Alerts without FWP
Tue Dec 20, 2022 10:11 am
roquej offline
Alerts without FWP
The only thing left to replace is weather alerts.
Do you have any suggestions on how to accomplish the same alert functionality with GhostXML or the NOAA plugin? I believe the below was your code:
wsStates = indigo.devices[DEVICEID].states #FWD device
smtpDevice = DEVICEID
def sendAlertEmail(alert, message, expires):
emailTo = "email@email.com"
theSubject = "Weather Alert: %s" % str(alert)
theBody = "%s\n\nThis weather alert is valid until %s" % (message,expires)
props={
'emailTo': emailTo,
'emailCC': '',
'emailBCC': '',
'emailSubject': theSubject,
'emailAttachments':'',
'emailFormat': 'plain',
'emailMessage': theBody
plugin = indigo.server.getPlugin("com.indigodomo.email")
if plugin.isEnabled():
plugin.executeAction("sendEmail", deviceId=smtpDevice, props=props)
return
if str(wsStates[u'alertTitle1']) != ' ':
sendAlertEmail(wsStates[u'alertTitle1'], wsStates[u'alertDescription1'], wsStates[u'alertExpires1'])
if wsStates[u'alertTitle2'] != ' ':
sendAlertEmail(wsStates[u'alertTitle2'], wsStates[u'alertDescription2'], wsStates[u'alertExpires2'])
if wsStates[u'alertTitle3'] != ' ':
sendAlertEmail(wsStates[u'alertTitle3'], wsStates[u'alertDescription3'], wsStates[u'alertExpires3'])
if wsStates[u'alertTitle4'] != ' ':
sendAlertEmail(wsStates[u'alertTitle4'], wsStates[u'alertDescription4'], wsStates[u'alertExpires4'])
if wsStates[u'alertTitle5'] != ' ':
sendAlertEmail(wsStates[u'alertTitle5'], wsStates[u'alertDescription5'], wsStates[u'alertExpires5'])
Tue Dec 20, 2022 2:28 pm
Re: Alerts without FWP
That doesn't look like my work, but anything is possible.
With the NOAA plugin that shipped with Indigo 2022.1, the plugin includes a Weather Alert device type that you can use with Indigo Triggers. The state names that show up in the Create Trigger dialog box need to be improved (my fault NOT Jay's or Matt's). These labels will be improved in a future release.
You can select the first "Sent" state in the list and that should correspond to Alert 1. Or you could watch the "Alert Count" value. If you select "Observation Date/Time", it will trigger any time the data are updated (which may or may not mean a new severe weather alert).
With GhostXML, the method would be largely the same. Create Triggers that fire when your chosen weather alert data changes.
