OS BHTR968 sensor
Fri Aug 31, 2012 10:37 am
frodier offline
OS BHTR968 sensor
I just installed the plugin and have it working with all my OS sensors except for the BTHR968 temp/humidty/Barometer sensor that came with my WMR968 station. It shows up as a type 84 in the error log and there is no ID associated with it. RFXCOM Error as follows --> "unknown device detected (type = 84).
I am running firmware 42. Is there something I've missed or is this sensor undefined in the plugin?
Wed Sep 05, 2012 4:34 am
RJdeKok offline
Re: OS BHTR968 sensor
Type 84 is not (yet) implemented.
Can you send me some data from the event log so I can implement and test it?
Thu Sep 06, 2012 8:45 am
frodier offline
Here are 2 logs from the RFXmngr for the sensor in question
    0D540200270000E5280003E60279
    Packettype = TEMP_HUM_BARO
    subtype = THB2 - BTHR918N, BTHR968
    channel 0
    Sequence nbr = 0
    ID = 9984
    Temperature = 22.9 °C
    Humidity = 40
    Status = Dry
    Barometer = 998
    Forecast = Partly Cloudy
    Signal level = 7
    Battery = OK
    0D540205270000E6280003E60289
    channel 0
    Sequence nbr = 5
    ID = 9984
    Temperature = 23 °C
    Humidity = 40
    Status = Dry
    Barometer = 998
    Signal level = 8
    Battery = OK
Here is the event log but since I had to switch the RFX from the MAC to the PC some of the values could have changed as reported by the RFXmngr
13 84 2 22 39 0 0 230 40 0 3 231 2 137 ( 0D 54 02 16 27 00 00 E6 28 00 03 E7 02 89)
Thank you in advance
FR
Thu Sep 06, 2012 12:42 pm
RJdeKok offline
Again a new version of the RFXCOM Plugin (V1.2.3) is available here: http://www.rjdekok.nl/downloads/RFXCOM.indigoPlugin.zip
- Temperatures fahrenheit now have a accuracy of .1 degrees.
- Barometer (Type84) implemented
Thu Sep 06, 2012 5:58 pm
frodier offline
:) Just installed the update and it works like a charm with the BHTR968 :D
Thanks for a great plug-in
FR
