Basic Problem Unable to reach Dark Sky
Mon Mar 23, 2020 9:06 am
captcurrent offline
I installed the pluginsgotmy API and created a weather forecast device. I get this error which probably means I screwed top again..
Any Thoughts?
ar 23, 2020, 10:26:14 AM
Error process (pid 7582) failed to quit after polite request -- forcing it to quit now
Stopped plugin "Fantastic Weather 0.3.01"
Starting plugin "Fantastic Weather 0.3.01" (pid 7602)
Fantastic Weather
Fantastic Weather =================================================== Initializing New Plugin Session ===================================================
Fantastic Weather Plugin name: Fantastic Weather
Fantastic Weather Plugin version: 0.3.01
Fantastic Weather Plugin ID: com.fogbert.indigoplugin.fantasticwWeather
Fantastic Weather Indigo version: 7.3.1
Fantastic Weather Python version: 2.7.10 (default, Feb 7 2017, 00:08:15) [GCC 4.2.1 Compatible Apple LLVM 8.0.0 (clang-800.0.34)]
Fantastic Weather Mac OS Version: 10.12.6
Fantastic Weather Process ID: 7602
Fantastic Weather =======================================================================================================================================
Fantastic Weather **********************************************************************************************************************************
Fantastic Weather ******************** Powered by Dark Sky. This plugin and its author are in no way affiliated with Dark Sky. *********************
Started plugin "Fantastic Weather 0.3.01"
Fantastic Weather Error Unable to reach Dark Sky. Retrying in 10 seconds.
Fantastic Weather Error Unable to reach Dark Sky. Retrying in 20 seconds.
Mar 23, 2020, 10:26:52 AM
Fantastic Weather Error Unable to reach Dark Sky. Retrying in 30 seconds.
Mon Mar 23, 2020 10:37 am
Re: Basic Problem Unable to reach Dark Sky
My access appears to be working just fine, so I don't think it's a problem on their end.
Unfortunately, what you've provided is not enough to go on. Could you please turn on debugging, reload the plugin and post any additional messages you see? Also, please check the plugin's private log at:
/Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.fogbert.indigoplugin.fantasticwWeather/plugin.log
Lastly, what operating system version are you using on your server machine? The plugin requires at least High Sierra.
Mon Mar 23, 2020 10:49 am
captcurrent offline
You nailed it. U am running Sierra. because of conflicts between Indigo and High Sierra
Oh well. Thanks for the quick response
Mon Mar 23, 2020 12:25 pm
What conflicts? I ran High Sierra for years, then mostly skipped Mojave and went to Catalina (which is not for everyone).
Mon Mar 23, 2020 12:32 pm
captcurrent offline
FTDI-Driver Bugs. The work around never worked for me
My Min Mac can't run Catalina. I can't afford to keep up with all the "hardware " improvements
Mon Mar 23, 2020 3:08 pm
Yeah, this is likely an issue with outdated security in Sierra. I've heard that it's possible to upgrade the security libraries to support the latest protocols, but I have zero experience in doing that and can't provide any help or support. Sorry!
Mon Mar 23, 2020 3:16 pm
Which mini do you have? I have 2012 (running basically everything it'll run, currently on High Sierra), 2014 (Mojave) and 2018 (Mojave & Catalina) minis all running Indigo and PowerLincs with no driver issues. I did start with completely clean installs on each of them.
Mon Mar 23, 2020 4:46 pm
captcurrent offline
mid 2010 mini
Tue Mar 24, 2020 9:10 am
Wow, that's old... ;)
No idea if doing a clean OS install (of High Sierra) will work or not then.
Wed Mar 25, 2020 7:03 am
captcurrent offline
like I am made of money
oh well
Wed Mar 25, 2020 8:26 am
We have a lot of users with older Macs, and we're not making any judgements. Not many using Macs as old as yours, which was my point. Unfortunately, time and technology march on, and fundamental things like low-level security protocols like TLS get updated to address hacked security protocols. In this case, it has required API and web data providers to upgrade to a newer security protocol version. Older operating systems will often get left behind, and unfortunately we all know that Apple is not that interested in updating older versions.
If you haven't already tried, I would definitely recommend doing a clean High Sierra install on your mini (and only manually move the Indigo installation folder over) to see if that makes any difference. Also make sure that your PowerLinc is plugged directly into a USB port on the mini itself and not through a hub.
Wed Mar 25, 2020 8:37 am
captcurrent offline
Matt, I have around $15 K in Mac hardware In general I am moving to convertthese systems to FreeBSD. That and open source software serves most of my need although not as early as with GUI. Yeah apple wants to sell hardware. I am retired and a lot older then my machines
I will try Hiigh Sierra One more time on this maschine. My US maschine is at the level and sort of runs
Thanks for the additional info
Thu Mar 26, 2020 5:24 pm
captcurrent offline
ok i upgraded to 10.13. and right on schedule, have the bug. No more insteon. I have zwave and x-10 back and since all my
insteon devices here are dead. i think i am sort of back in business. Dark Sky now works. REAL cool
thanks for the assist. This old man and his old Macs will fade off into the sunsets
Mon Mar 30, 2020 5:33 am
c64 offline
I'm in the same boat - old minimac currently on Sierra. I have been trying to find a "safe" looking download link for High Sierra, as it is not appearing in the App Store for some reason. Does anyone have any tips on where I can download it? Thank you.
Mon Mar 30, 2020 5:38 am
Umtauscher offline
Just google it.
Apple's providing a download page for it.
https://support.apple.com/de-de/HT208202
Cheers
Wilhelm
