and with a bunch of boxes surrounding it, is heating up relatively fast. Its temperature settles fairly quickly at the setpoint.
Interestingly, the left Spirit temp and valve colors are cyan and blue. After a short period of 100% valve, the valve closes but after four hours, the temp is still not at the setpoint. It looks like the valve reacts properly to the measured temperatures, but the effect is not as strong as it should be. Maybe this is a case where I should adjust the temperature offset on the Spirit device. I will give it a shot and report back.
EDIT: Actually, the temperature values do not need an offset, as shown by the measurements during the night and early morning.
- Screenshot 2021-01-16 at 16.24.41.png (66.46 KiB) Viewed 6120 times
Best regards,
Mark
Trying to tie it all together...
| Indigo | Plex | NAD M33 | Unifi | LG WebOS | Tado | Sonos | SolarEdge | HUE |
