Fantastic Weather Plugin Bug Reports
Sat Apr 01, 2023 8:11 am
Re: Fantastic Weather Plugin Bug Reports
The Dark Sky API is officially dead (as of yesterday) and I'm recommending that users find a new API and use the Ghost XML plugin to get their weather data into Indigo (or use one of the other fine weather plugins).
Some users are switching to a "bootleg" API that emulates Dark Sky at https://dev.pirateweather.net/forecast/ in order to keep using Fantastic Weather. You can also find information here if you want to try this route.
But as of yesterday, I'm unfortunately no longer supporting the Fantastic Weather plugin.
Sat Apr 01, 2023 8:23 am
norcoscia offline
Any chance you could post a version that uses the bootleg api for those of us that are not programmers - if not, no worries I can give it a shot but I really don’t like messing around in plug-in code.
_______
Norm
Sat Apr 01, 2023 8:29 am
Patience grashopper. :D
I just posted it.
Sat Apr 01, 2023 8:59 am
ryanbuckner offline
I just posted it.
haha. He said "Grasshopper" but only wanted to use 3 of those letters.
Just tried the new version. Any config needed to get this working with the new API?
Apr 1, 2023 at 10:56:34 AM
   Upgrading plugin Fantastic Weather to newer version 2022.0.3 (previous version moved to trash)
   Loading plugin "Fantastic Weather 2022.0.3" using API v3.0
   Starting plugin "Fantastic Weather 2022.0.3" (pid 14260)
   Started plugin "Fantastic Weather 2022.0.3"
   Fantastic Weather Warning       Unable to make a successful connection to API. Retrying in 10 seconds.
   Fantastic Weather Warning       Unable to make a successful connection to API. Retrying in 20 seconds.
Apr 1, 2023 at 10:57:20 AM
   Fantastic Weather Warning       Unable to make a successful connection to API. Retrying in 30 seconds.
Sat Apr 01, 2023 9:06 am
Yes -- you'll need to sign up for an API key at Pirate Weather and adjust the plugin configuration to get it to work with the new API key.
Sat Apr 01, 2023 9:58 am
norcoscia offline
A million thanks - trying to change all my control pages would be so so hard and I have totally forgotten how to work with the graphics…
_______
Norm
Sat Apr 01, 2023 10:25 am
You're welcome Norm.
