RFXCOM Debug Temp sensor 486 now 61.88 degrees and 96 humidity.
RFXCOM Debug Temp sensor 486 in list
RFXCOM Debug UpdateMinMax state temperature value 61.9
RFXCOM Debug check if new day: last date 2012/10/18, new date 2012/10/18
RFXCOM Debug UpdateMinMax state humidity value 96
RFXCOM Debug ++++++++++++++
RFXCOM Debug processing: 11 85 2 2 21 0 0 0 0 12 190 89 (0B 55 02 02 15 00 00 00 00 0C BE 59)
RFXCOM Debug Rainsensor 21 values updated rate:0.000000 total:12.830000
RFXCOM Debug Rainsensor 21 in list
RFXCOM Debug saving plugin props
RFXCOM Debug <<-- entering deviceUpdated: RFX Rain Gauge
RFXCOM Debug deviceStop called. Removed device RFX Rain Gauge.
RFXCOM Debug deviceStart called. Adding device RFX Rain Gauge, type: Rainsensor
RFXCOM Debug Adding sensor 21.
18Oct, 2012 10:46:16 AM
RFXCOM Debug processing: 10 82 1 3 5 1 0 215 44 1 89 (0A 52 01 03 05 01 00 D7 2C 01 59)
RFXCOM Debug Temp sensor 261 now 70.70 degrees and 44 humidity.
RFXCOM Debug Temp sensor 261 in list
RFXCOM Debug UpdateMinMax state temperature value 70.7
RFXCOM Debug UpdateMinMax state humidity value 44
RFXCOM Debug processing: 10 82 1 4 230 1 0 166 96 3 89 (0A 52 01 04 E6 01 00 A6 60 03 59)
18Oct, 2012 10:46:41 AM
RFXCOM Debug processing: 11 85 2 5 21 0 0 0 0 12 190 89 (0B 55 02 05 15 00 00 00 00 0C BE 59)
RFXCOM Debug processing: 10 82 1 6 5 1 0 215 44 1 89 (0A 52 01 06 05 01 00 D7 2C 01 59)
RFXCOM Debug processing: 10 82 1 7 230 1 0 166 96 3 89 (0A 52 01 07 E6 01 00 A6 60 03 59)
18Oct, 2012 10:47:28 AM
RFXCOM Debug processing: 11 85 2 8 21 0 0 0 0 12 190 89 (0B 55 02 08 15 00 00 00 00 0C BE 59)
RFXCOM Debug processing: 10 82 1 9 5 1 0 214 44 1 89 (0A 52 01 09 05 01 00 D6 2C 01 59)
RFXCOM Debug Temp sensor 261 now 70.52 degrees and 44 humidity.
RFXCOM Debug UpdateMinMax state temperature value 70.5
RFXCOM Debug processing: 10 82 1 10 230 1 0 166 96 3 89 (0A 52 01 0A E6 01 00 A6 60 03 59)
18Oct, 2012 10:47:58 AM
Received INSTEON "Thermostat Fam Study" humidity changed to 47.0
18Oct, 2012 10:48:13 AM
RFXCOM Debug processing: 10 82 1 11 5 1 0 214 44 1 89 (0A 52 01 0B 05 01 00 D6 2C 01 59)
RFXCOM Debug processing: 10 82 1 12 230 1 0 166 96 3 89 (0A 52 01 0C E6 01 00 A6 60 03 59)
18Oct, 2012 10:48:52 AM
RFXCOM Debug processing: 10 82 1 13 5 1 0 214 44 1 89 (0A 52 01 0D 05 01 00 D6 2C 01 59)
RFXCOM Debug processing: 10 82 1 14 230 1 0 166 96 3 89 (0A 52 01 0E E6 01 00 A6 60 03 59)
Received INSTEON "Thermostat Main Bedrooms" humidity changed to 45.0
RFXCOM Debug processing: 11 85 2 15 21 0 0 0 0 12 190 89 (0B 55 02 0F 15 00 00 00 00 0C BE 59)
Received INSTEON "Thermostat Fam Study" humidity changed to 46.0
18Oct, 2012 10:49:31 AM
RFXCOM Debug processing: 10 82 1 16 5 1 0 214 44 1 89 (0A 52 01 10 05 01 00 D6 2C 01 59)
RFXCOM Debug processing: 10 82 1 17 230 1 0 166 96 3 89 (0A 52 01 11 E6 01 00 A6 60 03 59)
RFXCOM Debug processing: 11 85 2 18 21 0 0 0 0 12 190 89 (0B 55 02 12 15 00 00 00 00 0C BE 59)
18Oct, 2012 10:50:06 AM
Received INSTEON "Thermostat Main Bedrooms" humidity changed to 46.0
RFXCOM Debug processing: 10 82 1 19 5 1 0 214 44 1 89 (0A 52 01 13 05 01 00 D6 2C 01 59)
RFXCOM Debug processing: 10 82 1 20 230 1 0 166 96 3 89 (0A 52 01 14 E6 01 00 A6 60 03 59)
18Oct, 2012 10:50:36 AM
RFXCOM Debug processing: 11 85 2 21 21 0 0 0 0 12 190 89 (0B 55 02 15 15 00 00 00 00 0C BE 59)
RFXCOM Debug processing: 10 82 1 22 5 1 0 213 44 1 89 (0A 52 01 16 05 01 00 D5 2C 01 59)
RFXCOM Debug Temp sensor 261 now 70.34 degrees and 44 humidity.
