Page 7 of 7
Re: Simple Serial Plugin - just to use for debugging
PostPosted: Wed Feb 03, 2016 8:17 pm
by Vig
Hi Jim,
My fault, I don't think I explained my question correctly. Basically, I am controlling my projector with SimpleSerial by sending the hex code to turn the projector On and Off. There is also a hex code that I can send to the projector using SimpleSerial to poll the On/Off state and the projector will reply back with a Hex code whether it's On or Off. My question: is there a way to somehow pass that information to the Indigo Touch or to the Indigo GUI to visually see if the projector is in On or Off state?
thanks,
Vig.
PostPosted: Sun Jun 19, 2016 3:41 pm
by yergeyj
OK Vig,
I have been meaning to reply in a useful fashion for 3-4 months now, but will be honest ... I'm in the process of opening a brewery and just haven't had time to research your question properly.
Indigo DOES have the capacity to include icons / states for a device (e.g. a SimpleSerial device), however, I still haven't implemented this for any of my plugins or devices, and just haven't had time to figure out how to do it.
Sorry, but I guess it still remains simply a Simple Serial plugin. :wink:
Jim
PostPosted: Sun Jun 19, 2016 5:12 pm
by mat
How about a trigger:
Trigger
Type: Device state change [your projector]
Last response - hex (if thats how you are communicating)
Has any change
with an Action in the trigger of
Type:Insert device state into variable
Device [your projector]
then in the edit actions settings:
insert state : last response hex
select your chosen variable.
The on your control page(s) use the variable value to display heuristic images representative of the state?
PostPosted: Sun Jul 10, 2016 10:27 pm
by Vig
Jim and Mat, thanks for the replies!
Trigger setting suggested by Mat did work just fine! Thank you Mat. Didn't realize the power of Triggers :)
Good luck with the Brewery Jim!
PostPosted: Tue May 09, 2017 5:57 pm
by cutmoney
Does anyone know if this plugin is available for download? I would PM the dev, but it seems that he is quite busy at the moment.
PostPosted: Wed May 17, 2017 5:23 am
by yergeyj
Per the original post, if you PM me with your e-mail, I will send a copy of the plugin.
Jim (the dev)
PostPosted: Sat May 20, 2017 8:10 am
by hamw
How do I turn off the debug output?
