IS this a problem with the plugin?
Sat May 18, 2013 6:10 am
midd offline
ok so I've been continuing to have problems with my OS rain sensor(s). I bought a new one thinking that the old one might be a problem, Still the same problem with the new sensor, no updates to any of the states.
This morning I decided to add my original sensor back into the mix. Now its updating every minute or so, saying that it's been added. This tends me to believe that its the plugin, not the sensor or the RFXrec. Playing around with the settings, I selected Currently raining? And it comes back yes. However its a beautiful sunny morning here. Meanwhile my other rain sensor has not been updated in 5 days,
May 18, 2013 7:58:16 AM
  RFXCOM Debug                    validateDeviceConfigUi called
  RFXCOM Debug                    wrote address for 206
  RFXCOM Debug                    <<-- entering deviceUpdated: Rain Guage 2
  RFXCOM Debug                    deviceStop called. Device Rain Guage 2 not found in list.
  RFXCOM Debug                    deviceStart called. Adding device Rain Guage 2, type: Rainsensor
  RFXCOM Debug                    Adding sensor 206.
  Received INSTEON                "Thermostat" temperature changed to 76.0
  RFXCOM Debug                    processing: 11 85 2 3 206 0 0 0 0 0 0 121 (0B 55 02 03 CE 00 00 00 00 00 00 79)
  RFXCOM Debug                    Rainsensor 206 values updated rate:0.000000 total:0.000000
  RFXCOM Debug                    Rainsensor 206 in list
  RFXCOM Debug                    lastUpdated empty so must be new day.
  RFXCOM Debug                    Entering new day
  RFXCOM Debug                    Entering new month = 5
  RFXCOM Debug                    Entering new week = 20
  RFXCOM Debug                    saving plugin props
  RFXCOM Debug                    ++++++++++++++
  RFXCOM Debug                    deviceStop called. Removed device Rain Guage 2.
May 18, 2013 7:59:46 AM
  Received INSTEON                "Thermostat" temperature changed to 77.0
  Schedule                        Am I Home?
May 18, 2013 8:00:16 AM
  RFXCOM Debug                    processing: 11 85 2 4 206 0 0 0 0 0 0 105 (0B 55 02 04 CE 00 00 00 00 00 00 69)
  RFXCOM Debug                    check if new day: last date 2013/05/18, new date 2013/05/18
May 18, 2013 8:01:01 AM
  RFXCOM Debug                    processing: 11 85 2 5 206 0 0 0 0 0 0 105 (0B 55 02 05 CE 00 00 00 00 00 00 69)
May 18, 2013 8:01:50 AM
  RFXCOM Debug                    processing: 11 85 2 6 206 0 0 0 0 0 0 105 (0B 55 02 06 CE 00 00 00 00 00 00 69)
May 18, 2013 8:03:24 AM
  RFXCOM Debug                    processing: 11 85 2 7 206 0 92 153 0 0 9 105 (0B 55 02 07 CE 00 5C 99 00 00 09 69)
  RFXCOM Debug                    Rainsensor 206 values updated rate:9.330000 total:0.000000
May 18, 2013 8:04:11 AM
  RFXCOM Debug                    processing: 11 85 2 8 206 0 92 153 0 0 9 105 (0B 55 02 08 CE 00 5C 99 00 00 09 69)
May 18, 2013 8:04:58 AM
  RFXCOM Debug                    processing: 11 85 2 9 206 0 92 153 0 0 9 105 (0B 55 02 09 CE 00 5C 99 00 00 09 69)
May 18, 2013 8:05:45 AM
  RFXCOM Debug                    processing: 11 85 2 10 206 0 92 153 0 0 9 105 (0B 55 02 0A CE 00 5C 99 00 00 09 69)
Indigo 7, Monterey (12.1) on a 2009 Mac Pro..
Sat May 18, 2013 10:50 am
midd offline
Re: IS this a problem with the plugin?
I deleted both Rain Gauges and started from scratch. It appears to be updating now. Might get some rain soon so I'll know for sure.
Update: Its been raining half the night and all morning.. the updates have gone through, but no data has been received.
Sun May 19, 2013 9:17 pm
midd offline
Here's the latest info that I'm seeing:
RFXCOM Debug                    processing: 11 85 2 58 206 0 92 153 0 0 9 121 (0B 55 02 3A CE 00 5C 99 00 00 09 79)
  RFXCOM Debug                    check if new day: last date 2013/05/19, new date 2013/05/19
Mon May 20, 2013 9:10 am
It looks like there is an incompatibility between Indigo and how the plugin is overriding a method. I'll email the developer the details so he can provide a fix.
I'm not positive it will fix the Rain Gauge problem, but base on the Event Log snipped above it might.
Mon May 20, 2013 5:28 pm
midd offline
Thanks Matt.
Fri May 24, 2013 12:40 pm
midd offline
I'm happy to report that I'm finally getting data from my OS Rain Sensor to Indigo. I replaced the Rfxrec's antenna with the Radio Shack antenna as mentioned here: viewtopic.php?f=28&t=8355
I'm now getting a signal strength of 8 and I have .35 rain so far today.
Thu Aug 15, 2013 2:06 pm
RJdeKok offline
There is a new version available here (1.3.6):http://www.rjdekok.nl/downloads/RFXCOM.indigoPlugin.zip
- Bug fix
Fri Oct 18, 2013 3:41 am
automagic offline
I have just got a new RFXtrx433 and am trying to set this up with a Byron Home Easy HE306 wireless doorbell. I have been following this discussion and this article. But cannot get any triggers to work. I have set up a device to transmit, which rings the door chime unit. But when I press the door bell I get this in the log in debug mode -
  RFXCOM Debug                    processing: 7 16 1 90 78 8 7 112 (07 10 01 5A 4E 08 07 70)
  RFXCOM Debug                    Switch Command N8 7808 command 7 received
  RFXCOM Debug                    Switch Command 7808 in list, command=Pressed
  RFXCOM Debug                    <<-- entering deviceUpdated: DoorBell
  RFXCOM Debug                    deviceStop called. Device DoorBell not found in list.
  RFXCOM Debug                    deviceStart called. Adding device DoorBell, type: X10Switch
  RFXCOM Debug                    Adding X10 Switch N8 (7808).
I am using Indigo 6.0.3 on a mac mini with OS 10.8.4. I have installed the FTDI driver and the latest RFXCOM plugin.
As I am new to this I am not sure how this trigger should be set up. Should I be able to see a RF/X-10 N8 ON command in the log when I press the doorbell, and use this to command to set up a trigger? Thanks!