RFXCOM Debug UpdateMinMax state temperature value 70.3
Received INSTEON "Thermostat GameRm" temperature changed to 66.0
18Oct, 2012 10:51:12 AM
18Oct, 2012 10:51:28 AM
RFXCOM Debug processing: 10 82 1 23 5 1 0 213 44 1 89 (0A 52 01 17 05 01 00 D5 2C 01 59)
RFXCOM Debug processing: 10 82 1 24 230 1 0 166 96 3 89 (0A 52 01 18 E6 01 00 A6 60 03 59)
18Oct, 2012 10:52:02 AM
Received INSTEON "Thermostat GameRm" temperature changed to 65.0
RFXCOM Debug processing: 10 82 1 25 5 1 0 213 44 1 89 (0A 52 01 19 05 01 00 D5 2C 01 59)
RFXCOM Debug processing: 11 85 2 26 21 0 0 0 0 12 190 89 (0B 55 02 1A 15 00 00 00 00 0C BE 59)
RFXCOM Debug processing: 10 82 1 27 230 1 0 166 96 3 89 (0A 52 01 1B E6 01 00 A6 60 03 59)
18Oct, 2012 10:52:46 AM
RFXCOM Debug processing: 10 82 1 28 5 1 0 213 44 1 89 (0A 52 01 1C 05 01 00 D5 2C 01 59)
RFXCOM Debug processing: 10 82 1 29 230 1 0 166 96 3 89 (0A 52 01 1D E6 01 00 A6 60 03 59)
RFXCOM Debug processing: 11 85 2 30 21 0 0 0 0 12 190 89 (0B 55 02 1E 15 00 00 00 00 0C BE 59)
18Oct, 2012 10:53:22 AM
RFXCOM Debug processing: 10 82 1 31 5 1 0 213 44 1 89 (0A 52 01 1F 05 01 00 D5 2C 01 59)
RFXCOM Debug processing: 10 82 1 32 230 1 0 166 96 3 89 (0A 52 01 20 E6 01 00 A6 60 03 59)
RFXCOM Debug processing: 11 85 2 33 21 0 0 0 0 12 190 89 (0B 55 02 21 15 00 00 00 00 0C BE 59)
18Oct, 2012 10:54:04 AM
RFXCOM Debug processing: 10 82 1 34 5 1 0 213 45 1 89 (0A 52 01 22 05 01 00 D5 2D 01 59)
RFXCOM Debug Temp sensor 261 now 70.34 degrees and 45 humidity.
RFXCOM Debug UpdateMinMax state humidity value 45
RFXCOM Debug processing: 10 82 1 35 230 1 0 166 96 3 89 (0A 52 01 23 E6 01 00 A6 60 03 59)
18Oct, 2012 10:54:31 AM
RFXCOM Debug processing: 11 85 2 36 21 0 0 0 0 12 190 89 (0B 55 02 24 15 00 00 00 00 0C BE 59)
RFXCOM Debug processing: 10 82 1 37 5 1 0 213 45 1 89 (0A 52 01 25 05 01 00 D5 2D 01 59)
RFXCOM Debug processing: 10 82 1 38 230 1 0 166 96 3 89 (0A 52 01 26 E6 01 00 A6 60 03 59)
Schedule Crawl Space Fans (delayed action)
Sent X10 "Water 4 CrawlSp Fan Fam Rm" off
Sent X10 "Water 5 CrawlSp Fan Main House" off
Sent X10 "Water 6 CrawlSp Fan Game Room" off
18Oct, 2012 10:55:18 AM
RFXCOM Debug processing: 11 85 2 39 21 0 0 0 0 12 190 89 (0B 55 02 27 15 00 00 00 00 0C BE 59)
RFXCOM Debug processing: 10 82 1 40 5 1 0 213 45 1 89 (0A 52 01 28 05 01 00 D5 2D 01 59)
RFXCOM Debug processing: 10 82 1 41 230 1 0 166 96 3 89 (0A 52 01 29 E6 01 00 A6 60 03 59)
18Oct, 2012 10:56:05 AM
RFXCOM Debug processing: 11 85 2 42 21 0 0 0 0 12 190 89 (0B 55 02 2A 15 00 00 00 00 0C BE 59)
RFXCOM Debug processing: 10 82 1 43 230 1 0 166 96 3 89 (0A 52 01 2B E6 01 00 A6 60 03 59)
18Oct, 2012 10:56:36 AM
RFXCOM Debug processing: 10 82 1 44 5 1 0 213 45 1 89 (0A 52 01 2C 05 01 00 D5 2D 01 59)
RFXCOM Debug processing: 10 82 1 45 230 1 0 166 96 3 89 (0A 52 01 2D E6 01 00 A6 60 03 59)
RFXCOM Debug processing: 11 85 2 46 21 0 0 0 0 12 190 89 (0B 55 02 2E 15 00 00 00 00 0C BE 59)
