Using the data
Sat Jan 04, 2020 5:40 pm
Bildhauer offline
Using the data
Hello,
I would like to us the data of FWP. How can I manage it to have triggers like "if temperature is less than x than do y"?
Thanks a lot for your support!
Best Regards
Bildhauer
Sat Jan 04, 2020 5:59 pm
Re: Using the data
All you would need to do is create a trigger and link it to the temperature state of a weather (or weather forecast) device. For example, to create a trigger that will fire when the temperature drops below freezing, you would set it like this (Fantastic Weather is the name of my current weather device). It's important to remember that the data will only be as current as your last download--so it won't always be real time. I download data every 15 minutes which I find sufficient.
Screen Shot 2020-01-04 at 5.50.33 PM.png (113.38 KiB) Viewed 4437 times
Sun Jan 05, 2020 5:46 pm
Bildhauer offline
Re: Using the data
Thx, that helps a lot.
Where do you set up the 15 minutes updates?
Best regards
Bildhauer
Sun Jan 05, 2020 5:54 pm
Re: Using the data
In the plugin configuration dialog, there is a setting called "Call Interval" which controls the frequency of updates to the data. You can set it as frequent as every 2 minutes; however, I would not recommend that. The data probably don't change that frequently, and the API call limit could be exceeded (unless you have registered for a higher call limit).
Mon Jan 06, 2020 2:38 pm
Bildhauer offline
Re: Using the data
Great, thanks!
Any chance to use data of the plugin e. g. to send an email saying "the temperature has reached now xº C."?
Mon Jan 06, 2020 3:16 pm
Re: Using the data
Easy. Just use the trigger above and select a notification action. There are many options if you choose to set them up. You can use Indigo's built in email facility, the Better Email plugin (recommended) or any number of messaging plugins.
I personally use Better Email to send a message to my cell phone company email and Verizon converts that to a text message.
Mon Jan 06, 2020 3:29 pm
Bildhauer offline
Re: Using the data
Sorry, that's not what I want.
I want to have e.g. an hourly email telling me the temperature provided by your plugin. So is there any way to read it out (e. g. using a Python script?)?
Mon Jan 06, 2020 3:38 pm
Re: Using the data
First a question. Do you mean "read it out" as in read it aloud?
Regardless, you can use a schedule action instead of a trigger to do it. In my system, I have standard schedules set for:
- every minute,
- every 15 minutes,
- every hour,
- every 12 hours,
- every day,
and so on.
I then add any tasks I want to accomplish on a set schedule to these individual schedules.
Mon Jan 06, 2020 3:39 pm
Bildhauer offline
Re: Using the data
yes, I meant "read it out"!
So there is now way to read the values out?
Mon Jan 06, 2020 4:00 pm
Re: Using the data
You'll have to use a short bit of Python code to do it (the Indigo server speak action doesn't support substitutions).
indigo.server.speak(unicode(dev.states['temperature']))
Replace the number with the device ID of your weather device. Then just run the script each hour.
Mon Jan 06, 2020 4:01 pm
Bildhauer offline
Re: Using the data
Ok, I'll try, I'm not a great programmer …
Mon Jan 06, 2020 4:18 pm
Bildhauer offline
Re: Using the data
I'm getting an error running this script, that it doesn't find the key temperature.
And how do I get the read out value in an an email or a trigger for a specific action?
Mon Jan 06, 2020 4:23 pm
Re: Using the data
Just to be sure that you have all the needed parts.
Install the Fantastic Weather plugin.
Sign up for a Dark Sky API key.
Configure the plugin to use your Dark Sky account.
Create a plugin Weather Device linked to the geographic location you wan to monitor.
Then the script should work. I've tested it against my system and its working as expected.
Mon Jan 06, 2020 4:25 pm
Bildhauer offline
Re: Using the data
Everything done as describe by you. But error is still existing run the script.
Still the additional question: How do I get the value of this script into an email or trigger?
Mon Jan 06, 2020 4:28 pm
Bildhauer offline
Re: Using the data
Log shows:
Script Error embedded script: 'key temperature not found in dict'
embedded script, line 2, at top level
KeyError: 'key temperature not found in dict'
