RFXTRX Cannot See Sockets
Fri Mar 22, 2013 4:15 pm
AndrewGWalsh offline
Hello. Is anyone else having difficulty getting the RFXTrx to see LW switched sockets?
The sockets connect ok to a LW remote control and the remote control connects ok to the RFXTrx but they are invisible to the RFXTrx.
I have emailed support at RFXCom but, while I am waiting for a reply I was wondering if anyone else had them working already? The RFXMNGR software doesn't have a tab for switches which was a little discouraging!
Andrew Walsh
Sat Mar 23, 2013 6:20 am
b_weijenberg offline
Re: RFXTRX Cannot See Sockets
LightwaveRF and HomeEasy sockets are receivers only. These modules do not transmit RF so the RFXtrx433 will not receive anything from a LWRF module.
You can pair the LWRF sockets with the Indigo device the same way as you pair the module with a remote. After this you can control the module the same way as with a remote.
Note: A module can be paired with up to 6 remotes (Indigo devices) If the module does not accept a pair command, reset the module to remove all remotes and try again.
Sat Mar 23, 2013 9:19 am
Aha! Many thanks for that - I've been bashing my head against this problem for a week.
I now have all my sockets operational :)
The steps for setting up a LightwaveRf Switched Socket are therefore as follows:
1 Create a device in Indigo of type RFXCom | LightwaveRF Appliance
2 In Edit Device Settings, allocate a unique House Code | Unit Number combination
3 Pair by doing the usual press and hold of the socket button AND turn it on from within Indigo whilst the socket is flashing
Indigo will keep a track of its state - but will get it wrong whenever it is altered manually because there is no feedback. This has implications for how you program use. Note also that whenever there is a power cut switched sockets default to off when the power returns.
Thanks again!
Andrew
