I had a low battery warning - voltage dropped to 478. I replaced the battery with another one (that was supposedly new). Voltage indicated 455. Messages using either battery seemed good... Low battery detector on the Sensor device and a 1-wire scratchpad CRC error for the additional 1 wire sensor plugged into the main RFX sensor. All seemed good.
I replaced the battery with one still in the package. Voltage went to 498 which was pretty consistent with the previous brand new battery when I did not have problems. Both sensors started working as expected.However, both messages still remained on the device (low battery and the CRC error). I thought the messages would reset. I restarted the computer, and checked - both messages remained. I reloaded the plug in and they still remained. I noticed there is a reset value, but between the 1-wire connected to the sensor and the sensor, the values are different (see screen shots after battery replaced). The zero voltage for the 1-wire is expected.
- When does this message get reset?
- The voltage states around 500. The actual battery is a 9V. Why the difference or is this value really the wattage/milliamps?
Thanks this plugin is awesome!
