I have been having some stability issues with the RFX plugin.
When I start the plugin everything is working great, but after some time it seems like all the RF devices drop out and appear as unknown device in the log.
When this happens I cannot use any RF switches etc. But if I use Indigo touch I am able to send a command to my light dimmer. The errors that you see below is just repeating until I restart the plugin.
See cut out from log:
2012-09-23 00:00:06 Application Created new log file (Indigo Server version 5.1.5)
2012-09-23 00:00:06 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:00:12 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:00:14 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:00:20 RFXCOM Error unknown device detected (id = 262, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:00:24 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:00:26 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:00:40 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:00:41 RFXCOM Error unknown device detected (id = 260, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:00:54 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:00:54 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:00:59 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:01:05 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:01:08 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:01:11 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:01:20 RFXCOM Error unknown device detected (id = 262, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:01:22 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:01:32 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:01:34 RFXCOM Error unknown device detected (id = 257, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:01:36 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:01:41 RFXCOM Error unknown device detected (id = 260, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:01:44 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:01:50 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:01:52 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:01:58 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:02:03 RFXCOM Error unknown device detected (id = 344, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:02:11 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:02:18 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:02:23 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:02:32 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:02:34 RFXCOM Error unknown device detected (id = 257, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:02:50 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:03:00 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:03:02 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:03:14 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:03:20 RFXCOM Error unknown device detected (id = 262, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:03:28 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:03:30 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:03:32 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:03:38 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:03:41 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:03:42 RFXCOM Error unknown device detected (id = 260, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:03:42 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:03:52 RFXCOM Error unknown device detected (id = 344, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:03:56 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:04:08 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:04:10 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:04:19 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:04:20 RFXCOM Error unknown device detected (id = 262, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:04:24 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:04:31 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:04:34 RFXCOM Error unknown device detected (id = 257, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:04:38 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:04:41 RFXCOM Error unknown device detected (id = 260, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:04:47 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:04:52 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:04:59 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:05:06 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:05:06 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:05:20 RFXCOM Error unknown device detected (id = 262, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:05:24 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:05:26 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:05:34 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:05:38 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:05:48 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:05:53 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:06:02 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:06:05 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:06:17 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:06:17 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:06:20 RFXCOM Error unknown device detected (id = 262, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:06:30 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:06:34 RFXCOM Error unknown device detected (id = 257, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:06:40 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:06:42 RFXCOM Error unknown device detected (id = 260, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:06:44 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:06:44 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:06:56 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:06:58 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:07:10 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:07:12 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:07:20 RFXCOM Error unknown device detected (id = 262, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:07:23 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:07:26 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:07:27 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:07:27 RFXCOM Error unknown device detected (id = 344, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:07:35 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:07:40 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:07:54 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:08:02 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:08:03 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:08:08 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:08:14 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:08:14 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:08:22 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:08:36 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:08:41 RFXCOM Error unknown device detected (id = 260, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:08:42 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:08:50 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:08:53 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:08:56 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:09:01 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:09:04 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:09:18 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:09:20 RFXCOM Error unknown device detected (id = 262, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:09:20 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:09:32 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:09:35 RFXCOM Error unknown device detected (id = 257, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:09:41 RFXCOM Error unknown device detected (id = 260, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:09:46 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:09:48 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:09:49 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:10:00 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:10:00 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:10:11 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:10:14 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:10:20 RFXCOM Error unknown device detected (id = 262, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:10:35 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:10:38 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:10:42 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:10:42 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:10:50 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:10:56 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:11:03 RFXCOM Error unknown device detected (id = 344, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:11:10 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:11:17 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:11:22 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:11:24 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:11:29 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:11:34 RFXCOM Error unknown device detected (id = 257, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:11:38 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:11:56 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:12:06 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:12:08 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:12:09 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:12:20 RFXCOM Error unknown device detected (id = 262, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:12:28 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:12:34 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:12:35 RFXCOM Error unknown device detected (id = 257, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:12:35 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:12:41 RFXCOM Error unknown device detected (id = 260, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:12:47 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:12:48 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:12:56 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:13:02 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:13:14 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:13:16 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:13:21 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:13:30 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:13:43 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:13:44 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:13:53 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:13:58 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:14:05 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:14:12 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:14:14 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:14:20 RFXCOM Error unknown device detected (id = 262, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:14:26 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:14:30 RFXCOM Error unknown device detected (id = 26, type = 85). Select a Rain sensor from the list of devices
2012-09-23 00:14:32 RFXCOM Error unknown device detected (id = 290, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:14:40 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:14:41 RFXCOM Error unknown device detected (id = 260, type = 82). Select a Temperature sensor (with humidity) from the list of devices
2012-09-23 00:14:44 RFXCOM Error unknown device detected (id = 444, type = 80). Select a Temperature sensor from the list of devices
2012-09-23 00:14:54 RFXCOM Error unknown device detected (id = 194, type = 86). Select a Wind meter from the list of devices
2012-09-23 00:15:07 RFXCOM Error unknown device detected (id = 406, type = 82). Select a Temperature sensor (with humidity) from the l
