Fantastic Weather Plugin Bug Reports
Sun Jul 22, 2018 7:46 pm
Re: Fantastic Weather Plugin Bug Reports
Monstergerm wrote:
Great job Dave. I just downloaded plugin and will do some testing.
Regarding the icons. I noticed that Dark Sky reports mostly-cloudy and partly-cloudy but uses in both cases the icon partly-cloudy.
"summary":"Mostly Cloudy","icon":"partly-cloudy-night".
"summary":"Partly Cloudy","icon":"partly-cloudy-night"
Can the plugin correct for this and generate the mostly-cloudy icon view?
Thanks for the kind words.
Your idea is probably a pretty easy one to crack from a programming standpoint, but with the transition from WU to Dark Sky, I was planning on making as few adjustments to the underlying data as possible. Your suggestion runs counter to that plan. :D I'm not dismissing your suggestion, but at this point I'll say "maybe".
Let me know if you see anything with the beta that doesn't look right. Thanks!
Mon Jul 23, 2018 4:04 pm
Monstergerm offline
TemperatureLow bug in DailyForecast device:
Dark Sky reports a TemperatureLow and a TemperatureMin. If you look at the timestamp for each readings you can see that TemperatureLow is actually for the following day in the morning, while TemperatureMin is the correct reading for the current day in the morning. The plugin currently reports TemperatureLow but should report TemperatureMin.
TemperatureHigh and TemperatureMax seem to be identical readings. So it does not matter which one to report.
Mon Jul 23, 2018 6:49 pm
Thanks, but I'm not too sure about this one. According to the Dark Sky API:
temperatureHigh optional, only on daily
The daytime high temperature.
temperatureHighTime optional, only on daily
The UNIX time representing when the daytime high temperature occurs.
temperatureLow optional, only on daily
The overnight low temperature.
temperatureLowTime optional, only on daily
The UNIX time representing when the overnight low temperature occurs.
temperatureMax optional, only on daily deprecated
The maximum temperature during a given date.
temperatureMaxTime optional, only on daily deprecated
The UNIX time representing when the maximum temperature during a given date occurs.
temperatureMin optional, only on daily deprecated
The minimum temperature during a given date.
temperatureMinTime optional, only on daily deprecated
The UNIX time representing when the minimum temperature during a given date occurs.
So my reading of the docs is that temperatureLow is prospective once today's low has passed. Moreover, temperatureMin is going to go away at some point. I think we gotta stick with temperatureHigh and temperatureLow. Let me know if you think that's off base.
Mon Jul 23, 2018 7:22 pm
Monstergerm offline
Yes, I saw this and not sure why they would deprecate these values.
As long as everyone is aware of that these are Overnight Low Temperatures. If today is Monday and I am looking at Wednesday's Low forecast I will get actually the low temperature for Thursday morning. After researching this a bit more it actually looks like this is the way WU also did it ... never thought about it.
Mon Jul 23, 2018 7:39 pm
Cool. Please do let me know if you see anything else. I was (and am) very grateful for your help with the WUnderground plugin.
Tue Jul 24, 2018 1:24 pm
Monstergerm offline
Two minor things:
alertUri and Alert - URI should be spelled alertUrl and Alert - URL
In the Hourly device, I think Date - Hour 1 etc. would be better named Time - Hour 1
Tue Jul 24, 2018 2:30 pm
Monstergerm wrote:
Two minor things:
Since a URL (Universal Resource Locator) is (almost always) a subset of a URI (Universal Resource Identifier) then it really depends on the possible values of the field: if it can contain URIs that aren't URLs then changing it would be inaccurate... ;)
Tue Jul 24, 2018 3:48 pm
Thanks @Monstergerm.
Jay is right. The Dark Sky API returns a URI, so that's what I went with.
Your comment about the Hour state is right on, and I've already made that change. The change will appear in the next build.
Cheers!
Thu Jul 26, 2018 8:25 am
Colorado4Wheeler offline
Fantastic Weather is a great example of taking years of plugin experience working on WU and turning that into a better product. That is to say that I'm loving the new plugin and I think it works better than WU did - or at least has more useful information for me. Either way it feels like a more mature plugin than it is because it works so well.
I have zero complaints right now.
I have used Dark Sky for a very long time anyway because I've always found it to be more accurate than most other sources (at least in the past year or two) so I'm thrilled that it is part of Indigo!
Thu Jul 26, 2018 8:57 am
Glad to hear that you're finding the plugin useful and especially glad that you're finding no flaws! :D
If you find anything hinky or think of any enhancements, please let me know.
Sat Sep 01, 2018 5:27 pm
Different Computers offline
I'm getting a lot of
Fantastic Weather Error         Unable to decode data. (Line 842) No JSON object could be decoded
even though my internet is working fine.
I don't see any commentary on this except in the WU forum.
Sat Sep 01, 2018 7:33 pm
I looked at six days of logs and didn't get that message once--which leads me to believe that it's not an API change (otherwise, we'd all be seeing the same thing). The log message is saying that Dark Sky returned something in response to the plugin's request, but that something wasn't a valid JSON object. If there's not a valid JSON return from the service, there's not much I can do after that.
Are you seeing the message all the time, or is it intermittent? The URL sent to the service is written to the plugin's debug log. Try pasting the URL in a browser and see what comes back.
Sat Sep 01, 2018 7:35 pm
The Fantastic Weather plugin doesn't use the WU service, so nothing on the WU forums would apply.
Sat Sep 01, 2018 7:42 pm
@lanbrown: Thanks for posting that output. The plugin is trying every 30 seconds to get back into a good state as quickly as possible, but clearly that could chew through API calls fast. I'll add something to the TODO list to take a look at how it can be more frugal in such a condition.
Sat Sep 01, 2018 7:50 pm
lanbrown wrote:
I did reset the plugin a couple times today and it would work for a little while and then back to that message again.
It is working right now. So I don't think it ate through the API limit. They may not have registered on their side.
Thanks. You can always check the number of calls within the plugin configuration dialog. That number reflects the number of registered calls (it comes from the API return so it would not be updated/accurate when the API is in a bad state). Also, the API calls reset each day at midnight UTC (IIRC) so at this precise moment, that number is likely very low. Mine is on 8 calls (at 15 minute intervals).
