Unsupported temperature sensor?
Sun Mar 10, 2013 2:53 pm
krissh offline
I cannot seem to receive a temperature sensor, might be that I'm missing some settings or that it is not supported by the plugin?
This is what I get in rfxmngr.
085009019BFF00D379
Packettype = TEMP
subtype = TEMP9 - RUBiCSON 48659 stektermometer
Sequence nbr = 1
ID = 39935
Temperature = 21,1 °C
Signal level = 7
Battery = OK
If not supported, would it be possible to add this sensor to the plugin? :-)
Sun Mar 17, 2013 7:35 am
RJdeKok offline
Re: Unsupported temperature sensor?
This is a standard RFXCOM Temperature sensor.
It's ID is 65435.
It works here like a charm:
Before creating the device:
Teststring=085009019BFF00D379
RFXCOM Debug processing: 8 80 9 1 155 255 0 211 121 (08 50 09 01 9B FF 00 D3 79)
RFXCOM Debug Temp sensor 65435 now 21.10 degrees and 0 humidity.
RFXCOM Error unknown device detected (id = 65435, type = 80). Select a Temperature sensor from the list of devices
After creating the device:
RFXCOM Debug Temp sensor 65435 in list
RFXCOM Debug UpdateMinMax state temperature value 21.1
Sun Mar 17, 2013 8:08 am
krissh offline
Thanks for your reply :-)
I tried the teststring and got the same results as you.
However, before I added the device, nothing was shown in the event log when the sensor transmitted. And after adding the device (I've tried RFX Sensor, RFX Meter, Temperature Sensor), the temperature value is not updated. I've tried to enable all 433 MHz protocols, same results.
Running the teststring updates the temperature value for the device.
In rfxmngr I needed to enable Rubicson protocol to receive this sensor, which protocol would be equivalent in RFXCOM?
Thu Nov 28, 2013 2:47 am
krissh offline
Still no-go with this temperature sensor. In rfxmngr it works when enabling Rubicson protocol, which I can't seem to enable with RFXCOM plugin. Please consider adding/enabling the Rubicson protocol in the plugin :D
Users browsing this forum: Google [Bot] and 4 guests
