THGR810 Oregon et Rfxtrx433
Fri May 25, 2012 2:46 am
Stef offline
Can you tell me how to configure my THGR810 probe on indigo
here is the log of the probe with Mmngr
0A520200E10100F1390179
Packettype = TEMP_HUM
TH2 subtype = - THGR810, THGN800
channel 1
Sequence nbr = 0
ID = 57 601
Temperature = 24.1 ° C
Humidity = 57
Status = Comfortable
Signal level = 7
= Battery OK
0A520201E10100F0390179
channel 1
Sequence nbr = 1
ID = 57 601
Temperature = 24 ° C
Humidity = 57
Signal level = 7
= Battery OK
Thank you Stef (Europe Belgium)
Fri May 25, 2012 6:08 am
johnpolasek offline
Re: THGR810 Oregon et Rfxtrx433
The RFX Plugin for Indigo makes it pertty easy; as soon as the RFXtrx is connected and the plugin is enabled it will assign a random channel number to each sensor the RFX recieves and tell you to define it in the log. You can then create an Indigo Device of type Plugin->RFX and configure it to the channel number and type from the log, and it becomes a standard device with the Temperature, Humidity, Min, Max, lastupdate time, battery and signal strength as states that can be used for display or trigger functions like anything else.
Users browsing this forum: No registered users and 18 guests
